Interior Lights/ Instrument Cluster Problem - JeepForum.com
post #1 of 3 Old 07-20-2010, 12:48 PM Thread Starter
windhamdw
I have an 07 Patriot that the interior lights have stopped working again and a buzzing sound comming from the left side of the instrument cluster. I was hoping the problem was maybe just a relay or something pretty simple. I had the same problem about 25,000 miles ago while it was under warranty so I took it in and they fixed the problem then, but now it's out of warranty.
I called them to see what they did hopping I could fix it myself, but thay told me that they had to replace the whole intrument cluster($250+labor) and to do that you have to disable the car so when you install the new cluster the orginal miles will tranfer.
Has any else had the problem or has any one else replaced their intrument cluster?
Thanks
windhamdw is offline
post #2 of 3 Old 07-20-2010, 04:19 PM
merlinTec
merlinTec's Avatar
Hi
The cluster does store the vehicle config so you can't just change it out yourself. If it's the cluster again will it not be covered under parts warranty?
It's not a common fault, you are the first I have I have heard of.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 3 Old 08-14-2010, 01:44 AM
stevephillips79
HELLO,
Vehicles often have intermittent problems with the Auto-Check system and display, as well as problems with the speedometer being intermittent. Usually these problems are caused by poor solder joints on the Instrument cluster circuit boards where the wiring connector pins are soldered to the board.
__________________________________________________ __________________________________________
Want to get-on Google's first page and loads of traffic to your website? Hire a SEO Specialist from Ocean Groups
stevephillips79 is offline
compass , guage cluster , lights , patriot
interior lights don't come on (Compass) jeepsternj Jeep Compass & Patriot Forum 3 06-20-2016 07:36 AM
Problem with lights on window switches adsaue2 Jeep Compass & Patriot Forum 25 09-01-2009 07:30 PM
Gauge Cluster Sgt_K Jeep Compass & Patriot Forum 4 05-29-2009 09:19 AM
Hit a pothole - instrument lights stay on pillzny Jeep Compass & Patriot Forum 5 05-23-2008 01:55 PM
Interior Lights safaribabe Jeep Compass & Patriot Forum 10 09-19-2007 06:39 PM
