Jeep Compass - windshield condensation - JeepForum.com
post #1 of 22 Old 09-04-2006, 09:47 PM Thread Starter
Mistyfate
I've had my Compass for almost two months and I only have one complaint so far. Recently, I have noticed that I get a considerable amount of condensation on the inside of my windsheild - My vent setting was on the front dash defroster and it has been a wet week in NJ, however I don't think there should be any condensation. While I was away a family member noted a considerable amout of water on the inside; she said the whole windshield was covered and the water was dripping onto the dash. Has anyone else had this problem? Please let me know.
The problem was pointed out to me this evening and when I checked there was condensation on the interior bottom part of the windshield.
Mistyfate is offline
post #2 of 22 Old 09-06-2006, 06:42 PM
mealso
In the owners manual somewhere it should tell you that the AC is on, on the defrost settings unless you turn the temp up towards heat. This keeps the AC clutch from sticking from lack of use in the winter time. So just turn it up just before the red and the condensation should stop.
mealso is offline
post #3 of 22 Old 09-07-2006, 05:40 AM
Kev M
2012 WK
Good point.
Manufacturers also do this because generally speaking colder air is dryer air, so it actually does the job of defrosting much better as well.
Kev M is offline
post #4 of 22 Old 09-08-2006, 05:58 PM Thread Starter
Mistyfate
Thank you for your responses.
I'm afraid I was unclear in my original post...
the window condensation occured when my car was sitting in the driveway; not while anyone was driving. No one had driven it for over a day when the condensation was noted. The last setting that I had my air set to was defroster and it appeared as if somehow the humidity was creeping in through there while my car sat. I didnt know if there was a correlation with the vent setting to the condensation - I was just stating the situation.
Since then, whenever I park my car I leave the air vents on another setting and I have had no problems; however it has been relatively dry outside.
Thanks again tho! any further insight will help
post #5 of 22 Old 09-08-2006, 08:53 PM
JeepFreak91
i get the condensation on my xj but its always on the outside of the windsheild but never on the inside. maybe the hvac has a flaw in it that lets moisture in?
JeepFreak91 is offline
post #6 of 22 Old 09-11-2006, 09:13 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Sorry that I didn't chime in sooner, been on the road. I've had no problems with mine. It may be from "deposits" of some kind on the inside of the windshield, like smoke tar, but it could be something left by the factory. Try a really good cleaning with alcohol and see if that helps.
Gramps is offline
post #7 of 22 Old 09-11-2006, 09:25 AM
Melanie
Same problem in Neon
I had the same problem with my '98 Neon. (And sincerely hope that my soon-to-arrive Compass isn't heading in the same direction as the problems I had with that car!)
Sorry to say, but I never got the problem resolved with the Neon. As I live in the snow belt in Canada, I often had a bit of ice on the inside of the windshield as well. Just had to employ creative use of the defroster and vent.
If you come up with a solution, I'd be interested in hearing it!
Melanie is offline
post #8 of 22 Old 09-11-2006, 01:39 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I had 2 older cars with the same kind of problem. They had bad vent seals, cracked windshields and bad windshield seals so I just put up with it. The dealer should have a look at it and fix it on a new one.
Gramps is offline
post #9 of 22 Old 09-14-2006, 04:31 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Mistyfate,
We've had a lot of rain here, too and still no inside condensation problems. This morning we had some pretty heavy fog, 45 degrees, dew point of 46 and 93% humidity, still nothing.
I have noticed that on the outside of my windshield that I still have the suction cup marks from the installation. I'm going to do the same thing that we used to do in an optics lab for cleaning lenses. First COVER whatever is paint or plastic, clean well with acetone and then clean again with alcohol. Alcohol cleans off the sugar based deposits that acetone doesn't touch. Both maybe harmful to your paint and dash, so if you do this, be careful.
Another problem that you may have is that someone is getting into your Compass at night, folding the seats down and having a romantic interlude. If that's the case, lock you doors!
GOOD LUCK!!
Gramps is offline
post #10 of 22 Old 09-15-2006, 05:37 PM Thread Starter
Mistyfate
GOOD LUCK!!
You're too funny!
My sister makes similar comments all the time.
Thanks for your advice! I have noticed the suction cup marks too, on the upper right hand and left hand sides of my windshield.
I'll have to try the acetone/alcohol trick...I'll be sure to cover everything thing up since I know what havoc acetone can create.
post #11 of 22 Old 09-15-2006, 05:59 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Your sister and I...Great minds, same gutter! I hope it works for you!
Gramps is offline
post #12 of 22 Old 10-18-2006, 11:57 AM
phil8400
phil8400's Avatar
Same problem on my 04 Tiburon. I would suspect the seals. Although, what makes condensation?? Cold air meeting warm air.
I don't have the brain faculty (today) to come up with an answer to why sometimes it's on the outside and sometimes on this inside.
This said, if your car could quickly warm/cool to the outside temperature, then no condensation would occure. This would require leaky seals or other air leaks. Do you always turn off your vents when you park it for the night? Could it be that your car is so well sealed? I could very well be...
phil8400 is offline
post #13 of 22 Old 11-06-2006, 05:24 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I've had my Compass for almost two months and I only have one complaint so far. Recently, I have noticed that I get a considerable amount of condensation on the inside of my windshield - My vent setting was on the front dash defroster and it has been a wet week in NJ, however I don't think there should be any condensation. While I was away a family member noted a considerable amount of water on the inside; she said the whole windshield was covered and the water was dripping onto the dash. Has anyone else had this problem? Please let me know.
Mistyfate,
Could the aftermarket sunroof be causing your condensation problem or is it still a problem? BTW, check your PMs.
Gramps is offline
post #14 of 22 Old 11-08-2006, 11:44 PM Thread Starter
Mistyfate
I was thinking that the aftermarket sunroof could be the cause for my windshield condensation also, but I was not sure how to check.
It has happened one more time (since I last posted that everything was okay...go figure!)
And when I got into the jeep I touched in interior glass on the sunroof, and while there was slight condensation...there was no where near as much as what was on the interier windshield.
So I still have no clue. Another possibility that was pointed out to me was that...the compass maybe sealed very tightly and the condensation maybe coming from inside (since it has happened while it was raining and a day after the rain - but both times when I had a a full truckload of people with sopping wet sneakers)
for now it is not a huge concern for me. When I take it in for an oil change I will ask them to look into it. I was also thinking about a remote start...
post #15 of 22 Old 11-09-2006, 06:38 AM
Kev M
2012 WK
Has anyone asked yet it you run the air on a "recirculation" setting much?
Even in rain you shouldn't do that often, as it locks moisture into the cabin.
K
Kev M is offline
2007 Jeep Compass Windshield Replacement fourheels Jeep Compass & Patriot Forum 11 02-22-2016 06:04 PM
No Bus Jeep Compass 08 sad day... codered911 Jeep Compass & Patriot Forum 8 08-31-2008 11:33 AM
Like my Jeep (Compass) x96mnn Jeep Compass & Patriot Forum 2 03-09-2007 08:41 AM
Jeep Compass andrew2516 Jeep Compass & Patriot Forum 128 08-04-2006 10:44 PM
Compass now Available on jeep.com table Jeep Compass & Patriot Forum 2 05-31-2006 11:58 AM
