04-22-2010, 08:53 PM
#1
New-To-Me 2007 MK Patriot, battery and nomenclature questions
Hi guy's and gal's,
Just sold my TJ for a new-to-me 2007 MK Patriot. I needed a new car for family and work, and the Patriot fit the bill perfectly. So far I love this thing. I've got myself the LHD model, which I have no idea means, but she's already been down a few trails here in WA. Just wanted to say, "Hey!" to everyone in my new forum.
Got a quick question too. So today I was cleaning off a bunch of corrosion on the + battery terminal, and I noticed the battery doesn't fit properly. Don't know if the used car dealership put in the wrong size or something. Though, when I looked online at patriot engine bays, looks like the battery is covered with a plastic cover, which I don't have. Wondering if someone can verify the battery setup? Is it an enclosed battery box? How is the battery held in place? Some pics would be awesome, and/or part number of the things I'm missing would be great. Thanks!
04-22-2010, 09:13 PM
#2
Welcome to our side of the forum, lol. As for that battery setup, I'll try and take a picture for you.
CACTUS_JACK
98 XJ Sport Budget Build
04-22-2010, 09:23 PM
#3
Thanks! That'd be great.
04-23-2010, 09:38 AM
#4
Hi and welcome to the forum. Our Pat has a plastic cover on top of the battery and it plugs into a small rectangular opening in front of the air filter.
04-23-2010, 10:04 AM
#5
Thanks for the welcome. How is the battery held down? Is there a battery strap? Or, is there something below? I'm missing these parts. I think the car dealer I bought it from put in an odd size battery, and threw away the OE parts. I guess I need the correct battery size, battery hold-down, and plastic cover.
04-23-2010, 11:05 AM
#6
Okay, our OEM battery is 8 3/4" X 6 3/4" wide and is supported by a bracket underneath
It says: Daimler Chrysler
Part No 56041380AE
CCA 525 AMPS
RC 100 MIN
Vendor Code 44949F
The plastic cover on top is fastened with 2 90 degree twist plastic blades and lifts up and out towards the front of Jeep. I hope this helps
04-24-2010, 11:08 AM
#7
Thanks guy's, appreciate the info. I'm off to the local parts stores to see if I can pick up a replacement battery terminal. Mine was just about corroded away on the + side. Stealership want $50. OMG! I'm afraid to ask them how much for the plastic battery cover. Might just be the excuse I need to throw on a K&N CAI. Same with the odd-sized Les Schwab batter. Might just throw on an Optima Red Top. That way I don't have to deal with corrosion.
After getting this settled I'm going to start tearing into this thing. Does the Patriot forum have a sticky for maintenance and torque specs like the wrangler forum?
04-24-2010, 01:23 PM
#8
The Necessary Evil
No we haven't done a write up like that, just on a few as needed. Most units are/were new and went in under warranty so it never became a hot topic like they did in the TJ's and maybe some others. http://www.jeepforum.com/forum/f9/tj...5/#post4334812
The drain plug is 40 N·m (30 ft. lbs.). and the torque specs for the suspension and brakes are in seperate write ups that you can find in the http://www.jeepforum.com/forum/f98/q...s-more-519045/
Any sugestions on what needs to be covered just let me know and I'll work on putting a list together.
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
04-25-2010, 12:27 PM
#9
Thanks for the info and quick links. Great stuff. Out Patriot is well beyond the warranty, so we'll be working on as much as possible. I had a service manual for my TJ, that I picked up on ebay for $5. Sadly, they are not that cheap for the Compass/Patriot. I think they are selling them for around $200.
As I tackle some of this stuff. If there is no write-up, I'll put one together and post it. Thanks again, and see you all around the forum.
04-25-2010, 12:31 PM
#10
Does LHD stand for Left Hand Drive by chance? I see this acronym used to mean left hand drive pretty often.
04-25-2010, 12:49 PM
#11
The Necessary Evil
Yes it does. I was going to mention that and spaced out.
You can sometimes find the CD on eBay but the graphics for the wiring diagrams ONLY works with IE6, period. However the service info is rather indispensable. If you need something specific just let me know.
Bob
01-24-2011, 05:55 AM
#12
hey, just purchased an 09 patriot for the wife. saw your missing battery cover and noticed it also acts as a vent that allows air flow around the engine..but i had to wonder to myself, "is this even necessary?" any one care to ring in here? id be more than happy to have an excuse to take it off and let air just do its thing.
01-24-2011, 06:11 AM
#13
The Necessary Evil
If you do the Cold Air Intake, either aftermarket or DIY, this piece is left off. The cover does direct cold in to the factory air filter. The engine compartment does get pretty darn hot but whether this is a significant amount of cold air I personally don't think so. On the other hand, if it wasn't necessary, why would the factory go to the expense of adding something totally worthless?
Bob
04-13-2011, 02:46 PM
#14
K&N Aircharger 63-1552 uses the stock fresh air duct
09-17-2011, 06:22 AM
#15
Part No 56041380AE
CCA 525 AMPS
RC 100 MIN
Vendor Code 44949F
Please supply me with a price.
Reason: I need a prise on a new battery
