K&N AirCharger High-Flow Intake/Cold Air Intake - Merged - JeepForum.com
post #1 of 115 Old 02-01-2007, 09:47 AM Thread Starter
compassjeep
the cold air intakes are starting to come out for the compass/ caliber, for those that are looking for more power,
i will let you know , i will be buying the K&N version.
http://www.knfilters.com/search/prod...x?Prod=63-1552
http://www.globalautoshop.com/access...jeep_index.htm
compassjeep is offline
post #2 of 115 Old 03-12-2007, 06:16 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
There have been some inquiring about your K&N set up. Have you gotten to it yet or just doing the magnaflow first? An almost 8hp gain doesn't sound too bad for not going internal.
Good installation instructions here:
http://www.kandn.com/instructions/63-1552.pdf
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 115 Old 03-14-2007, 07:13 AM
Jason31
Something I didn't realize before, that dyno on K&N's website is for the 2.4L Dodge Caliber. That horsepower gain may or may not be realized on the Compass.
Would be interesting to see the difference in throttle response though.
Be sure that while you install the intake, you remove the negative battery cable from the battery. It will need to be off for at least a couple of hours to reset the computer so it can learn new timing tables with the increased air flow. This will also help keep your fuel mileage from taking a dump.
2007 Jeep Compass Limited - Black w/Chrome 18" OEM Wheels
Jason31 is offline
post #4 of 115 Old 03-14-2007, 07:36 AM
BuzzDog
Does anyone know if installing one of these would have any effect on the warranty?
Don't get me wrong - I like the idea of 5% more horsepower - but with an engine and transmission being of recent design, I like the peace of mind that comes from having a powertrain warranty.
BuzzDog is offline
post #5 of 115 Old 03-14-2007, 02:25 PM
Jason31
Its illegal for the dealer to void your warranty for an air intake UNLESS they can prove that the intake caused the problem.
Example: You install the intake and forget to put the filter on it. You run the engine for 10k miles this way. The cylinder walls are now gouged and the piston rings are complete crap, and they void your warranty.
Jason31 is offline
post #6 of 115 Old 04-03-2007, 10:07 PM
pillzny
Just received and installed it. Overall, I like it so far. The install was pretty easy. Other than the step where you have to install a sensor into the new tube, it was a sinch. All I needed was a flat head and plyers. Picked it up for $220 shipped
Positives:
-Considering I havent really gotten to test it out, I did notice a difference in HP. I've had my Compass since November... Noticable difference.
-Looks Good
-Hope there's a difference in gas mileage as they claim
Negative:
Little loud when you punch it - kind of sounds like a lawn mower
Overall I like it so far. It's a little late now but I'll take pix and comment on gas mileage in a bit
pillzny is offline
post #7 of 115 Old 04-04-2007, 05:40 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I hope that it’s a “Tim – the tool man – Taylor” Lawn Mower ! This sounds like a good way to go. Do you notice much difference off the line or is it in the driving range? And were the instructions on the website pretty accurate? Where did you find it for $50 less than list?
I pulled these from the other thread.
Instructions:
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 115 Old 04-04-2007, 08:23 AM
pillzny
I notice the biggest difference off the line and while I'm on the highway. K&N included paperwork guaranteeing a gain in 7.9 hp or your money back.
Regarding the directions, they are really accurate and it is that easy. Other than squeezing into a couple of tight spaces to get the stock parts out, steps 15 & 16 were the hardest. The sensor is about the width of your thumb and the hole is about the width of pencil. It doesnt help that it says that this is fragile part. Its downhill before and after those steps.
I searched for the best price and I found it here...
http://www.autoanything.com/air-inta...0A2540984.aspx
Ordered on Wednesday and received it on Tuesday
pillzny is offline
post #9 of 115 Old 04-04-2007, 08:49 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Sounds really great! Keep us informed on the mpg, not that it could suck that much gas but you could put your foot in it more often . Would just be nice to have the extra ponies when you needed them regardless of the mpg!!
Nice price too.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #10 of 115 Old 04-04-2007, 06:04 PM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
That's not like the Hot Air Intake that Mopar gave us is it?
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #11 of 115 Old 04-04-2007, 06:22 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Nope. COLD AIR! Higher volume, less restriction.
http://www.jeepforum.com/forum/showthread.php?t=369325
I just rechecked the links up in post #2 and they went dead. Posted a new link back there.
"They use only non-metallic rotationally molded tubes that can reduce intake air temperature and decrease intake sound over a metal tube. Restriction can exist BETWEEN an air filter and the engine reducing the benefit of a K&N Air Filter. The weakest link in the airflow “chain” robs a vehicle of its natural horsepower. Often that weak point is the factory air path leading to the Engine. K&N Air Intake Kits virtually eliminate air path restriction by replacing the air filter and the entire air path to the engine. The aerodynamically engineered tube drives a massive amount of air into an engine, which translates into POWER."
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #12 of 115 Old 04-04-2007, 11:06 PM
pillzny
Here's a pic
pillzny is offline
post #13 of 115 Old 04-05-2007, 04:57 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Here's the pic from the link. CLEAN looking!! Nice job! Also reposted pillzny's "Owners Pics".
Gramps is offline
post #14 of 115 Old 04-05-2007, 07:12 PM
Coasty161
i like the way that looks. also having the airfilter sitting where it is in the pic would help if u ever do water crossings. im guessing the same set up is gonna be used on the patriot too.
Coasty161 is offline
post #15 of 115 Old 04-21-2007, 06:23 PM
echocat22
2007 MK Compass
how is this working out for you? is your MPG the same? do you notice a significant difference, especially from a stopped position and the giving it gas?
echocat22 is offline
cheaper cold air intake on eBay flipperCompass Jeep Compass & Patriot Forum 0 09-23-2009 07:59 AM
Has anyone added the Mopar cold air intake zing43 Jeep Compass & Patriot Forum 6 05-13-2009 01:02 PM
compass intake umopp Jeep Compass & Patriot Forum 2 12-01-2008 04:23 PM
where is the vacuum line on intake manifold ? horsey2k Jeep Compass & Patriot Forum 3 11-20-2008 07:54 AM
DIY Short Ram Intake for under $40 impulseballer Jeep Compass & Patriot Forum 13 09-21-2008 10:57 PM
