Jeep Patriot w/foggy windows!! - JeepForum.com
post #1 of 12 Old 12-12-2007, 09:53 AM Thread Starter
emo
I'm not sure if anyone else has had this problem but my windows are always fogging up unless I always have defrost on!! I had a 2004 Liberty and never had that problem in winter. It's really killing my gas mileage and driving me nuts. Does anyone have any idea what the problem might be? Any suggestions would be great. I need to go in for my first oil change and would like to be able to tell the dealer what to look for.
Other than that I love my Patriot and it's been great in the snow...even better than my Liberty was!!
emo is offline
post #2 of 12 Old 12-12-2007, 01:11 PM
eeyun
Could it be off-gassing from the interior plastics?
eeyun is offline
post #3 of 12 Old 12-12-2007, 01:27 PM
unclejjg
I'd check to see if there is a leak in your vehicle. Some members on another Patriot board are mentioning this quite often.
It might explain why you are experiencing more moisture, causing the fog, in your vehicle.
unclejjg is offline
post #4 of 12 Old 12-12-2007, 01:28 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Is it similar to mistyfate's problem or only foggy?
http://www.jeepforum.com/forum/f98/jeep-compass-windshield-condensation-311834/
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 12 Old 12-13-2007, 09:33 AM Thread Starter
emo
Thanks for the link. I just looked at misty's problem but mine doesn't happen when it's sitting it's more when i'm in it and driving. If I have a passenger it's a lot worse. The only way I can kind of control it is if I have defrost on hot and a high speed. I just can't figure out why I can't just have the heat on without using defrost. It's really weird because it starts with the side windows and gradually creeps onto the windshield.
emo is offline
post #6 of 12 Old 12-13-2007, 06:31 PM
unibus
2007 MK Compass
You might want to have the vehicle checked to make sure that when in defrost mode the air conditioner is being activated. The A/C is used to remove moisture from the cabin in defrost mode in almost all new cars these days. From the way you describe the problem that's the first thing I'd have the dealer check, second would be that the heater box is allowing fresh air into the car and is not stuck in recirculate mode.
unibus is offline
post #7 of 12 Old 12-13-2007, 06:39 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I was thinking about the "stuck in recirculation" mode, too. Glad that you thought of the A/C, I had forgotten about that.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 12 Old 12-13-2007, 07:35 PM
Jeepster55
my guess is the 'recirculate' button too.....on our trip to KC over Thanksgiving weekend, i noticed that the button had gotten pushed in a couple of times, inadvertently i guess. i've NEVER used a recirculate button on any car i've had for that very reason; FOGGING. also, the button has a light next to it that is suppose to come on when depressed, but mine didn't......interesting.
check out your recirculate button first.....that's where i'm putting MY money!
Jeepster55 is offline
post #9 of 12 Old 12-14-2007, 10:14 AM Thread Starter
emo
Okay thanks I'll check into that. I really appreciate all the advice!! I don't think I've ever even pushed the recirculate button since I've had this vehicle.
I did have a problem when I first got in with wet carpet in the back passenger by the door. They ended up taking apart my whole vehicle and found a plug was missing and even took out all the a/c parts to see if they were leaking. Chrysler had to come out and everything. They had my car for 13 days because they ended up ordering me new carpet and it was on backorder. At least the dealer paid for a rental car!!
They could've messed something up when they put it back together I guess. I'll let you know what I find out.
emo is offline
post #10 of 12 Old 12-20-2007, 09:00 AM
Matthew1785
if you have your car on defrost during the winter you lose gas milage?? i thought it was just heat?
Matthew1785 is offline
post #11 of 12 Old 12-20-2007, 05:21 PM
Jeepster55
no, actually with the 'defrost' on, your a/c compressor kicks on to help keep your windows from fogging. obviously, when your compressor is engaged, it's an added load on your engine and therefore drops your MPG.
post #12 of 12 Old 12-20-2007, 05:22 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
if you have your car on defrost during the winter you lose gas mileage?? i thought it was just heat?
The compressor runs when you have the defrost on so that 1. you dry out the air inside and 2. you don't have major A/C work to do come Spring/Summer because you didn't run the system once a month like your supposed to do. These new A/C systems don't draw nearly the HP that the old ones did. Even turning it on full blast in the summer is as close to negligible as you can get as far as losing any power is concerned. When you've had yours through the Summer you'll see what we mean.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Windows in '09 Patriot: slow, stuck, frozen, etc tripleGmax Jeep Compass & Patriot Forum 9 01-23-2009 03:40 PM
How do you like your Jeep Patriot? jeeper_creepers Jeep Compass & Patriot Forum 35 12-13-2007 03:19 PM
Jeep Patriot Adventure JeepInfoCenter Jeep Compass & Patriot Forum 12 08-29-2007 09:42 AM
OT Jeep Patriot optdoug Jeep Compass & Patriot Forum 14 05-15-2007 03:01 PM
Jeep Patriot SteelBlue_WJ Jeep Compass & Patriot Forum 36 04-09-2007 09:04 AM
