Lift vs mpg - JeepForum.com
post #1 of 11 Old 05-11-2011, 10:20 PM Thread Starter
General_Jeep
1994 ZJ
Lift vs mpg
hows the mpg on that lifted compass? I was planing on running some bigger tire..
1994 Jeep Grand Cherokee 5.2L V8- NV3500 - Blown D35 8.8 replacement some day.
2010 Jeep Patriot 5 speed manual-- DD, 27-31MPG :D
1996 Dodge Ram 1500 - Work Truck/Plow 5.2L NV3500
2005 Nissan Titan - Hauler
"The Jeep is Americas only real sports car!" - Enzo Ferrari
General_Jeep is offline
post #2 of 11 Old 05-12-2011, 06:14 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Speedo calibrated for 28" tires (the best they can do) and I'm running 29.1" tires so everything gets a 1.04 multiplier. The speedo says 57.7 and I'm actually doing 60, just something to keep in mind.
Right now the EVIC says about 23.4 mpg (x 1.04) actual mpg = 24.3. I can accept that. The kids just took it on a day trip and got 24.2 (x 1.04) = 25.16. If the EVIC is reading 25mpg then it's an even 26mpg.
Odometer reads 67,366, installed tires and lift at about 30K, actual miles about 68,860.
TMI? It's a psychological thing on the math. Just keep in mind that your doing a little better than what the EVIC tells you but comparing it to stock I consider it rather negligible one way or the other.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 11 Old 05-16-2011, 06:54 PM Thread Starter
General_Jeep
1994 ZJ
Alright thank you for that info. I am going to install my lift after my warranty expires. After that the moding bug will start.
post #4 of 11 Old 10-03-2011, 09:13 PM
Burtonrocks
2007 MK Compass
Any recommendations on where do buy a lift kit for my 07 compass? Does someone make a kit I can buy?
Burtonrocks is offline
post #5 of 11 Old 10-03-2011, 09:22 PM Thread Starter
General_Jeep
1994 ZJ
http://www.rocky-road.com/patriotsus.html
These guys make a 2 1/8th lift for compass's and patriot's.
post #6 of 11 Old 10-04-2011, 06:50 AM
NHPATRIOT
2014 KL Cherokee
I would double check getting the speedo calibrated. Maybe on the Patriot/Compass it can't be done but I know on my Ram's if you gave the dealer the tire size, overall diameter( can vary within same tire size ), and then the revolutions p/ mile rate they could adjust the speedo using their scan tool for tires other than stock/stock options.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
NHPATRIOT is offline
post #7 of 11 Old 10-04-2011, 07:48 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
On the MK's, when I had mine done, they could only program it to the factory options, things may have changed. At the time I had mine done they could program the other Jeeps and Rams with many more tire sizes than stock. It never hurts to ask. It may have been the guy running the equipment too but others have ran into this too so I don't think so.
My lift is still doing fine btw. The EVIC says 23+ mpg so by the time I calculate the tire size error I'm up around 24, Good road, not freeway and not in town either. I still have another winter to go with my Kumho tires before I need new ones too.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 11 Old 11-02-2011, 05:37 PM
1SlowStang
This all sounds complicated lol. I'm happy I read this AFTER I asked the same thing in a different thread. I'm kinda slow some days haha
-Jim
07 Compass Sport- soon to be modded, I hope
04 Mustang GT- garage queen
1SlowStang is offline
post #9 of 11 Old 11-03-2011, 10:16 PM
patriot2009bk
2009 MK Patriot
So... Hypothetically.. a bigger tire helps make better mpg?
patriot2009bk is offline
post #10 of 11 Old 11-04-2011, 06:39 AM
tjkj2002
2002 KJ Liberty
In thoery but in reality you loose alot due to the extra weight of the tire and lost torque since you raised the final drive ratio.
For every 1lbs of added rotational weight is like adding 10lbs total vehicle weight.Doesn't sound like much but it adds up quickly and the lost torque compounds it unless you regear(which you can't) or add power to the engine.
tjkj2002 is offline
post #11 of 11 Old 11-04-2011, 07:18 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Originally Posted by tjkj2002 View Post
In theory but in reality you loose a lot due to the extra weight of the tire and lost torque since you raised the final drive ratio.
For every 1lbs of added rotational weight is like adding 10lbs total vehicle weight.Doesn't sound like much but it adds up quickly and the lost torque compounds it unless you re-gear(which you can't) or add power to the engine.
Changing from the Factory Firehawks to the Kumho I gained 6 lbs per tire and lost low end. This is most noticeable in town and would be noticed off-roading too. On the freeway you may see an increase because 'an object in motion tends to stay in motion'. The in town constant acceleration/deceleration kills gas mpg regardless. As far as it being 'a lot' that is very subjective since on the MK's there isn't much room to play with but it will make a difference. The tread pattern will also affect mpg. Generally speaking an off-road tire has more rolling resistance than a highway tire. In tests a bald tire will get better mpg but I don't recommend them.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
