Misc equipment - Mirrors & Aux Power - JeepForum.com
post #1 of 27 Old 05-25-2007, 09:58 AM Thread Starter
pszemia
2007 MK Compass
Hi, in 20 days i will finally get my jeep compass limited 4x4 jeep green arrived.
Here, in argentina, the equipments are almost similar but there are 2 important missing, and i want to know if i can add them.
1) electric folding mirrors. (mine include calefaction)
2) 110volt power outlet.
3) automatic diming mirror
1) is it possible to add this option? or it will cost a lot of money?
2) the power outlet, is tapped with a plastic, so i want to know if the wiring is still there, and i can reache them and insert the plug. Or what should i check to know if i can install it?
3) can i install it?
thanks,
ariel
pszemia is offline
post #2 of 27 Old 05-25-2007, 03:30 PM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
I have a Caliber, and I KNOW that you can install the U-Connect mirror in them if you have the auto dimming one, I would think you can install the auto dim mirror if you dont have it. Here's how to do that:
http://www.caliberforums.com/forums/...ghlight=mirror
I'm not sure though. As far as the power outlet goes, I dont know, and power fold mirrors (or even folding mirrors) are not available to us caliber guys. Somebody might be able to chime in about the Euro versions of the Compass, but I know Euro mirrors and ours have different wiring connectors.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #3 of 27 Old 05-26-2007, 10:06 AM Thread Starter
pszemia
2007 MK Compass
hi, mine is not euro compass (i think).
Thanks,
Ariel
pszemia is offline
post #4 of 27 Old 05-26-2007, 11:48 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
thanks,
ariel
1) Heated (calefaction) mirrors: I’m unsure of the connectors used in S America, but the male/female plugs could be changed. Do you have power mirrors now? If not, you will need a wiring harness and switch for the armrest.
Compass (MK49) power heated mirrors, fold-away:
US (out of stock at distributor):
Right - 5115 046AA
Left - 5115 047AA
Europe (availability unknown)
Right - 5115 294AC
Left - 5115 795AC (data entry error? sb 5115 295 possibly)
2) Argentina uses 220 V with a round 2 connector plug. To use your local appliances you would need a different converter and fabricate a plug or buy an adapter. You could also buy N. American appliances and use the 110 converter. I’m not sure what the export versions are shipped with as far as wiring or if the converter is installed either.
3) Do you just want the dimming mirror or do you want the UConnect phone option too? If it’s just the automatic dimming feature, that shouldn’t be too hard to find on the Internet.
I would think that all of these could be owner installed depending on your talents. A little bit of assembly knowledge and electrical experience would be needed. Check with your dealers parts department on availability of necessary items and then search the Internet to get the best prices. We do have a US dealer that is a vendor on this site, you may want to contact them for help:
http://www.wyckoffchryslerparts.com/
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 27 Old 05-27-2007, 04:11 PM Thread Starter
pszemia
2007 MK Compass
hi
the mirrors are power mirror, with electric control, but not fold away, but maybe i am wrong here, the fold away mirros, just open and close with the key? or there is an internal interruptor? if it's the second option, i have just power mirror withouth fold away (the thing i want)
the interior mirror, just auto-dim, not uconnect.
the power, is ok 110 and straight connector, because i have interchange plugs to use and most things here are 110-220 auto voltage select. So i want to know if just the plug is missing or all the wiring.
Thanks,
Ariel
pszemia is offline
post #6 of 27 Old 05-27-2007, 04:13 PM Thread Starter
pszemia
2007 MK Compass
i forgot, here the compass, as far as i can see (there are only a few) the rear headrest is not fixed, and there is also a central rear headrest
greetings,
ariel
pszemia is offline
post #7 of 27 Old 05-28-2007, 12:19 AM
madrabbitt
madrabbitt's Avatar
Assuming the existing rear view mirror is your everyday standard, glued onto the glass mirror, then an autodimming aftermarket mirror is probably your best bet.
heres theebay link
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #8 of 27 Old 05-28-2007, 03:03 PM Thread Starter
pszemia
2007 MK Compass
hi, thanks for that, but i am looking for original MOPAR accesories, because of warranty problems.
i dont know if the autodiming of mopar includes or not u-connect.
Thanks,
Ariel
pszemia is offline
post #9 of 27 Old 05-29-2007, 03:52 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Ariel,
The power mirrors here in N. America only fold away (swing in) when you brush against something, that part is not power, only the adjustment is controled by the switch on the armrest. All Compass' have fold away mirrors here in N. America
I have the auto dimming interior mirror in mine. It also has the mechanism for UConnect but is non functional since I did not get that option. Installing a rear view mirror that is not DC/MOPAR will have no affect on you warrenty.
To check out the 110 power outlet, I attempted to configure a Compass on the Argentina site but was unable to do it. I think the only way to find this out is to check with the dealers parts department.
i forgot, here the compass, as far as i can see (there are only a few) the rear headrest is not fixed, and there is also a central rear headrest.
LUCKY YOU! Wish we had that!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #10 of 27 Old 05-29-2007, 06:06 PM Thread Starter
pszemia
2007 MK Compass
hi
gramps, i have a question about that, if i buy the auto-dim (original mopar) mirror for my jeep, sholud i make some kind of strange connections?
about the 110 volt, i will wait to get mine and then remove the plastic cap that covers the outlet, and see how is everything there, then i will post the images.
Thanks,
ariel
pszemia is offline
post #11 of 27 Old 05-29-2007, 06:29 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Ariel,
All tho there is a wiring harness that comes out the back of the mirror, I believe that it's because of my "Drivers Convenience Group" that I have that is required to have the factory UConnect phone. The only thing that I can see that it does on mine is it lights up a little green light to tell me that the UConnect would be "ON" if I had it. As you can see from the posts on the Service Manual Wiring Diagrams, we are having a bit of a problem opening them. If I can get them to open, I'll trace down the circuitry on it and the Voltage Converter and maybe give you a better answer.
Minor update. I was able to read the index on the wiring charts and under "Power Converter" it said "All except export". It doesn't look promising.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #12 of 27 Old 05-30-2007, 11:21 AM Thread Starter
pszemia
2007 MK Compass
uhhhh bad bad bad
let's hop it's only a cable and an outlet so i can take out that ugly plastic cap,
greetings,
ariel
pszemia is offline
post #13 of 27 Old 06-10-2007, 01:05 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
110V Power Inverter and Outlet. Here's some links for better pics of the 3 & 4 Pics, I had to reduce them too much to attach. These would be with your head on the floor looking up.
http://i182.photobucket.com/albums/x...0InverterC.jpg
http://i182.photobucket.com/albums/x...0InverterD.jpg
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #14 of 27 Old 06-10-2007, 01:07 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Auto Dimming Mirror. On the C1 connector, 4 -7 are not used.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #15 of 27 Old 06-10-2007, 02:11 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Woops! Here's the wiring diagram for the Inverter.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Adding power windows question datachild Jeep Compass & Patriot Forum 10 08-10-2009 03:10 PM
loss of power? CharBroiled Jeep Compass & Patriot Forum 13 03-29-2008 08:27 PM
Want Power Options dolanmx305 Jeep Compass & Patriot Forum 7 03-16-2008 07:35 PM
Heated side mirrors? decimon Jeep Compass & Patriot Forum 19 08-08-2007 05:13 AM
Power outlets danbo Jeep Compass & Patriot Forum 6 06-07-2007 09:05 AM
