Jeep Compass Recall - JeepForum.com
post #1 of 14 Old 09-19-2008, 01:51 PM Thread Starter
Knightfallzx2
2008 MK Compass
Jeep Compass Recall
My took the Jeep to the dealership to have it's 3rd oil change. They told her there was a recall regarding the lower control arm bolts. Apparently many were not tightened properly. They went ahead and corrected this since it was of no charge to us.
I had not seen anything about this on here. Or am I blind. Gramps, you have anything on this oh-wise-one?
2008 Jeep Compass North 4x4
Black Crystal Pearlcoat, 5-speed
Knightfallzx2 is offline
post #2 of 14 Old 09-19-2008, 04:05 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I haven't seen anything on that either. Only the occasional early failure of a tie rod end and the one off rack and pinion mounting bolts being loose. I'll cruise a few sources and see what I can find on it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 14 Old 09-20-2008, 06:42 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The TSB and Recall list in the Caliber Forums is not available at this time. It is my favorite list to use and hopefully this is only temporary.
In the mean time, these sites are usefull but require more clicking to find what you may be looking for but can give you information about any vehicles that you may be interested in.
Allworldauto
About Automobile Main Page
For Compass About automobile
For Patriot About Automobile
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 14 Old 09-20-2008, 10:23 AM Thread Starter
Knightfallzx2
2008 MK Compass
Here's what the invoice said:
Complete Rapid Response - 08-070
Cause: Rapid Response
33CCZZ Campain Recalls
15841 Quik Respond 08-070 Perform Inspect Lower Control Arm Bolts
125Nm 02-10-05-90 Labour Operation #
The Jeep is back and what's done is done. I was just curious to see if you guys knew about it. Maybe it's just really new.
I'll check out your links at a later time, Gramps. Thanks.
post #5 of 14 Old 09-20-2008, 04:37 PM
merlinTec
merlinTec's Avatar
Hi
Rapid response transmittals will not show up on a recall list.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #6 of 14 Old 09-21-2008, 10:08 AM Thread Starter
Knightfallzx2
2008 MK Compass
I don't understand what you mean by that.
Is this therefore not a recall? Is it something that only effected my certain Jeep and not others? (I don't see how that would happen if true.)
post #7 of 14 Old 09-21-2008, 10:33 AM
merlinTec
merlinTec's Avatar
Hi
No it's not just yours but it's not a recall (no faulty parts) it's a Rapid response transmittals so will not show up on a recall list.
Regards,
Merlin
post #8 of 14 Old 09-23-2008, 05:42 AM
Skipsjh
Originally Posted by merlinTec View Post
Hi
Regards,
Merlin
When I took delivery of my 08 last week they replaced my LCA bolts while installed splash guards. They said it was a Rapid Response, not a recall. The mechanic had a whole pile of bolts he was going to trash on his workbench. He had done all the bolts in the Patriots and Compass' on the lot during the day. He wasn't happy!
'97 TJ SE - 2.5 AX5 NP231 - 167k
31x10.5x15 BFG AT's 2"BB
Skipsjh is offline
post #9 of 14 Old 09-23-2008, 08:39 AM
Argent33
2014 JK Wrangler
So is it something we should worry about? or wait until the Jeep goes in for service?
~Paul
-[O l l l l l l l O]- 2014 Freedom Edition JKU - Hydro Blue 6-Spd
Argent33 is offline
post #10 of 14 Old 09-23-2008, 09:27 AM
schoat333
2008 MK Patriot
So what if i never take my jeep to the dealer?
I do all my service myself so if this isnt a recall, how am i supposed to get it corrected? Im surely not going to be calling the dealer to ask them what problems they have fixes for. Thats the point of a recall notice isnt it? They mail it to you so you know that a part could fail and need to be inspected.
schoat333 is offline
post #11 of 14 Old 09-23-2008, 09:46 AM Thread Starter
Knightfallzx2
2008 MK Compass
Hi
Regards,
Merlin
For whatever reason, I just didn't clue in to what you meant. I understand now, thank you.
post #12 of 14 Old 09-23-2008, 12:47 PM
merlinTec
merlinTec's Avatar
Hi
If you never take your jeep to the dealer you would never know, If you call your dealer they will do a VIP sheet and it will show up on there if this RRT is outstanding. It’s only if a bolt is not at the correct torque then the bolt is replaced, if it is at the correct torque job done. No part is going to fail so no recall.
Regards,
Merlin
post #13 of 14 Old 10-23-2014, 08:52 AM
GOOSLEY
Is there a recall on the 2007 suspenion on the compass. Had it since 2007 , 45,000 miles on it. Recently went to get inspected and they replaced the lower control arm, front struts, inner tie rods and alignment. Now when i make a sharp turn my tires rub agst. The metal. They tell me that on compass's 2007 this is normal. Is it and is there a recall on them ????
GOOSLEY is offline
post #14 of 14 Old 10-29-2014, 04:52 PM
JTM1
1988 XJ Cherokee
Goosley, did the dealership do the inspection and subsequent parts replacement? if not, I would try to verify the parts were the right parts and installed correctly.
Justin
88 XJ-Lifted, Locked, and on Jackstands
69 CJ5-In peices
JTM1 is offline
No Bus Jeep Compass 08 sad day... codered911 Jeep Compass & Patriot Forum 8 08-31-2008 11:33 AM
Like my Jeep (Compass) x96mnn Jeep Compass & Patriot Forum 2 03-09-2007 08:41 AM
Recall (Compass) echocat22 Jeep Compass & Patriot Forum 35 02-26-2007 10:39 AM
Jeep Compass andrew2516 Jeep Compass & Patriot Forum 128 08-04-2006 10:44 PM
Compass now Available on jeep.com table Jeep Compass & Patriot Forum 2 05-31-2006 11:58 AM
