Mysteries of the Jeep Speed Control - JeepForum.com
post #1 of 3 Old 03-19-2008, 07:42 PM Thread Starter
Stargazer79
2008 MK Compass
Just wondering if you fine folks have any insight into the machinations of the factory installed speed control in the Compass. Specifically, what mechanism it uses to regulate vehicle speed. (RPM/Gearing/Braking, how much of each) And what sort of impact is has on fuel economy for long hauls..
"It's always suicide-mission-this and save-the-planet-that. No one ever stops by just to say 'Hi' anymore.." - Jack O'Neill
~No Longer Breathlessly anticipating my '08 Rallye, now just enjoying the [Expletive Deleted] out of it.~
Stargazer79 is offline
post #2 of 3 Old 03-19-2008, 07:59 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Never having made the same trip twice so that I could do a with/without comparison on economy, I can't say. But it sre lets you streach your legs.
DESCRIPTION
The speed control system is fully and electronically controlled by the Powertrain Control Module (see below PCM). A cable and a vacuum controlled servo are not used. This is a servo-less system. The switch is labeled: ON/OFF, RES/ACCEL, SET, COAST, and CANCEL.
The system is designed to operate at speeds above 25 mph (40 km/h).
WARNING: the use of speed control is not recommended when driving conditions do not permit maintaining a constant speed, such as in heavy traffic or on roads that are winding, icy, snow covered, or slippery.
PCM
POWERTRAIN CONTROL MODULE
The PCM receives input signals from various switches and sensors that are referred to as PCM Inputs. Based on these inputs, the PCM adjusts various engine and vehicle operations through devices that are referred to as PCM Outputs .
PCM Inputs:
Air Conditioning Controls
Battery Voltage
Brake Switch
Camshaft Position Sensor
Clutch Upstop Switch
Clutch Interlock
Crankshaft Position Sensor
Engine Coolant Temperature Sensor
Fuel Level Sensor (Bus message)
Ignition Switch
Intake Air Temperature Sensor
Knock Sensor
Evaporative System Integrity Monitor
Manifold Absolute Pressure (MAP) Sensor
Oil Pressure Switch
Oxygen Sensors
Power Steering Pressure Switch
Speed Control Switches
Vehicle Speed Sensor (MTX-equipped models)
PCM Outputs:
Air Conditioning Clutch Relay
Charging Indicator Lamp (Bus Message)
Proportional Purge Solenoid
Fuel Injectors
Generator Field
Ignition Coils
Malfunction Indicator (Check Engine) Lamp (Bus Message)
Manifold Flow Valve
Oxygen Sensors Heater Controls
Variable Valve Timing
Vehicle Speed (Manual Transmission)
Based on inputs it receives, the PCM adjusts fuel injector pulse width, idle speed, ignition spark advance, ignition coil dwell and EVAP canister purge operation. The PCM also determines the appropriate transmission shift schedule and shift points, depending on the present operating conditions and driver demand. The PCM regulates the cooling fan, air conditioning and speed control systems. The PCM changes generator charge rate by adjusting the generator field. The PCM also performs diagnostics.
The PCM adjusts injector pulse width (air-fuel ratio) based on the following inputs.
Battery voltage
Coolant temperature
Exhaust gas content (oxygen sensor)
Engine speed (crankshaft position sensor)
Intake air temperature
Manifold absolute pressure
Throttle position
The PCM adjusts ignition timing based on the following inputs.
Coolant temperature
Knock sensor
Throttle position
Transmission gear selection (park/neutral switch)
The PCM also adjusts engine idle speed through the idle air control motor based on the following inputs.
Air conditioning sense
Battery voltage
Brake switch
Coolant temperature
Engine run time
Power steering pressure switch
Throttle position
Vehicle distance (speed)
The camshaft position sensor and crankshaft position sensor signals are sent to the PCM. If the PCM does not receive the signal within approximately 1 second of engine cranking, it deactivates the fuel pump. When these are deactivated, power is shut off to the fuel injectors, ignition coils, oxygen sensor heating elements and fuel pump.
The PCM contains a voltage converter that changes battery voltage to a regulated 5 volts direct current to power the camshaft position sensor, crankshaft position sensor, manifold absolute pressure sensor, throttle position sensor, A/C pressure switch, A/C pressure transducer, and vehicle speed sensor.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 3 Old 03-19-2008, 08:29 PM Thread Starter
Stargazer79
2008 MK Compass
Thanks, Gramps
Speed / Cruise Control Installation soycap Jeep Compass & Patriot Forum 124 04-08-2013 07:34 AM
Patriot-5 speed 4x4 vs CVT 4x4...?? DaveJKJ Jeep Compass & Patriot Forum 8 08-10-2009 07:00 AM
Bus Speed? Argent33 Jeep Compass & Patriot Forum 6 11-09-2008 05:07 PM
cruise control with 5 speed Transmition? etovar Jeep Compass & Patriot Forum 9 10-09-2008 01:07 PM
5-Speed vs. CVT mthackerson Jeep Compass & Patriot Forum 1 08-05-2007 02:31 PM
