On the inside of the tire -- what's this part called?? - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > On the inside of the tire -- what's this part called??
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 09-12-2014, 05:20 PM   #1
jeepHatriot
Hey, my jeep patriot has been one nightmare after another. After spending too much of my hard earned money trying to fix this beast, I've resorted to self diagnostics. However, I'm a girl that knows nothing about mechanics. It's been making the dreaded clunk noise when I come to a complete stop, accelerate from dead stop, make a hard left, and now sometimes even when there is simply a bump in the road. Out of sheer frustration, rage, and hunger, I crawled under the jeep today. I noticed on one side, this part looks normal. On the other side tho, it appears maybe a cap is missing. It's also rusted on that side. I'm posting a pic of the good side, and also of the bad side (once I cleaned the gunk off). Even if you can offer no repair wisdom, please help me identify this part. (Sorry it only let me attach one photo so I attached the "bad" side)
jeepHatriot is offline   Reply With Quote
Unread 09-12-2014, 06:01 PM   #2
222Doc
i only see 1 pic. the main part connecting the wheel and its assembly to the jeep is the lower control arm. at the bottom the shinny thing is a Zirk fitting that you use a grease gun to lubricate the lower ball joint. I do not see much rust that is of any trouble.
There are a few threads here on the trouble with the control arm bushings with these type Jeeps. From what little i have read on them it does seem to happen enough to be a pain the back. On my stuff that has Zirk fittings i grease them about every 3k miles. BUT clean the end of the zirk before greasing.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote
Unread 09-15-2014, 08:20 AM   #3
aroundincircles
1989 XJ Cherokee
This might help:
https://www.youtube.com/watch?v=_nxIiN5tt_U
ball joints are notorious for going bad on a lot of vehicles. They are not too hard to replace yourself, and are not too expensive to buy. You can buy just the ball joint or for a little more money you can buy the whole control arm with ball joint already in it.
1989 Cherokee Pioneer
http://goo.gl/h3lf9 youtube channel.
aicoffroad.com
aroundincircles is offline   Reply With Quote
