Just got my 2014 Patriot with 205 70 R16 tires, can I? - JeepForum.com
post #1 of 7 Old 05-18-2013, 05:36 PM Thread Starter
POLBOSS
POLBOSS's Avatar
Was thinking of going straight to Discount Tire and get some all terrain tires but... there are no 205 70 R16 all terrain tires, but... plenty of 215 70 R16 all terrain tires... Which I understand are about .25 inch wider and about .20 inch taller, anybody running 215?
Or any all terrain tires that you recommend?
POLBOSS is offline
post #2 of 7 Old 05-18-2013, 06:31 PM
aroundincircles
1989 XJ Cherokee
225/70-16's should fit no issue. Even more choices!
89 Cherokee
aroundincircles is offline
post #3 of 7 Old 05-19-2013, 07:00 AM
Blackjak420
2009 MK Patriot
^^what he said
Sent from AutoGuide.com Free App
Blackjak420 is offline
post #4 of 7 Old 05-19-2013, 11:06 AM Thread Starter
POLBOSS
POLBOSS's Avatar
Thanks for your help
So... In any case 215 70 R16 would be absolutely fine?
POLBOSS is offline
post #5 of 7 Old 05-19-2013, 05:10 PM
aroundincircles
1989 XJ Cherokee
"should" is the key world. depends on the tire, not all tires are exactly the same size even though the tires are labeled the same size.
89 Cherokee
post #6 of 7 Old 05-19-2013, 07:52 PM
rhdeese
2007 MK Patriot
Im running 215 on my 2007 Pat.
rhdeese is offline
post #7 of 7 Old 06-05-2014, 02:04 PM
rick979tx
2012 MK Patriot
I went from 205/70 to 215/70 r16 just fine no difference at all really. 215/70s are what come on a lot of PATs FDI & FDII. The 2014 I almost Bought had them on it. I went with Terra Trac AT 2s on my 2012 FDI great on and off the Hwy so far only been on gravel roads, and some red clay sloppy mud nothing major. Will probably be going to 225/70s next go around with some General Grabber AT 2s 2012 Jeep Patriot FDI
2013
rick979tx is offline
