Jeep compass 2007 oil change - JeepForum.com
post #1 of 15 Old 08-17-2010, 02:45 PM Thread Starter
compasser
Hi Guys
I am new to this forum and I would like to know a thing which makes me nervous
I do have the jeep compass 2007 2.4 benzin
I looked at the oil and it looked dark well lets say not little dark but a bit more than little. but not burned.
on the cover its written put 5w-20
I couldnt find it in finland then I went to the jeep dealer and he said we put here 5w-40 full syhthetic oil! and no market has 5w-20 there is only 5w-30 and then something like 0w-__
the other thing that car was serviced when it was 60 000km and now its 65700km so the dealer said usually it depends on the country here in finland we change oil every 30 000km and we change spark plugs every 45000km and oil kind 5w-40
so any advice please? what are differences with oil types? and does then 5w-30 work better?
another thing can air filter be cleaned or it has to be exchanged?
and spark plugs they look with no carbon on the ends but the white part of it has a yellow circle from the begining of it? still works? or should be replaced?
thanks alot for any advice you may tell
compasser is offline
post #2 of 15 Old 08-17-2010, 04:04 PM
miketmx
2015 MK Patriot
Hi as far as I know 5W-30 is approved for all 2.4 gas engines other than U.S.A. where it is a greenie thing. I don't know anything about the diesel engines. 5W-30 is fine in the U.S. as well. I use synthetic and change oil every 8k km, with non-synthetic I would change every 5k km. The air cleaner must be replaced; in Canada it is 50k km along with spark plugs.
miketmx is offline
post #3 of 15 Old 08-17-2010, 05:35 PM Thread Starter
compasser
Thanks for the fast responce
so if the 5w-30 works here is 5w-40 full is also aprroved but what is the difference is it like softer or ?
post #4 of 15 Old 08-17-2010, 07:21 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The lower the first number the "thinner" it is at cold temps making for easier starts. The higher the second number the heavier it is at hi temps for more protection. That's an over simplification but understandable.
I have been using 0W-30 in mine for several years now. IMHO Finland doesn't get hot enough to warrant 5W-40. My temps range from a low of -30F (-35C) to a high of 90F (+35C).
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 15 Old 08-18-2010, 03:44 AM Thread Starter
compasser
Thanks Gramps, this was clear explaination about the differences,
the thing is I dont understand Finns when they fix cars.
the weather is from -30c to +30c
the dealer said 5w-40 so is it since thick then hard to be frozen? I am really confussed but do you think it harms the engine if I put this 5w-40`? or it just deals with fast start of engine and weather?
or lets say to keep engine heating degree high? because regularly in finland the normal heater gage while car works is on the "half". another thing is that we do have a motor heating system inside the engine and the car works on electricity, when you park your car you plug it to 240v electric plug then at morning all is warm like summer.
post #6 of 15 Old 08-18-2010, 09:01 AM
miketmx
2015 MK Patriot
5W-40 would not lubricate as well as 5W-30 because it is too thick at warmer temperatures. The only use for that grade would be continuous high speed driving in very warm conditions.
miketmx is offline
post #7 of 15 Old 08-18-2010, 10:48 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Here's a nice chart and some easily understandable (for me) info that you may find helpful. What Every Motorist Should Know About Motor Oil
The reason that Jeep, for N.A. applications, recommends 5W20 is that there is less friction at higher temps to pass the pollution police. Outside of N.A there was a TSB released that said it was OK to use 5W30.
In most of the specs that I looked at 5W is good protection down to -25C, below that 0W is better. As you can see from the chart in the link above 30 is as high as you need to go for your temps in Finland. Now with all of the charts and ideal conditions you still have to run what's available in your area. I have no problem getting the 0W30 and it works great for me. My Jeep is parked outside with no engine heater and I never have any problem starting it on cold winter mornings.
Overhead cam engines also like the 30 better than the 40 weight at higher temps too.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 15 Old 08-18-2010, 03:47 PM Thread Starter
compasser
well guys I am sure that the way you answered would be the right one.
anyway I asked an american friend of mine he got his mpv mazda from the states and put always 5w-20, but the dealer recomended 5w-40 and he said it works even though not for long he have been using it.
anyway asked today for 5w-20 not at the market so I guess I have to buy either 30 or 40 but the 0w issue, anyway I will read the link you have given me
thanks for the help
post #9 of 15 Old 08-19-2010, 07:43 AM Thread Starter
compasser
how is ow-40 gramps? I have bought this one is it ok? or? the worker said it wont harm and good in cold conditions but what you think since you use 0w-30 its not present in finland by the way
post #10 of 15 Old 08-19-2010, 09:13 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
For your cold weather 0W-30 is my first choice, 0W40 is next, followed by 5W30 and 5W40. I think it's a very good choice but that's just my opinion. I think that the cold weather start up is the most important. More damage can be done due to lack of lubrication at low temps that a heavier oil at high temps.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #11 of 15 Old 08-20-2010, 03:38 PM Thread Starter
compasser
well since the weather is getting colder now, maybe in summer time I would use another if possible but anyway saw a video by an oil company and they said that the 0w should be so good. I checked the oil myself wasnt really too heavy and if you look at the link you have given me its shown that all works with hot weather since the arrow points there am I not right?
anyway I had it done yesterday put to it 5 liters even though I have now 1cm on the meter over the safe area but I think its fine isnt it? since I have driven and no strange sound with the engine its the oposite the sound of engine is less now old oil was so black.
post #12 of 15 Old 08-20-2010, 04:37 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
You should be just fine with that.
5 liter = 5.283 quarts [US, liquid]. Very slightly over fill but while running it will go into the oil galleys. You may want to put in about a 1/4 of a liter less next time but I wouldn't worry about it this time.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #13 of 15 Old 08-20-2010, 05:54 PM Thread Starter
compasser
Ok thanks for the reply
the funny thing is that we had another rebault 1.4L and its regular engine evwn not turbo but it
takes 5L so i thought it would be impossible that a 2.4 american 4wd engine woulf take less !
post #14 of 15 Old 08-20-2010, 09:21 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
My daughters 3.9 V-6 Dakota only takes 4 qts. It is what it is, size doesn't explain it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #15 of 15 Old 08-20-2010, 11:03 PM Thread Starter
compasser
Haha yeah Iguess so
oil , oil weights , temperature
2007 Jeep Compass Windshield Replacement fourheels Jeep Compass & Patriot Forum 11 02-22-2016 06:04 PM
Check Engine Light 2007 Jeep Compass jandyrodax Jeep Compass & Patriot Forum 19 09-05-2015 05:47 AM
Chrysler announces Dodge Caliber, Jeep Compass recall 2007 models w4rh4wk Jeep Compass & Patriot Forum 8 06-29-2010 05:32 PM
2007 jeep compass suspension 10MRC Jeep Compass & Patriot Forum 4 12-15-2009 10:55 PM
Hi, I bought a new 2007 Inferno Red Compass Limited 2 days ago, yes-NEW 2007- Beware Jeep Compass & Patriot Forum 5 04-20-2009 06:40 AM
