Line output converter help - JeepForum.com
post #1 of 10 Old 11-21-2012, 05:48 PM Thread Starter
08PatLimited
2008 MK Patriot
So I installed a line-out converter to my REC nav unit until I sell it so I can hook up my amp and sub. Followed the instructions and used a quick connect from the rear right and left speakers to l.o.c. Ran the remote from the acc. on the deck.. Amp turns on and sub works. However the sub is at full volume even when the volume is on 1. When i turn up the volume the sub doesn't get any louder. I got a metra converter that has a ground wire and even tried grounding it and still the same thing. Did I miss something?
08PatLimited is offline
post #2 of 10 Old 11-21-2012, 09:52 PM
FujativeOCR
2011 MK Patriot
Turn the amp gain way down?
FujativeOCR is offline
post #3 of 10 Old 11-22-2012, 06:26 AM Thread Starter
08PatLimited
2008 MK Patriot
Doesn't make a difference except that the sub isn't as loud. Shouldn't the volume on the hu still control the sub volume
post #4 of 10 Old 11-22-2012, 10:38 AM
FujativeOCR
2011 MK Patriot
Theres no gain like adjustment on the loc?
post #5 of 10 Old 11-22-2012, 06:54 PM Thread Starter
08PatLimited
2008 MK Patriot
Yes there is. But i dont understand why it wont adjust the volume of the amp along with the actual volume like it does with an aftermarket hu. If i have the hu volume at about 20+ it's sounds awesome but from vol. 1-19 it's all bass because the amp is at full power the whole time. Is this something that always happens with L.O.C. I figured it would increase the volume of the sub the same as the speakers. Not just push the amp at 100% the whole time
post #6 of 10 Old 11-22-2012, 10:04 PM
FujativeOCR
2011 MK Patriot
No that isn't normal. If it was there would be no market for LOCs. Theres got to be a happy combination of gains between both the amp and the loc. start with them both at the bottom and work their way up. What about bass boost on amp and deck? Seems obvious but sometimes easy to overlook.
post #7 of 10 Old 11-24-2012, 07:28 AM Thread Starter
08PatLimited
2008 MK Patriot
So I figured it out. You have to run the l.o.c. from the speaker not behind the head unit. everything goes to an amp somewhere and then gets split off and sent to the speakers. just can't figure out how to run the rca from the rear door to under my seat but at least my bass sounds good now at not at full volume all the time
post #8 of 10 Old 11-24-2012, 09:57 AM
FujativeOCR
2011 MK Patriot
Where is the amp in the non-Boston system located? Been wondering that.
post #9 of 10 Old 11-24-2012, 11:31 AM Thread Starter
08PatLimited
2008 MK Patriot
no idea. i have the ba system. if i had to guess its either by the spare tire or behind the actual radio somewhere
post #10 of 10 Old 11-24-2012, 06:54 PM
FujativeOCR
2011 MK Patriot
Oh i know where the BA one is. There are two. One is under the right side of ghe back seat. Just behind it I should say. The other is in the plastic side panel by the subwoofer.
