Jeep Compass ipod connection - JeepForum.com
post #1 of 28 Old 12-19-2006, 08:16 AM Thread Starter
laser
I need to connect my ipod to my Compass. What are my options? I've seen the Mopar integration kit for $125.00 which seems a little steep. I talk to the creepy guy at Radio Shack and he tried to sell me a $50.00 piece of equipment that goes through the radio.
Help!
laser is offline
post #2 of 28 Old 12-19-2006, 09:01 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Which radio do you have?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 28 Old 12-19-2006, 07:29 PM
g3cko
2011 JK Wrangler
I was wondering about this too since the expensive radio with navigation doesn't have an ipod hook up. I would think they might have even offered the myGig with the limited package or something.
g3cko is offline
post #4 of 28 Old 12-20-2006, 05:55 AM
BuzzDog
Supposedly a company called PIE makes an interface that allows you to plug in an iPod, but it doesn't allow you to have BOTH factory-installed Sirius AND the aux input. I had something similar in the GM car I traded in when I bought my Compass, and still have one in my Ford, and it works very well.
The concern I have with the Mopar kit is that the description refers to it as "FM bounded"...does this mean that it's an FM modulator that transmits on an "empty" FM frequency in your area? If so, best of luck...due to interference from FM stations, I found it extremely difficult to get one of these to work well on any frequency, and I'm hardly in a major metro area (approximately 400,000 people). Don't even ask what would happen when I ventured a few hours away to a larger metro such as Kansas City, Tulsa, Oklahoma City or Little Rock...it became impossible to use a modulator, because in those areas the FM dial is so "crowded" with commercial broadcast stations. If you're in Massachusetts, I would suspect it would be even worse due to the proximity of so many major cities in a relatively small area, which tends to mean more radio stations.
BuzzDog is offline
post #5 of 28 Old 12-20-2006, 08:04 AM
phil8400
phil8400's Avatar
Help!
Are you specifically looking at an integrated solution where you can control your iPod tacks, playlists and volume?
If not... if you have the single CD player...you have an auxiliary jack on the front of the head unit. All you need is a mini-stereo cable (male to male - headphone type plugs). Plug your iPod into the jack and voilà. This method allows you to control the volume using the head unit and the steering wheel volume control if you have them. If you have the six CD changer, then this option is not available to you.
As for an intergrated solution, the best is a complete hardwired solution, albeit a bit pricey. You will also have to pay for the installation. Many vendors sell these...even Best Buy etc. Specialized car audio stores definately have these and know their stuff. What installers normally do is drill a tiny hole in the back of the glove box where they feed the wire to the back or the head unit. You simply pull out the wire (uninversal iPod connector), and plug it into your iPod. Switch the stereo to SAT, AUX or CD Changer (depending on which port the installer plugged it into). From here, you can control everything (volume, tracks and playlists) on your iPod using the stereo/steering wheel controls. Very cool Leave the Ipod in the glove box or take it out and put it where you want as long as you have cable. You can ususally close the glovebox with the cable sticking out the corner without pinching it - if not, the installer will adjust the hindges or grind down a tiny slit for the cable to pass. My girfriend has this setup in her M3 and it's 100% seemless and she just loves it.
Mopar part#82210181 is an FM transmitter that is preset to a specific radio station. All you do is tune into that station, press play on the iPod and presto. Downsides to this application are:
1 Can't control iPod using stereo/steering wheel controls.
2 Sound degration compared to true digital in option above.
3 Radio interference - especially in big cities.
phil8400 is offline
post #6 of 28 Old 12-20-2006, 08:24 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Thanks Phil, I like that solution! I've got the RAQ, 6 CD, MP3 unit and the kids have been trying to talk me into an ipod for the past couple of months. The thought of playing with tiny buttoms and looking at a tiny screen while driving turned me off to them. If I ever go with one, that's the way I'd go.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 28 Old 12-20-2006, 08:59 AM
Kev M
2012 WK
My wife has been using her Ipod in her Mini for 2 years now and although it was easy to hook up through a CD changer harness that was already there, the fact that IF you want to change songs or playlists etc you have to look down at that tiny screen IS a real turn off for me (cause I've got Musical A.D.D. and like to futz with that stuff).
I think a fully integrated set-up is really the best way to go and I plan on doing that with my new Ipod in my Scoobie-Doo.
I also like that it can be out of sight (and out of mind) in a compartment.
