Keyless entry - JeepForum.com
post #1 of 6 Old 04-16-2010, 08:08 AM Thread Starter
estropes
Keyless entry
Guys I need a little help.
My wife's Pat's keyless entry no longer works. Her car wouldn't start a few weeks back so I changed the battery in the Key-fob, then puled the battery cables on the Pat itself.
The car then started right up, but the keyless entry no longer works.
Any help very appreciated.
Thanks!
estropes is offline
post #2 of 6 Old 04-16-2010, 10:58 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Do you have a TPMS and does it work? They both run threw the SKREEM module which could be the problem. Can you get any codes pulled on this, that could help?
The Sentry Key REmote Entry Module (SKREEM) (3) is sometimes referred to as the Wireless Control Module (WCM). The SKREEM is the primary component of the Sentry Key Immobilizer System (SKIS). It is also the receiver for the Remote Keyless Entry (RKE) system and the Tire Pressure Monitor (TPM) system. The SKREEM is located on the right side of the steering column near the ignition lock cylinder housing and is concealed beneath the column shrouds. The molded black plastic housing for the SKREEM has an integral molded plastic halo-like antenna ring (1) that extends from one side. When the SKREEM is properly installed, the antenna ring is oriented around the circumference of the ignition lock cylinder housing.
A single integral connector receptacle (4) is located adjacent to the antenna ring on the SKREEM housing. An integral molded plastic mounting tab (2) on the SKREEM housing has a hole in the center through which a screw passes to secure the unit to the steering column lock housing. The SKREEM is connected to the vehicle electrical system through a single take out and connector of the instrument panel wire harness.
The SKREEM cannot be adjusted or repaired. If ineffective or damaged, the entire SKREEM unit must be replaced.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 6 Old 04-16-2010, 11:40 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I just found this too. Have you armed the system manually after disconecting the battery with the power locks?
POWER-UP MODE
When the armed VTA senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTA was armed prior to a battery disconnect or failure, the technician or vehicle operator will have to actively or passively disarm the alarm system after the battery is reconnected. The power-up mode will also apply if the battery goes dead while the system is armed, and battery jump-starting is attempted. The VTA will be armed until the technician or vehicle operator has actively or passively disarmed the alarm system. If the VTA is in the disarmed mode prior to a battery disconnect or failure, it will remain disarmed after the battery is reconnected or replaced, or if jump-starting is attempted.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 6 Old 04-16-2010, 12:09 PM Thread Starter
estropes
Gramps, is there anymore information on the powerup mode? That sounds like the issue, but doesn't have anything about a fix.
Thanks!
estropes is offline
post #5 of 6 Old 04-16-2010, 12:32 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
That's all that I thought may be pertinent to yours since you disconnected the battery. It's just a small section in the Vehicle Security Theft section of the FSM. Here some of the rest of it. Several sections involved pertain to key programming, SKIES initialization and a bunch of others. Let me know if any of this holds your interest to check out. The Power Up is simply the manual on/off of the power switch.
OPERATION
The Vehicle Theft Security System (VTSS) is divided into two basic subsystems: Vehicle Theft Alarm (VTA) and Sentry Key Immobilizer System (SKIS). Following are paragraphs that briefly describe the operation of each of these two subsystems.
VEHICLE THEFT ALARM
The ElectroMechanical Instrument Cluster (EMIC) is used on this vehicle to control and integrate many of the functions and features included in the Vehicle Theft Alarm (VTA). The EMIC is also sometimes referred to as the Cab Compartment Node (CCN). In the VTA system, the EMIC receives inputs indicating the status of the door ajar switches, the ignition switch, the liftgate ajar switch and the power lock switches. In vehicles built for certain export markets where it is required, the hood ajar switch provides a hard wired input to the Totally Integrated Power Module (TIPM) and both the TIPM and the Intrusion Transceiver Module (ITM) provide electronic message inputs to the EMIC over the Controller Area Network (CAN) data bus. The EMIC processes the information from all of these inputs, internally controls the security indicator as appropriate, and sends electronic messages to the TIPM over the CAN data bus. The TIPM internally controls the output to the hazard warning lamps and sends a control output to energize or de-energize the horn relay as appropriate. On vehicles with an ITM, the horn output of the TIPM is replaced by an output of the siren module that is controlled by the ITM.
The hard wired circuits between components related to the VTA system may be diagnosed using conventional diagnostic tools and procedures. Refer to the appropriate wiring information. The wiring information includes wiring diagrams, proper wire and connector repair procedures, details of wire harness routing and retention, connector pin-out information and location views for the various wire harness connectors, splices and grounds.
