New Patriot downshifts funny. Should it? - JeepForum.com
post #1 of 13 Old 02-08-2014, 05:40 PM Thread Starter
normbrockway
2014 MK Patriot
6 speed automatic, but feels like a manual downshifting into 1st gear. It slows the car down when it downshifts, just like I was braking with a manual transmission. Is this normal in this transmission. This is my first Jeep, and want to get some advice before I go complaining to the dealer.
Help
normbrockway is offline
post #2 of 13 Old 02-08-2014, 07:51 PM
222Doc
222Doc's Avatar
you are selecting a lower gear, it slows down. sounds like it should be to me. i do not run a mk. if i am in 2nd low and tap it to first with no added gas it will send you through the window if not for the seat belts.
222Doc is offline
post #3 of 13 Old 02-09-2014, 01:55 PM
chachums
2004 KJ Liberty
Just got one myself, yes it's normal. Apparently after a few hundred miles you should start to notice it being a bit more smooth. That's coming from the manual though, I only gave 124 miles in mine so far
'04 Jeep Liberty
K&N Intake, Flowmaster Super 88 muffler.
OME NS131 Front Struts, OME927 H/D front Springs, Strut Top Plates; Rear OME948 H/D springs, OME132L Rear Long Travel Shocks and pair of rear extended bump stops.
chachums is offline
post #4 of 13 Old 02-09-2014, 05:23 PM
DEF1ANT
2014 MK Compass
The 6 speed automatic comes equipped with city braking assist. At slow speeds, around 20 mph and below, the transmission will hold the gear or downshift when you let go off the gas. It might feel weird at first but it's handy, no more having to move the foot around just to brake a little.
Also, if you are manually shifting the automatic. There's no need to downshift when coming to a stop. The transmission will put you in first gear automatically once stopped.
DEF1ANT is offline
post #5 of 13 Old 02-10-2014, 05:35 PM
chachums
2004 KJ Liberty
Dumb question but when manually shifting, only way to put it back into manual is to put it into neutral then back into drive... Is this true
'04 Jeep Liberty
chachums is offline
post #6 of 13 Old 02-10-2014, 06:12 PM
festerw
festerw's Avatar
If it's like the other autostick transmissions hold the stick towards the + side and hold it.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #7 of 13 Old 02-11-2014, 04:26 PM
chachums
2004 KJ Liberty
Never had an autostick lol thanks!!!!
'04 Jeep Liberty
chachums is offline
post #8 of 13 Old 02-11-2014, 04:59 PM
chachums
2004 KJ Liberty
Wow I feel likes *******, but it's clearly written right under the stick... Derp derp :-p
'04 Jeep Liberty
chachums is offline
post #9 of 13 Old 02-16-2014, 10:03 AM
ASTMedic
Hey OP is it the new 6 speed auto or the CVT trans? The CVT shows 6 "gears" when in auto stick mode.
ASTMedic is offline
post #10 of 13 Old 02-20-2014, 01:09 PM
caulk04
2008 WK
14 doesn't have the CVT anymore. It's a Kia/Hyundai sourced 6spd auto.
Drives nicely though I did notice the autostick doesn't function like my WK does. My WK autostick simply stops it upshifting past whatever selected gear but will still kick-down as needed. The new Pat we have holds a selected gear, even at WOT. DIfferent, I like it.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #11 of 13 Old 02-21-2014, 09:17 PM
dmill89
1995 XJ Cherokee
2014 FDII models still have the CVT as it is necessary for the simulated "low-range", FWD and FDI models now use the Hyundai 6-spd auto.
dmill89 is offline
post #12 of 13 Old 02-22-2014, 08:50 PM
ASTMedic
Just saw "new", didn't see how new.
ASTMedic is offline
post #13 of 13 Old 02-24-2014, 06:33 PM
caulk04
2008 WK
True, didn't think of that.
caulk04 is offline
