Quantcast need diagram or info on chassis lube points for 07 Compass 4x4 - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > need diagram or info on chassis lube points for 07 Compass 4x4
Old 12-29-2009, 01:58 PM   #1
zing43
I want to change oil and lube and need diagram or info on chassis lube points for 07 Compass 4x4. Can anyone help
zing43 is offline   Reply With Quote
Old 12-29-2009, 07:03 PM   #2
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
There are no grease fittings unless you have replaced something with an aftermarket part that came with one. However, I occasionally spray all of the bushings with silicone spray.
There are no serviceable lubrication points on the front or rear suspension. The ball joints and tie rod ends are sealed for life and require no maintenance.
The front wheel bearing is designed to last for the life of the vehicle and requires no type of periodic maintenance.
The only serviceable component of the lower control arm is the ball joint seal boot. It should only be replaced if damaged during service of a chassis component. Otherwise, replace the entire control arm.
The rear wheel bearing and wheel mounting hub used on this vehicle are a one-piece sealed unit or hub and bearing assembly. It is permanently lubricated when assembled and is sealed for life. There is no periodic lubrication or maintenance recommended for these units.
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
Gramps is offline   Reply With Quote
Old 12-30-2009, 08:02 AM   #3
zing43
Thanks
Thanks alot Gramps
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