However, conventional diagnostic methods will not prove conclusive in the diagnosis of the VTA system or the electronic controls or communication between modules and devices that provide some features of the VTA system. The most reliable, efficient, and accurate means to diagnose the VTA system or the electronic controls and communication related to VTA system operation requires the use of a diagnostic scan tool. See the Vehicle Theft Security System menu item on the scan tool. Refer to the appropriate diagnostic information.
Following are paragraphs that briefly describe the operation of each of the VTA features.
ENABLING
The EMIC must have the VTA function electronically enabled in order for the VTA to perform as designed. The logic in the EMIC keeps its VTA function dormant until it is enabled using a diagnostic scan tool. The VTA function of the EMIC is enabled on vehicles equipped with the VTA option at the factory, but a service replacement EMIC must be VTA-enabled by the dealer using a diagnostic scan tool. Refer to the appropriate diagnostic information.
ARMING
Passive arming of the VTA occurs when the vehicle is exited with the key removed from the ignition switch, the headlamps are turned OFF, and the doors are locked while they are open using the power lock switch. Active arming occurs when the LOCK button on the Remote Keyless Entry (RKE) transmitter is depressed to lock the vehicle. For active arming to occur, the doors and the liftgate must be closed and the ignition switch must be in the OFF position when the RKE transmitter LOCK button is depressed. The power lock switch will not function if the key is in the ignition switch or the headlamps are turned ON with the driver side front door open.
Pre-arming of the VTA is initiated when a door or the liftgate is open when the vehicle is locked using a power door lock switch or when the RKE transmitter LOCK button is depressed. Pre-arming will not occur if the key is in the ignition switch or the headlamps are turned ON with the driver side front door open. When the VTA is pre-armed, the arming sequence is delayed until all of the doors and the liftgate have been closed. The VTA will remain in pre-armed mode for up to 16 seconds after all doors and the liftgate have been closed.
Once the VTA begins the passive or active arming sequence, the security indicator in the instrument cluster will flash rapidly for about 16 seconds. This indicates that VTA arming is in progress. If the ignition switch is turned to the ON position, if a door or the liftgate is unlocked or opened by any means, or if the RKE PANIC button (if equipped) is depressed during the 16 second arming process, the security indicator will stop flashing and the arming process will abort. Once the arming sequence is successfully completed, the security indicator will flash at a slower rate, indicating that the VTA is armed.
On vehicles equipped with the hood ajar switch, the VTA arming sequence will occur regardless of whether the hood is open or closed, but the security indicator will illuminate solid and the underhood area will not be protected unless the hood is closed when the VTA arming sequence begins. Also, if the status of the hood ajar switch changes from open to closed during the 16 second arming process, the security indicator will switch from solid to flashing and the VTA arming sequence will abort. Once the arming process is successfully completed, the security indicator will flash at a slower rate, indicating that the VTA is armed.
DISARMING
For vehicles built for the North American market, passive disarming of the VTA occurs by inserting a valid Sentry Key Immobilizer System (SKIS) key into the ignition lock cylinder or by turning the ignition switch to the ON position. Active disarming of the VTA for all markets occurs when the vehicle is unlocked by depressing the UNLOCK button of the RKE transmitter. Once the alarm has been activated, either disarming method will also deactivate the alarm. Depressing the PANIC button (if equipped) on the RKE transmitter will not disarm the VTA.
POWER-UP MODE
ALARM
The VTA alarm output varies by the version of the VTA with which the vehicle is equipped. In all cases, the alarm provides both visual and audible outputs; however, the time intervals of these outputs vary by the requirements of the market for which the vehicle is manufactured. In all cases, the visual output will be a flashing ON and OFF of the exterior lamps. For vehicles equipped with the North American or the export base version of the VTA, the audible output will be a pulsing of the horn. For vehicles with the export premium version of the VTA, the audible output will be a cycling of the alarm siren. The inputs that will trigger the alarm include the ignition switch, the door ajar switches, the liftgate ajar switch and, in vehicles built for certain markets where they are required, the hood ajar switch and the ITM.
TAMPER ALERT
The VTA tamper alert feature will pulse the horn three times upon VTA disarming if the alarm was triggered and has since timed out, or if the battery has been disconnected and reconnected. This feature alerts the vehicle operator that the VTA alarm was activated while the vehicle was unattended.
