Idler Pulley Replacement - JeepForum.com
post #1 of 5 Old 06-07-2013, 07:56 PM Thread Starter
inflatus
07 Patriot Front Wheel Drive. My idler is making some noise. Will start to change it out tomorrow. Is there anything I should know to change it? This will be my first time working with a Patriot. It looks real tight in there. Any thoughts or suggestions would be greatly appreciated. Thanks.
"He who knows does not speak.
He who speaks does not know."
Lao-tzu, The Way of Lao-tzu
inflatus is offline
post #2 of 5 Old 06-07-2013, 11:38 PM
bigkat91
2011 MK Compass
There is a thread tagged in the stickie section of the forum for belt replacement. I believe coming up from the bottom might be your best betm , YMMV.
2011 Compass 120K miles
RRO Lift
bigkat91 is offline
post #3 of 5 Old 06-08-2013, 07:08 PM Thread Starter
inflatus
So I replaced the Upper Idler Pulley and Power Steering pump. Definitely take the plastic crap cover off the bottom. It will make reaching the tensioner easier when putting the belt back on. I also removed the bladder closest to the belt as well. There was enough room once all of that was out of the way.
There still is a bit of noise. Not as bad as before. Still don't know which pulley. At least if I have to replace another pulley it should go much faster.
Thanks for the help bigkat.
inflatus is offline
post #4 of 5 Old 06-08-2013, 07:20 PM
bigkat91
2011 MK Compass
No problem! Glad I could help and glad you had a successful job completed. I would have went in greater detail but I was using the forum app on my phone.
RRO Lift
bigkat91 is offline
post #5 of 5 Old 06-15-2013, 07:22 PM Thread Starter
inflatus
Altenator was the problem. Replaced it today. Was a bit difficult to remove.
inflatus is offline
