K&N AirCharger High-Flow Intake/Cold Air Intake - Merged - Page 8 - JeepForum.com
post #106 of 115 Old 10-21-2008, 09:50 PM
LiBMXr1390
1995 XJ Cherokee
open air issue possibly
do you need to reset the computer after you install an open air intake?? my economy dropped after i installed it and i was wondering if this was the culprit... thanks
LiBMXr1390 is offline
post #107 of 115 Old 10-22-2008, 03:43 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Yes. They do recommend disconnecting the battery during installation which does cause the computer to reset. Half an hour should do it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #108 of 115 Old 10-23-2008, 07:38 PM
Cobydick
I've got the K&N Cold Air installed. I noticed a difference, but it wasn't until i installed a Magnaflow Cat Back system that it made a true difference.
Cobydick is offline
post #109 of 115 Old 08-03-2009, 07:15 PM
shmup-o
2009 MK Compass
Anyone know if this will work for the 2.0L engine?
Edit:
Poked around this morning and they do make the 2.0L 57 series FIPK, but not the 63 series AirCharger.
shmup-o is offline
post #110 of 115 Old 09-22-2009, 05:06 AM
goshawk99
Hi, I went throught all the pages on this topic and I may have missed it but ....
isn't the intent of CAI to get COLD air... this unit is still on the top of the motor and is still getting warm air into it's system...
so where is the benefit... on spending all this $$$ when it is not getting the orginal idea of cold air....
inquiring minds wants to know....
thanks
goshawk99 is offline
post #111 of 115 Old 05-26-2011, 10:30 PM
Patriotwanted
When installing an open airfilter, you should always run an cold air feed pipe to the filter. Best place is at the foglight, but, if you go through mud and water, you won't be driving that far. You could. Put a pipe in behind the wheel arches, should stay clean over there, but give enough cold air
Patriotwanted is offline
post #112 of 115 Old 09-12-2012, 05:44 PM
SHABANG
2010 MK Compass
im about to order an intake for my 2010 jeep compass. i have decided on K&N. but after install, ive seen people put that original battery cover-? thing back on next to the new air filter. whats the deal with that? are you supposed to? is it ok if i dont?
SHABANG is offline
post #113 of 115 Old 09-13-2012, 06:44 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Since it's directing outside air to the old filter box that you are replacing it's only purpose would be to direct outside air to your engine compartment. It does get VERY hot in there but whether or not it helps to cool it down, I don't know.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #114 of 115 Old 09-13-2012, 07:40 PM
SHABANG
2010 MK Compass
well thanks! get back to me if you know if it does truly help to cool down or what. appreciate it!
SHABANG is offline
post #115 of 115 Old 09-14-2012, 03:41 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It's purpose is air flow to the filter which you are removing. Any side benefit of cooling the engine compartment by it not being connected to the air filter box is your call. Mine is as delivered from the factory. At this point YOU are R&D.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
cheaper cold air intake on eBay flipperCompass Jeep Compass & Patriot Forum 0 09-23-2009 06:59 AM
Has anyone added the Mopar cold air intake zing43 Jeep Compass & Patriot Forum 6 05-13-2009 12:02 PM
compass intake umopp Jeep Compass & Patriot Forum 2 12-01-2008 03:23 PM
where is the vacuum line on intake manifold ? horsey2k Jeep Compass & Patriot Forum 3 11-20-2008 06:54 AM
DIY Short Ram Intake for under $40 impulseballer Jeep Compass & Patriot Forum 13 09-21-2008 09:57 PM
