-   Jeep Compass & Patriot Forum (http://www.jeepforum.com/forum/f98/)
-   -   Idler Pulley Replacement (http://www.jeepforum.com/forum/f98/idler-pulley-replacement-1533644/)
inflatus 06-07-2013 07:56 PM
07 Patriot Front Wheel Drive. My idler is making some noise. Will start to change it out tomorrow. Is there anything I should know to change it? This will be my first time working with a Patriot. It looks real tight in there. Any thoughts or suggestions would be greatly appreciated. Thanks.
bigkat91 06-07-2013 11:38 PM
There is a thread tagged in the stickie section of the forum for belt replacement. I believe coming up from the bottom might be your best betm , YMMV.
inflatus 06-08-2013 07:08 PM
So I replaced the Upper Idler Pulley and Power Steering pump. Definitely take the plastic crap cover off the bottom. It will make reaching the tensioner easier when putting the belt back on. I also removed the bladder closest to the belt as well. There was enough room once all of that was out of the way.
There still is a bit of noise. Not as bad as before. Still don't know which pulley. At least if I have to replace another pulley it should go much faster.
Thanks for the help bigkat.
bigkat91 06-08-2013 07:20 PM
No problem! Glad I could help and glad you had a successful job completed. I would have went in greater detail but I was using the forum app on my phone.
inflatus 06-15-2013 07:22 PM
Altenator was the problem. Replaced it today. Was a bit difficult to remove.
The time now is 08:31 PM.
