Quantcast MK Lift Kit Available - Page 18 - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > MK Lift Kit Available
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 07-30-2009, 03:11 PM   #256
Rall-E
2008 MK Compass
MK lift and spacers
So it sounds like the RRO lift is working out well. What about a good set of spacers to clear that strut problem. Has anyone found or used any wheel spacers for the MK? I would love to run 30-31's on mine but I cant find spacers. grrr
Rall-E is offline   Reply With Quote
Old 07-30-2009, 04:10 PM   #257
Rall-E
2008 MK Compass
do you think the wheel spacers have to be hub centric or not? The compass/patriot hub/center bore is 67.1. A jeep wrangler 80-06 for instance is 71.5. It would fit but would not be hub centric .... right?
Old 07-30-2009, 05:16 PM   #258
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I do recall someone going with some pretty good size spacers. This is from memory so I may not be right on the money with the info. I also can't remember if it was on here or over at JP.
They used about a 2" spacer and some tires in the size that you are looking at. They ran into a problem with the tire hitting the wheel well because of the change in the turning arch. I do think that they had the lift kit also. I also recall them needing a different size spacer for the rear.
I do think that hub centric is a must and I know that the Tire Rack sells after market wheels with a centering adapter listed but I don't know where you would find them separately, I just haven't looked.
Some of the better spacers (not legal in all states) are up around $200 a set and it may be worth looking at wheels with a different offset that would do the same thing. But then you still have the turning arch to deal with.
Any one with a better memory on this please feel free to chime in.
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
Gramps is online now   Reply With Quote
Old 07-30-2009, 08:04 PM   #259
winkosmosis
Remember that a strut is already having to fight sideways bending unlike the spring in a double wishbone setup. Using spacers or wheels with more offset will make those forces greater.
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline   Reply With Quote
Old 07-30-2009, 08:24 PM   #260
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Right. The biggest hazard even if you do get them to fit is the increased stress on the half shafts and bearings. I imagine some early life failure some where in there.
Bob
Old 07-31-2009, 10:05 AM   #261
Rall-E
2008 MK Compass
Maybe I should just go with the goodyear fortera 245/60R18.
http://www.tirerack.com/tires/Spec.jsp?make=Goodyear&model=Fortera+HL+Edition&pa rtnum=46SR8FORTHL&tirePageLocQty=%26partnum%3D46SR 8FORTHL
Old 07-31-2009, 10:25 AM   #262
Rall-E
2008 MK Compass
my goal is mostly looks. I want a tire for highway most of the time. I need the lift from the RRO kit and taller tires to get on and off the beach. I want to get some aggressive looking tires that are good on the sand and the highway. I would like to give the MK a wider stance to, get the wheels just outside the fender. Maybe I could use some 1/2" spacers just for looks.
Old 09-17-2009, 12:37 PM   #263
Rall-E
2008 MK Compass
Ok well the RRO lift is on. I still need tires. I put 2" wheel spacers on and they look great!! Now I'm wondering if anyone else has a lifted rallye compass : )
Old 09-17-2009, 01:29 PM   #264
Argent33
2007 MK Compass
pics? since I have a Rallye I've been waiting for someone else to lift one
~Paul
-[O o l l l l l l o O]-|- 2007 Jeep Compass Sport Rallye Edition 4x4 - Black 5-Spd - K&N CAI
Founder of the Compass Rallye Collective
Black Jeep Society Member #287
Argent33 is offline   Reply With Quote
Old 09-24-2009, 10:47 AM   #265
Rall-E
2008 MK Compass
Old 09-24-2009, 10:48 AM   #266
Rall-E
2008 MK Compass
I cant seem to post pics : (
Old 09-24-2009, 11:01 AM   #267
Knightfallzx2
2008 MK Compass
Rall-E, pictures won't show up until you have a certain amount of posts made. I think it's 30. Just post the links to the pictures.
2008 Jeep Compass North 4x4
Black Crystal Pearlcoat, 5-speed
View my iPod integration kit tutorial.
Read my Blog on Jeepspace
Knightfallzx2 is offline   Reply With Quote
Old 09-25-2009, 03:38 AM   #268
Tony1911
2007 MK Patriot
The problem with the image is that its URL is not valid. Do post images using the IMG-tag even if you don't have the required amount of posts to post images. Makes it easier for others to no-clicky your posts by simply quoting them.
It's a Jeep Patriot thing. You wouldn't understand.
Tony1911 is offline   Reply With Quote
Old 09-25-2009, 09:49 AM   #269
Rall-E
2008 MK Compass
check out some pics of my lifted rallye at http://www.cardomain.com/ride/3385166
Old 01-05-2010, 08:34 AM   #270
cactus_jack
so quick question...will this lift kit work on the fwd compass? I hate to sound dumb, but I'm not putting $359 on my credit card without being sure
Cactus Jack-NAPA Auto Parts
cactus_jack is offline   Reply With Quote
compass, lift, lift kit, mk, patriot
Glock Forum
