Improve CVT Response - JeepForum.com
post #1 of 1 Old 05-29-2008, 06:25 PM Thread Starter
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
Gents, I stumbled upon this on another site. It is a method to fix flat spots in the DBW system that these use and it of course helps somewhat to fix CVT response. I take no credit for this, as it was reposted by a member of the other site.
1-ignition to RUN but do not start
2-wait until all the lights go out
3-slowly depress the gas peddle to the floor (take at least 15 seconds to gradually push it to the floor, do not waver as you push)
4-slowly release gas peddle to full up (again, take at least 15 seconds to gradually let it back up, do not waver as you let up)
5-ignition to off
6-restart and check for difference in response and linearity. (Letting it sit for up to 1 hour before doing this step may help)
Let me know if this helps any of you out.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
Bad Throttle response lidhead Jeep Compass & Patriot Forum 4 01-09-2010 08:39 AM
JeepForum Survey Time! Help Improve JF! Keith Jeep Compass & Patriot Forum 0 12-04-2008 10:21 AM
