New Patriot (slight alignment problem) - JeepForum.com
post #1 of 17 Old 05-14-2007, 07:46 AM Thread Starter
phil8400
phil8400's Avatar
My Patriot is brand new and the steering was dead on when I test drove it.
Since I took delivery, I've notice that I have to compensate the steering wheel to the left by less than half an inch. So it's really not a huge deal...it's more of an annoyance. Road camber is tricky, but middle highway lanes here are pretty flat and this is where I notice it the most.
Is there anything you folks can recommend I do to remedy this on own before I take it in for an alignment? Tire pressure is 35psi all around.
Do new cars often require wheel alignments? Does the dealer align the steering as part of the normal PDI process?
phil8400 is offline
post #2 of 17 Old 05-14-2007, 08:58 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Phil
This shoild have been done at the factory. Take it back to the dealer ASAP.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 17 Old 05-14-2007, 09:41 AM Thread Starter
phil8400
phil8400's Avatar
Originally Posted by Gramps
Phil
ASAP? You're scaring me
I just made the appointment and stressed that it was delivered like that.
phil8400 is offline
post #4 of 17 Old 05-14-2007, 10:00 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Sorry, maybe I shouldn't have put on the caps. asap will be fine.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 17 Old 05-14-2007, 11:21 AM
snikr
Have the dealer fix this for sure. They should have noticed this when they did there delivery check.
Tom
2010 Subaru Forester
2004 Dodge Dakota 4 X 4
So many roads.......So little vacation time
snikr is offline
post #6 of 17 Old 05-14-2007, 11:35 AM Thread Starter
phil8400
phil8400's Avatar
Is it relatively common for dealers to have to do an alignment on new off the truck cars? I'm assuming that the shipping via rail and truck could knock something off slightly - as is my case...it's off by about 1/2 an inch only. Still, I booked the appointment.
Gramps, thanks for lower casing that I'm assuming all they have to do is tighten a tie rod a bit...
phil8400 is offline
post #7 of 17 Old 05-15-2007, 03:33 AM
madrabbitt
madrabbitt's Avatar
i would have said take it in asaywt
but dont pay for the alignment.
yeah, it could have gotten knocked off slightly in transit.
dealer probably shouldnt have put it on the machine, but it should have appeared the day you left...
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #8 of 17 Old 05-15-2007, 05:00 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Sorry folks. You know that us grandpa’s have a lot of stories to tell. This one is about the time my mother was driving her new ’73 New Yorker out of the final prep area at the dealers and the welds on the steering gear bracket broke. Just one of the many reasons that with age comes cynicism and paranoia.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #9 of 17 Old 05-15-2007, 07:03 AM Thread Starter
phil8400
phil8400's Avatar
It did start the day I left. I just procrastinated about bringing it in for a while.
Hey Gramps, that reminds me of a bike my Dad bought me when I was six. It came in a box and had to be built. As soon as I took off, something snapped at the head and top tube, and down I went. At least I'm pretty sure that's how it went
phil8400 is offline
post #10 of 17 Old 05-17-2007, 05:04 PM Thread Starter
phil8400
phil8400's Avatar
Ok, I had an alignment done. I'd like for you guys to look the report over and tell me if you see anything wrong. I see a couple...
Forgot to mention that it still pulls and I still have to hold the wheel ~1” to the left…
phil8400 is offline
post #11 of 17 Old 05-17-2007, 05:25 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Well, the first thing is when did you buy a Liberty? Post your tire size, the specs are in the Service Manual and I'll look them up.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #12 of 17 Old 05-17-2007, 05:32 PM Thread Starter
phil8400
phil8400's Avatar
Well, the first thing is when did you by a Liberty? Post your tire size, the specs are in the Service Manual and I'll look them up.
Right. Also, isn't the rear camber not completely out of spec? -82/-89 where min limit is -63??
My tires are P215/65R17. Is this what you meant?
phil8400 is offline
post #13 of 17 Old 05-17-2007, 05:57 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
P215/65R17 exactly. The Liberty is a solid rear axle isn't it? Can't compare apples to oranges. This will take me a while, I can't do a cut and paste from the manual, only a print screen and it won't fit very well for this and even if it did you couldn't read it very well.
I'll be back.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #14 of 17 Old 05-17-2007, 06:12 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
ALL P215/65R17AT without OFF-ROAD GROUP (AWL)
FRONT WHEEL ALIGNMENT
CAMBER
-0.90° PREFERRED SETTING
-1.30° to -0.50° ACCEPTABLE RANGE
Cross Camber (Maximum Side-To-Side Difference)
0.00° PREFERRED SETTING
-0.50° to +0.50° ACCEPTABLE RANGE
CASTER* - LEFT * For reference only. These are nonadjustable angles.
+3.00° PREFERRED SETTING
+2.00° to +4.00° ACCEPTABLE RANGE
CASTER* - RIGHT * For reference only. These are nonadjustable angles.
+2.70° PREFERRED SETTING
+1.70° to +3.70° ACCEPTABLE RANGE
Cross Caster (Maximum Side-To-Side Difference)
0.30° PREFERRED SETTING
-1.30° to +0.30° ACCEPTABLE RANGE
TOE - INDIVIDUAL
+0.10° PREFERRED SETTING
0.00° to +0.20° ACCEPTABLE RANGE
TOE - TOTAL**
+0.20° PREFERRED SETTING
-0.10° to +0.40° ACCEPTABLE RANGE
REAR WHEEL ALIGNMENT
CAMBER
-0.80° PREFERRED SETTING
-1.20° to -0.40° ACCEPTABLE RANGE
TOE - INDIVIDUAL
TOE - TOTAL**
0.00° to +0.40° ACCEPTABLE RANGE
** TOTAL TOE is the sum of both the left and right wheel toe settings. TOTAL TOE must be equally split between each wheel on the same axle to ensure the steering wheel is centered after setting toe.
THRUST ANGLE
0.00°
-0.10° to +0.10°
Positive toe (+) is toe-in and negative toe (−) is Toe-out.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #15 of 17 Old 05-17-2007, 07:14 PM Thread Starter
phil8400
phil8400's Avatar
where did you get these? Are these for the Compass?
phil8400 is offline
Patriot Cabin Air / Exhaust fumes Problem safaribabe Jeep Compass & Patriot Forum 7 05-31-2011 09:35 PM
Headrest Problem On 2008 Patriot ChillyWillys Jeep Compass & Patriot Forum 16 08-24-2009 08:59 PM
10k for a New Patriot. kjp527 Jeep Compass & Patriot Forum 25 08-11-2009 09:16 AM
getting patriot, can't decide color! (how is the patriot?) taseal Jeep Compass & Patriot Forum 20 02-08-2008 11:46 PM
Well, i got to sit in one...(Patriot) madrabbitt Jeep Compass & Patriot Forum 14 04-10-2007 05:04 PM
