Loose steering wheel. - JeepForum.com
post #1 of 3 Old 07-19-2013, 10:28 PM Thread Starter
ezzymo1024
Okay. This one is odd. It just started happening. So it's not that there is play in the steering feel. But I can grab a hold of my steering wheel and rock it back and forth, side to side maybe a quarter inch or less. It feels like the physical mounting point of the steering wheel to the column has loosened. Maybe the mounting bolts? Any ideas?
ezzymo1024 is offline
post #2 of 3 Old 11-06-2013, 12:56 PM
seymourless
bump for an answer on this. Search has been tough, since i get the results from every death wobble post ever haha
seymourless is offline
post #3 of 3 Old 11-09-2013, 08:25 AM
Canada12
You can take the hornpad/airbag off. Check first for two 10mm bolts on backside of the steering wheel under cosmetic covers. If you are able to remove hornpad, DISCONNECT BATTERY FIRST. I think there is a 13mm bolt securing steering wheel to steering shaft.
Canada12 is offline