Again, in Jenn's mini she looses one of her cupholders to the Ipod mount, and then there is the wiring from the Ipod to the powered adapter sticking out of the c12-volt power source. Ick.
Kev
Kev M is offline
post #8 of 28 Old 12-20-2006, 10:08 AM
phil8400
phil8400's Avatar
The best on the market is the DICE by Dension.
http://www.diceelectronics.com/ipod_integration.htm
They must have one for the Compass. It's isn't listed, but the Compass shares the exact same head unit as many other Jeeps and Dodges. Most car audio stores worth their salt carry or can order this model.
Email or call them first:
http://www.diceelectronics.com/contact.htm
Mucho dineros though...
phil8400 is offline
post #9 of 28 Old 12-20-2006, 10:47 AM
g3cko
2011 JK Wrangler
This is run through the auxiliary input, Is there even an option for that on the radio with the 6 cd changer?
g3cko is offline
post #10 of 28 Old 12-20-2006, 11:06 AM
phil8400
phil8400's Avatar
The OEM 6 cd changer does not have an aux input. With this stereo, you would need either a hardwired ipod intergrator like the DICE or FM transmitter.
PS: The OEM 6 cd changer will play raw mp3's on cd. The single disc HU does not - hence the aux input.
phil8400 is offline
post #11 of 28 Old 12-21-2006, 06:30 AM
g3cko
2011 JK Wrangler
I noticed this, and went out and grabbed some of my old mp3 cd's and I was listening to the same one for days. Awesome feature.
g3cko is offline
post #12 of 28 Old 12-21-2006, 10:17 AM
phil8400
phil8400's Avatar
On the two stereo options...
I can understand why the HU that plays mp3's would not have an aux jack, and the one that does have an aux jack, does not play mp3's. However, an aux jack should be standard these days, as should the ability to play raw mp3's.
The thinking behind this is quite lame - IMHO. Cost cutting? Probably.
phil8400 is offline
post #13 of 28 Old 01-19-2007, 09:38 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
As for an integrated solution, the best is a complete hardwired solution, albeit a bit pricey. You will also have to pay for the installation. Many vendors sell these...even Best Buy etc. Specialized car audio stores definitely have these and know their stuff. What installers normally do is drill a tiny hole in the back of the glove box where they feed the wire to the back or the head unit. You simply pull out the wire (universal iPod connector), and plug it into your iPod. Switch the stereo to SAT, AUX or CD Changer (depending on which port the installer plugged it into). From here, you can control everything (volume, tracks and play lists) on your iPod using the stereo/steering wheel controls. Very cool Leave the Ipod in the glove box or take it out and put it where you want as long as you have cable. You can usually close the glove box with the cable sticking out the corner without pinching it - if not, the installer will adjust the hinges or grind down a tiny slit for the cable to pass. My girlfriend has this setup in her M3 and it's 100% seamless and she just loves it.
Thinking out loud again. If you can get an integrated AUX jack for an IPOD can you get one that takes a USB thumb drive? I don't have an IPOD, I'd have to buy one; I do have 2 Gig and 4 Gig thumb drives. At least I could save the $$ from buying an IPOD.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #14 of 28 Old 01-19-2007, 05:27 PM
phil8400
phil8400's Avatar
I'm not sure, unless you don't mind changing your head unit. Many manufacturers make HU's with USB ports which support mp3 playback.
phil8400 is offline
post #15 of 28 Old 01-19-2007, 05:36 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Thanks Phil, I've seen those and didn't really want to go that way, I can buy an Ipod cheaper. I can load MusicMatch controllers on to the thumb drive that I believe would act like Ipod software. In my searching I did find this:
http://www.theautochannel.com/news/2...24/022874.html
All I can say on that is WOW!!! How sweet!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Which iPod do you own? I have Mopar iPod Interface (82210181AB), I need to buy iPod. Beware Jeep Compass & Patriot Forum 7 05-08-2009 06:05 PM
No Bus Jeep Compass 08 sad day... codered911 Jeep Compass & Patriot Forum 8 08-31-2008 11:33 AM
Like my Jeep (Compass) x96mnn Jeep Compass & Patriot Forum 2 03-09-2007 08:41 AM
Jeep Compass andrew2516 Jeep Compass & Patriot Forum 128 08-04-2006 10:44 PM
Compass now Available on jeep.com table Jeep Compass & Patriot Forum 2 05-31-2006 11:58 AM
