Has anyone installed a starter on their Compass as of yet? The one i have has a whole in the side of it and pieces are falling out. After turning the car off it acted like it wanted to keep starting. I finally got it to turn off after I heard a snap. Apparently something on the starter blew a whole in the side of it. Not big just there. Anyways I haven't found anything anywhere on how to remove the old one. There is some junk in the way to get to the starter, I wasn't sure how much to remove. If anyone has some tips that would be great!
Thanks!
edit. It has the 2.4. oh and no haynes manual out yet.
REMOVAL
FIG 1
1. Open hood, raise vehicle.
2. Remove air cleaner box and air tube.
3. Disconnect and isolate the battery negative cable
4. Remove starter motor mounting bolt.
FIG 2
5. Disconnect the electrical connector at throttle body.
FIG 3
6. Remove Throttle body bolts and remove throttle body.
Fig 4
7. Push starter under intake manifold.
8. Tip starter nose toward cooling module.
9. Pull starter up and out.
Fig 5
10. Disconnect starter motor wiring.
11. Remove starter motor from vehicle.
INSTALLATION.
1. Connect starter motor wiring. Tighten battery cable nut to 10 N•m (90 in. lbs.).
2. Reinstall starter motor into vehicle lower engine compartment.
3. Loose install starter into position.
4. Install throttle body
5. Install throttle body bracket.
6. Install starter motor mounting bolts and tighten to 54 N•m (40 ft. lbs.).
7. Connect throttle body electrical connector.
8. Install air cleaner box and inlet tube.
9. Lower vehicle.
10. Connect battery negative cable.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
