looking to buy brakes - JeepForum.com
post #1 of 12 Old 05-08-2012, 10:53 AM Thread Starter
marco182
2007 MK Patriot
i need some new brakes for my Patriot. im wanting to get either slotted or drilled rotors and pads and calipers. what im really saying is a whole new brake kit any ideas on a good brand that i can buy? i live in Vancouver canada and looking for a good price. obviously not so cheap cuz you get what you pay for. ive looked around but since ive beengetting so much help here i thought id check here
marco182 is offline
post #2 of 12 Old 05-08-2012, 11:43 AM
tjkj2002
2002 KJ Liberty
Skip the whole slotted and/or drilled junk.You will gain no braking performance and generally will loose some.They are just for looks on the street and weight savings on the track.Almost all major racing leagues do not use slotted/drilled rotors.
Just use quaility blanks(solid rotors) like the Centric premiums and a high quality pads like Naps Adaptive Ones or similar.If there is nothing wrong with your calipers why change them? Only stock remaned replacements are out there for your vehicle anyways.
tjkj2002 is offline
post #3 of 12 Old 05-08-2012, 04:02 PM Thread Starter
marco182
2007 MK Patriot
i thought the drilled and slotted brakes were better for heavy braking so the rotors dont overheat?
marco182 is offline
post #4 of 12 Old 05-08-2012, 05:08 PM
tjkj2002
2002 KJ Liberty
Less metal = less heat disapation.They are also prone to heat cracking at the drilled holes.The drilled holes have zero effect on cooling,only wieght reduction and why they came around in some racing circuits where every ounce counts.The street scene thought they looked cool and that is how they came available to the public.
tjkj2002 is offline
post #5 of 12 Old 05-08-2012, 05:12 PM Thread Starter
marco182
2007 MK Patriot
excellent thanks for the info now just to find the cheapest place to buy them
marco182 is offline
post #6 of 12 Old 05-08-2012, 05:14 PM
tjkj2002
2002 KJ Liberty
Don't go cheap on brakes,shopping around is okay but going for the cheapest is just wrong as so many count on your brakes working right.
tjkj2002 is offline
post #7 of 12 Old 05-08-2012, 05:36 PM Thread Starter
marco182
2007 MK Patriot
yeah i met it as good deal gor good brakes
marco182 is offline
post #8 of 12 Old 05-08-2012, 06:21 PM
peytonimor7
FWIW, I always heard that slotted/drilled rotors do help with heat dissipation, but they're only good for racing, where you are pushing your brakes to the limit, so there is no notable difference on the street. Also, would slotted/drilled rotors help get mud out of your brakes?
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline
post #9 of 12 Old 05-08-2012, 10:44 PM Thread Starter
marco182
2007 MK Patriot
apparently i cant type
marco182 is offline
post #10 of 12 Old 05-09-2012, 04:56 AM
ddavidv
2008 MK Patriot
tkjk is absolutely right. Drilled rotors are one of the biggest wastes of money for street cars, duping people into purchase because they look cool. As I guy who races, I can assure you the drilled rotors are far more likely to develop heat stress cracks than a solid rotor. They are about weight savings, pure and simple. If you really want to read some tech about them, click here: http://www.8thcivic.com/forums/suspe...dissolved.html
Good quality 'blanks' to avoid warpage coupled with the best quality pads you can find/afford will do everything you'll need of brakes on the street. Don't try to out-engineer the engineers with a few bolt-on bits foisted by people who want your money.
ddavidv is offline
post #11 of 12 Old 05-10-2012, 12:55 AM Thread Starter
marco182
2007 MK Patriot
thanks for all the help i went with a ultra performance solid rotor with top quality brake pads. spent 675 for front and back
marco182 is offline
post #12 of 12 Old 05-14-2012, 02:35 PM Thread Starter
marco182
2007 MK Patriot
before
after
marco182 is offline
