-   Jeep Compass & Patriot Forum (http://www.jeepforum.com/forum/f98/)
-   -   Larger Tires on Compass 4X4 (http://www.jeepforum.com/forum/f98/larger-tires-compass-4x4-1473675/)
12CompassLTD 02-04-2013 06:59 AM
I have a 2012 Jeep Compass Limited 4X4 CVT with the factory 18" Chrome Clad wheels. I would like to go to larger tires on the stock rims. Can I go to a 235 60 18 size with no rubbing issues? How much will performance suffer (with the increased tire height)? How about MPG? Any experience/help with this set up is appreciated.:confused:
Gramps 02-05-2013 10:27 AM
I ran Kumho's that size on my '07 Compass for a couple of years. The ride was good but you'll need to re-cal the speedo and the best that you can do is for a 28" tire and those are 29.1" tall. Your speedometer will be off by about 10 mph at 65 (65 = 75) so keep that in mind. Also your mpg's won't read correct on your EVIC (if equipped) either. Mine did not rub but that can depend on how much of a bulge there is in the side wall AND I have a lift kit in mine. I still have doubts that they will rub. I did pick up some 16" Patriot rims and I'm using those now with some 28" tall tires. Gas mileage has been slightly better since I've done that but only on longer drives. I don't 'hot rod' they way that I used too and off line performance didn't seem to change much with normal driving.
12CompassLTD 02-05-2013 02:30 PM
Larger Tires for Compass 4X4
Well, it sounds like clearance wise, I should be okay. I do have NAV, so I can get accurate speed readings that way. I usually figure out MPG the old fashioned way anyway. I think the benefits of the improved ride and looks provided by the larger tire would outweigh the bad. Thanks Gramps for the reply.:tea:
NHPATRIOT 02-05-2013 02:52 PM
I am running 225/65R17's on my 2011 Patriot which are a 28.5" tall and 8.85" wide tire. That is the generally accepted biggest( i.e. height and width )tire for the Patriot and Compass without problematic rubbing issues. Most people experience no rub while a few have minimal in certain situations( like me ). As Gramps told you that 18" tire size you mention is 29.1" tall( they are 9.25" wide as well )and you are probably going to have some rub( front wheels on full turn lock and rear wheels on spring mount ). Without a lift and wheel spacers I wouldn't, personally, run that size.
On my Patriot w/ those 28.5"/8.85" tires I get the slightest bit of rub on a right turn with the wheel literally cranked to full lock. Only happens in that certain situation which basically is having to crank it while pulling into a parking spot. Even then it is minimal and just the slightest release of pressure and it stops. Probably just the wheel liner is mounted slightly off on mine or something like that. Basically keep the tire diameter at or under 28.5" and keep the width under 9" and you should be fine. Exceed either and you will have rub most likely.
Your speedo will be off as well though as Gramps pointed out. 10 MPH off seems high though? Maybe though as he is taking 65 MPH. If you are really going 60 MPH you will only be going about 55-56 MPH on the speedo going up in that 18" size with no reflash.
Unfortunately you can't accurately calibrate the speedo on these vehicles. All you can do is have the dealer reflash to a different stock size. 215/65R17 is actually the largest stock size that can be used. If you reflash to that on a vehicle with 28.5" diameter tires your speedo will be off approx 2 MPH @ 60 MPH( you will be going faster than the speedo says ). On my Patriot 60 MPH is actually 61.8MPH checked with GPS. Close enough for me as I don't speed. If you reflash the speedo to the 215/65R17 size, while running the 235/60R18's, your speedo should be off approx 2.5-3 MPH @ 60 MPH. Again you will be going faster than the speedo shows. The faster you go the more the speedo will be off and vice versa( i.e. slower you go less it is off ).
A benefit of that for the vehicle owner is your odometer shows fewer miles than actual. It isn't much but over time it could add up and maybe let you squeak in under a warranty limit.
12CompassLTD 02-06-2013 02:10 AM
NH Patriot,
Thanks for the information! Steve.
The time now is 02:48 PM.
