Key fob programming - JeepForum.com
post #1 of 5 Old 11-20-2006, 03:37 PM Thread Starter
preese
Key fob programming
I'm beating head against the wall with this one.
On page 26 of the manual it talks about turning off the 'Sound Horn on Lock' feature. I don't have the EVIC feature so I'm doing it via the key fob.
The steps couldn't be easier:
1 Press the LOCK button for 4 to 10 sec
2. While the LOCK button is pressed (after 4 sec) press the PANIC button, release both buttons.
If it works, then when you hit the Lock button the doors will lock but the horn should NOT chirp.
I've not been able to get this to work, anyone else had issues with this?
Phil
preese is offline
post #2 of 5 Old 11-27-2006, 11:43 PM
karigador
Phil, my compass which arrives on wednesday (11/29) doesn't have the VIC either. I'll try to disable the horn on lock and let you know how it goes.
Craig
karigador is offline
post #3 of 5 Old 07-24-2008, 04:29 PM
mag9219
I have the same problem. A few sites on the Internet document the same procedure using lock and unlock button rather than the lock and panic button. That does not work either.
mag9219 is offline
post #4 of 5 Old 07-24-2008, 06:06 PM
CharBroiled
check this thread, this issue has come up before.. seems some need the dealer to do it? cant remember exactly.
http://www.jeepforum.com/forum/f98/security-horn-415845/
2000 Cherokee Sport 4.0L Selec Trac - mine - for occasional wheeling
2007 Patriot 2.4L FD I 4x4 - wifes - doomed to rarely leave the street
CharBroiled is offline
post #5 of 5 Old 07-25-2008, 10:00 AM
PirateKatz
I really wish our key FOBS were more like those on Fords. Where you press the button once and the doors lock but the horn doesn't sound, press again and the horn goes off.
My "chirp" is excessively loud on my Compass. I wish there was a way to make it a bit quieter or to behave like a Ford.
PirateKatz is offline
CVT2 custom programming KBlair Jeep Compass & Patriot Forum 4 04-02-2009 06:46 PM