INTRUSION ALARM
The intrusion alarm is an exclusive feature of the export premium version of the VTA, which is only available in certain markets where it is required. When the VTA is armed, the ITM uses an ultrasonic transmitter and receiver which allows the module to monitor the interior of the vehicle for movement. If motion is detected, the ITM sends an electronic message to the EMIC and the TIPM over the CAN data bus to invoke the visual alarm features, and sends an electronic message to the alarm siren in the engine compartment over a dedicated serial bus to invoke the audible alarm feature.
The motion detect feature of the intrusion alarm can be disabled by depressing the LOCK button on the RKE transmitter 3 times within 15 seconds during VTA arming, while the security indicator is still flashing rapidly. The VTA provides a single short siren chirp as an audible confirmation that the motion detect disable request has been received.
The ITM must be electronically enabled in order for the intrusion alarm to perform as designed. The intrusion alarm function of the ITM is enabled on vehicles equipped with this option at the factory, but a service replacement ITM must be configured and enabled by the dealer using a diagnostic scan tool. Refer to the appropriate diagnostic information. The ITM monitors the conditions of the ultrasonic transmitter and receiver as well as the siren, and will store fault information in the form of a Diagnostic Trouble Code (DTC) if a system malfunction is detected. The ITM may be diagnosed, and any stored DTC can be retrieved using a diagnostic scan tool. Refer to the appropriate diagnostic information.
SENTRY KEY IMMOBILIZER SYSTEM
The Sentry Key Immobilizer System (SKIS) is designed to provide passive protection against unauthorized vehicle use by disabling the engine after about two seconds of running whenever any method other than a valid Sentry Key is used to start the vehicle. The SKIS is considered a passive protection system because it is always active when the ignition system is energized and does not require any customer intervention. The SKIS uses Radio Frequency (RF) communication to obtain confirmation that the key in the ignition switch is a valid key for operating the vehicle. The microprocessor-based SKIS hardware and software also uses electronic messages to communicate with other electronic modules in the vehicle over the Controller Area Network (CAN) data bus. .
Pre-programmed Sentry Key transponders are provided with the vehicle from the factory. Each Sentry Key REmote Entry Module (SKREEM) (also known as the Wireless Control Module/WCM) will recognize a maximum of eight Sentry Keys. If the customer would like additional keys other than those provided with the vehicle, they may be purchased from any authorized dealer. These additional keys must be programmed to the SKREEM in the vehicle in order for the system to recognize them as valid keys. This can be done by the dealer using a diagnostic scan tool or, if Customer Learn programming is an available SKIS feature in the market where the vehicle was purchased, the customer can program the additional keys, as long as at least two valid Sentry Keys are already available.
The SKREEM performs a self-test of the SKIS each time the ignition switch is turned to the ON position, and will store fault information in the form of a Diagnostic Trouble Code (DTC) if a system malfunction is detected. The SKREEM will also send an electronic message to the instrument cluster if a fault is detected, and the ElectroMechanical Instrument Cluster (EMIC) (also known as the Cab Compartment Node/CCN) illuminates the security indicator as appropriate.
The hard wired circuits between components related to the SKIS may be diagnosed using conventional diagnostic tools and procedures. Refer to the appropriate wiring information. The wiring information includes wiring diagrams, proper wire and connector repair procedures, details of wire harness routing and retention, connector pin-out information and location views for the various wire harness connectors, splices and grounds.
However, conventional diagnostic methods will not prove conclusive in the diagnosis of the SKIS or the electronic controls or communication between other modules and devices that provide some features of the SKIS. The most reliable, efficient, and accurate means to diagnose the SKIS or the electronic controls and communication related to SKIS operation requires the use of a diagnostic scan tool. Refer to the appropriate diagnostic information.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 6 Old 05-18-2010, 12:01 AM
ScubaStevie
2008 MK Patriot
Had this happen to my jeep while I was at work
There is a problem with some WCM and they stop the car from starting. It cost me $300 to get it replaced. Didn't have time to decide if i could have done it myself.
Chrysler did pay $100 of it back to me since I was only mileage out of warranty and they know of problem just no recall.
ScubaStevie is offline
compass , electrical , keyless entry , patriot , skreem
HOW TO: Installing Power locks and Keyless entry (in progress) cactus_jack Jeep Compass & Patriot Forum 1 01-25-2010 08:14 AM
08 Compass keyless entry cactus_jack Jeep Compass & Patriot Forum 10 01-19-2010 07:21 PM
2008 Compass Keyless Entry - Door unlock tonyp64 Jeep Compass & Patriot Forum 7 09-25-2008 04:08 PM
keyless enrty and headlights CharBroiled Jeep Compass & Patriot Forum 11 09-20-2007 02:15 PM
