lift for 2013 patriot? - JeepForum.com
post #1 of 15 Old 01-19-2013, 07:35 PM Thread Starter
daveWK42
2008 WK
so my fiancee just traded her 2011 KK liberty for a 2013 MK patriot. it's quite a bit lower than her liberty & she was thinking that she might want to put a small 2" lift on it to get some additional ride height. would she notice any loss in mpg's?
i'm coming at this from my WK, so i'm totally clueless. any help would be greatly appreciated.
Living well is the best revenge
hers: 2013 patriot sport
his: 2008 grand cherokee laredo
daveWK42 is offline
post #2 of 15 Old 01-19-2013, 10:29 PM
aroundincircles
1989 XJ Cherokee
Yes, she would notice a drop in MPG's but it should be pretty negligible. But if you go with a lift, I recommend wheel spacers, and a slightly larger tire. You can go up an inch and a half in tire size (overall diameter) and get some height that way as well. I run 245/65-17's I rub a bit, but you could go with a 225/70-17, which is 29.5" vs the stock 28" tire, and you should have little if any rubbing. and with a lift it will fill that wheel well, giving it a better look as well.
aroundincircles is offline
post #3 of 15 Old 01-20-2013, 11:18 AM Thread Starter
daveWK42
2008 WK
Thanks...appreciate the advice! I'm looking forward to playing around w/ this little jeep of hers & seeing what it can do!
I have a set of 245/65/17s from my WK laying around, maybe I'll just get some spacers & throw 'em on the MK for the heck of it.
daveWK42 is offline
post #4 of 15 Old 01-26-2013, 09:35 AM Thread Starter
daveWK42
2008 WK
One more thing. Will stock WK wheels fit on an MK? Fiancée likes my current wheel/tire combo & I was thinking of new wheels & bigger tires anyway.
daveWK42 is offline
post #5 of 15 Old 01-26-2013, 09:26 PM
xJoshxx
2012 WK
No WJ to WK2 wheels have been 5x5 since 99
5x127MM
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #6 of 15 Old 01-26-2013, 11:01 PM
aroundincircles
1989 XJ Cherokee
If you go with the 245's you'll need to modify this spot in the front wheel wells:
Otherwise it will rub, the way I did it was to use my dremmel with a cut off tool, cut the plastic, and the took a big hammer and flattened the pinch weld that's under it, last step was to spray it with black spray paint, then I'll probably use a plastic welder and cover it back up as flatly as I can with the plastic i cut off. Haven't done that part yet though.
post #7 of 15 Old 01-27-2013, 05:52 AM Thread Starter
daveWK42
2008 WK
xJoshxx what's the bolt pattern on the MK then? They look identical...
daveWK42 is offline
post #8 of 15 Old 02-01-2013, 07:04 AM
FourPointZero
2013 MK Patriot
Bolt pattern: 5x114.3mm or 5x4.5
Thread type: 12mm x 1.5
FourPointZero is offline
post #9 of 15 Old 02-01-2013, 07:10 AM
ramthis426
2005 WK
5x4.5 rims my gf just bought a patriot to and ive been playing around with it idk of any lifts but if you do a pinch weld cut and fold your be fine to go up a sizethen lift it and go up two sizes
05 3.7 wk QT1,2.25 Old Man EMU,255/75/17 GY silent armors,call of duty black moabs,Spidertrax
1.5,Pinch weld & rear fender mod,hypertech max energy.1992 jeep xj larado 4.0,4.5 rought country lift, coustome built rear bumper with tire swing soon to be on 33s
ramthis426 is offline
post #10 of 15 Old 02-01-2013, 02:46 PM
Kenny-g
Rocky Road Outfitters has a lift that keeps your stock suspension components (shocks and springs) but gives you a 2&1/8" lift ... most MK owners who want a cheap lift go this route and it's what Mopar Underground used on their Patriot Extreme concept back in 2010 and the Compass Canyon concept in 2011. Link for you; http://www.rocky-road.com/patriotsus.html
Also, ARB's Old Man Emu has a STU Coils lift for the MK's but it cost's more and gives you less lift...but id does supposedly give you a more cushioned ride quality. Some people love it but others dont like it. I do not know where people order those lifts from though. I'm trying to google it now and am coming up with nothing.
Project; LOST YETI
'13 Wrangler Sport "Lee-Roy2.0"
32" BFGoodrich Mud Terrain T/As | Rubi MOABs | OMIX-ADA Locking Lugs | Rough Country hybrid front bumper & 8K lb Smittybuilt winch coming soon!
Kenny-g is offline
post #11 of 15 Old 02-01-2013, 08:00 PM Thread Starter
daveWK42
2008 WK
Wow, Kenny, that's great! Super helpful, thank you...guess my WK wheels will go collect dust in the garage & we'll get her a new set of 17" to fit the 5x4.5 bolt pattern...
daveWK42 is offline
post #12 of 15 Old 02-04-2013, 01:01 PM
Kenny-g
^ Theres more tire options for 16's just saying. That's why I bought the TJ Rubicon wheels
Project; LOST YETI
Kenny-g is offline
post #13 of 15 Old 02-05-2013, 07:42 PM Thread Starter
daveWK42
2008 WK
Really? She HATES the stock 16"s that came on the thing...maybe I'll try to convince her to just get new wheels the same size...
daveWK42 is offline
post #14 of 15 Old 02-06-2013, 08:39 AM
aroundincircles
1989 XJ Cherokee
Get aftermarket 16s, get a wider rim, with some more backspacing.
post #15 of 15 Old 02-07-2013, 08:08 AM
Kenny-g
Or TJ Rubicon wheels like I did
Project; LOST YETI
Kenny-g is offline
