How are your 18 inch Firestone's doing? - JeepForum.com
post #1 of 16 Old 08-26-2007, 06:19 PM Thread Starter
wonderment
I'd like to know how those who have the oem Firstone Firehawks experience has been with this tire. We have 22k on them and all four need replaced. They are cupped, stair stepped and the car sounds like it has four wheel bearings needing replaced, even with dealer noted rotations.
Dealer said the tires were bad, or bad compound, but they aren't warranted since they are OEM. At least my 18 inchers are not.
Wondered if this is happening to others.
wonderment is offline
post #2 of 16 Old 08-26-2007, 07:29 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Just confirming that I have the same problems with mine. They have gotten noisy and makes it sound like wheel bearing problems, too. This from my other post.
I'm needing new tires already! These Firestone Firehawk GTA-03 that come on the Limited (215/55R18) just don't get the tread life that I wanted. I really thought that they did OK threw the ice and snow last winter but I've got about 19.5 K on them and the the tread depth is down from the original 10/32" to 5/32". With the new information on "legal" tread depth of 2/32" vs the lost traction at 4/32 from this info at the TireRack, I only have about 3K miles left to go.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 16 Old 08-26-2007, 08:11 PM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
this is BAD news for all of us then. My 18" Firestones are doing alright at 11k so far, I've rotated them at 6k as recommended and am going to do it at 12k as it suggests as well. Mine is FWD so that might make a difference with me.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #4 of 16 Old 08-26-2007, 08:29 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
wonderment is also FWD, so don't hold your breath. Mine didn't get noisy like this until the last 2K or so.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 16 Old 08-26-2007, 08:42 PM
CoriolisSTORM
WHAT?!
2010 JK Wrangler
You just HAD to go and burst my bubble didn't you??? Night guys, the bed calls...
post #6 of 16 Old 08-27-2007, 11:07 AM Thread Starter
wonderment
Thanks for the reply. I believe we have about 25k on the tires. Lots of tread on the tire, but somethings certainly wrong with them. Ordered new tires this am.
Our situation sounds like gramp's...the noise factor came on very quickly at a certain mileage and is worsening very, very quickly along with enough vibration to move the steering wheel.
post #7 of 16 Old 08-27-2007, 11:38 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
wonderment,
What tires are you ordering and why?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 16 Old 08-27-2007, 11:43 AM Thread Starter
wonderment
My wife and I ordered 235/50HR-18 Continental ContiProContact's from the Tirerack.
The exact size tire replacements did not enthuse me...did not want to replicate current issues with replacing Firestone's with Firestone's. So, I did a bit of research on the size change, and went with these. We have had good experience with the Conti's in the past on our Audi TT.
Wanted an all season tire, too...so that's what we picked...for better or worse. We're not tire experts, but do rely on what the tirerack says will work. We are 3 or 4 time purchasers from there. My wife and I each drive 1.5 hours to our jobs. In different directions. She heads north, I go south.
post #9 of 16 Old 08-27-2007, 01:15 PM
BuzzDog
It will be interesting to see if this wear issue also extends to the Firestone Affinity tires that are mounted to vehicles with 17-inch rims. I only have 10,700 miles on mine, so it's too soon for me to to tell if they're wearing any faster than usual.
As for the noise that is showing up as the Firehawks wear: My brother-in-law is an independent tire dealer, and I recall that when these tires came out there was quite a bit of hoopla over the fact that the tread is designed to reduce noise. When I bought a set as replacements for my Maxima, I wondered how this would work as the tread blocks wore down. This may be our answer...perhaps it doesn't work as the tread wears down?
BuzzDog is offline
post #10 of 16 Old 08-27-2007, 02:37 PM Thread Starter
wonderment
Buzzdog,
They "were" quiet when new. The car was very quiet and we commented and liked how quiet the vehicle was. I'm not exactly sure at what point that ended (my wife drives the car to work) but when I got in one day...wow...big, big change.
We just had our street paved with new black asphalt, and when driving 5-10mph the noise is extremely loud. I may put a SPL meter in the car to see what the reading is.
post #11 of 16 Old 08-27-2007, 06:03 PM
BuzzDog
Exactly. What I'm thinking is that as the tread blocks wear down, their shape changes...and there goes your "special tread pattern, scientifically designed to reduce tread noise" (my words in quotes, not Firestone's).
BuzzDog is offline
post #12 of 16 Old 09-10-2007, 10:28 AM Thread Starter
wonderment
An update on our Tire Saga. Bought the new replacement tires, Continental Contacts. Local Jeep Dealer balanced the tires. Next day, off to work on the highway and got all sorts of vibration. Now steering wheel vibrates too. Called dealer after getting to work. They said perhaps some weights flew off. I checked and two of the tires did not have any weight balancing weights on them. Hard to get back to jeep dealer, so I stopped in Indy at a Firestone dealer to have the two tires rebalanced.
Got called into the shop and they told me at least one of my new continentals were "not round." I saw the wheel moving up and down on the balancer. So, I figure I need at least one new replacement from the tire I just purchased.
Now getting really tired of all this mess, I decided to drive up to the Tire rack and have them fix all this mess. (3 hour trip)
They determine that the tires are not at fault or out of round...it is all four of the original RIMS that are out of round. So, I have their paperwork, Firestone's paperwork, the initial Jeep dealers paper work and have an appt on Wed eve to have them determine if Jeep will replace all four rims.
If it is indeed out of round rims, that may be the culprit in the Firestones wearing so quickly and strangely. I hope this ends it.
post #13 of 16 Old 09-10-2007, 11:49 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
My wear is even, no cupping, just faster than I would like and more noisy than when new. It is only a 30K tire so I'm not expecting any more than about 25K which they could probably go. I'll watch for the out of round when I go to get mine replaced.
It shouldn't make a difference but do you have the standard wheels or the chrome?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #14 of 16 Old 09-10-2007, 12:15 PM Thread Starter
wonderment
We have the chrome rims.
post #15 of 16 Old 09-17-2007, 12:24 PM Thread Starter
wonderment
Thought I'd post a resolution to our issue....I took Jeep back to dealer, armed with paperwork from a variety of the places I went to including the Tirerack. Jeep service dept sent my concern to a different level of service within Jeep. All of my rims will be replaced by Jeep due to all being out of round.
They are being ordered today. I am assuming this will fix things.
