New to me oil consumption - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > New to me oil consumption
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! April Instant Rebate: Up to $75 off Flowmaster Products!
Unread 06-13-2014, 05:44 PM   #1
bigkat91
2011 MK Compass
Last oil change I put in regular white bottle valvoline. About 3000 miles into the oil change interval I checked the level (usually doesn't use any oil) and it was half full on the dip stick. I had been using Synthetic the previous 80,000 miles with no issues as stated before. I check the pcv valve and it rattles well blew through the hose it was clear and checked the hose running from the top of the valve cover to the air box. Tail pipe was a little sooty but not bad for a vehicle with that many miles. I switched back to synthetic this morning to see if it rectifies the situation. Has anybody have this issue when switching back to conventional after a long synthetic run.
2011 Compass 59K miles
RRO Lift
Tires:225 65 17
bigkat91 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2014, 08:24 AM   #2
Redpine
2014 MK Patriot
Yes, I have read about this phenomenon on Bobistheoilguy. It can happen when changing oil type (synthetic vs. conventional, vice-versa) or even when changing brands.
There is no definitive explanation why this sometimes happens. It's all speculation. Many report that after several thousand miles, the consumption returns to normal. Some think that maybe the new oil additive package is "washing away" (lack of a better term) the protective molecules embedded in/on the metal engine parts to be replaced with the new oil's protection additives. Once this is complete, the oil consumption returns to normal.
Opinions abound and mine is that some things go unexplained. You won't know unless you try the conventional oil for a longer period and observe the results. If you visit the site you might find more answers. People don't seem to be too concerned about it. In other instances, sometimes a different oil will clean off deposits on an older engine (ie - seals) and a leak will develop. The leak was bound to happen because the seal was wearing, but people like to blame the oil.
Redpine is offline   Reply With Quote Quick reply to this message
Unread 06-15-2014, 06:45 PM   #3
tjkj2002
2002 KJ Liberty
90% of your synthetic oils are actually not true synthetic,just highly refined conventional oil.You will not have any issues switching back and forth.
Your oil change interval can be a cause of the oil loss.The more miles the more oil a engine will start to use.
tjkj2002 is offline   Reply With Quote Quick reply to this message
Unread 06-15-2014, 06:56 PM   #4
bigkat91
2011 MK Compass
I'll continue to monitor oil levels. Its a 2011 with roughly 84k on the clock now and I've never had an oil issue before this last oil change.
RRO Lift
Tires:225 65 17
Unread 03-02-2015, 10:28 AM   #5
lastontheboat
2013 MK Patriot
I use conventional motor oil. Found a table spoon of oil under my 2013 Patriot (2.4L 16,000 miles) yesterday (2-28-15). Jeep is currently sitting at the dealership awaiting an oil leak test. Apparently Chrysler says it is acceptable to lose 1 quart every 2 thousand miles. I had no idea that loosing 25% of your oil capacity every 2k miles would be acceptable. I have a 1998 Saturn that doesn't burn a quart every 3K.
lastontheboat is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 11:08 AM   #6
bigkat91
2011 MK Compass
I've changed the pcv valve and switched back to "synthetic" and have lost only a half quart in 6000 miles. I'm now only 750 miles away from reaching 100k. Happy Jeeping.
RRO Lift
Tires:225 65 17
