How to know if my trans has low gear - JeepForum.com
post #1 of 11 Old 03-23-2013, 05:50 AM Thread Starter
Sperron
2007 MK Compass
Hi,
I own a compass 2007 (2.4 L). I'm calling some junkyards for a used transmission (because mine is already dead, after 35 000 miles) and they ask if my transmission is with or without low gear. How do I know that? Of course I have a "D" and a "L" on the gear selector. Is that it ? The shops I have called all have trans without low gear.
Thanks
Sperron is offline
post #2 of 11 Old 03-23-2013, 06:36 AM
aroundincircles
1989 XJ Cherokee
It says Off road next to L.
89 Cherokee
aroundincircles is offline
post #3 of 11 Old 03-24-2013, 05:46 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
'07 Compasses did not have an Off-Road mode, but there was either an 'L' on the shift bezel or a '+ / -' by the 'D' if you had a Autostick.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 11 Old 03-24-2013, 06:47 AM Thread Starter
Sperron
2007 MK Compass
So, if there is a "L" on the shift bezel, it means I'm looking for a transmission with low gear? Does it mean that these transmissions without low gear don't offer "L" on the shift selector?
thanks
Sperron is offline
post #5 of 11 Old 03-24-2013, 08:12 AM
aroundincircles
1989 XJ Cherokee
Sorry didn't read that he mentioned the compass specifically. Compass didn't have the FDII package till 2011 I believe. L just puts it into a the lower gear range (what putting it into 2nd or 3rd on a regular automatic) you would be looking for a patriot of that age for one that says Off Road next to the L on the shifter. I think for 2007 they did not have the auto shift, so it just has an L, but no off road next to it.
The transmissions are the same between a FWD/FDI/FDII, but the FDII has a lower final drive. its not really a low gear like you would find in a traditional 4x4, its just the overall gear ratios are lower (hence the lower mpg's)
basically you do NOT have the low gear, so they have the correct trans.
89 Cherokee
post #6 of 11 Old 03-25-2013, 06:02 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Correct. There will be a stamping on the case that says "CVT-2' and that was used in all FWD and FD I packages. The FD II version is stamped "CVT-2L" and has the lower transaxle ratio. The 'gears' on the transmission section are all the same, it's the final drive on the 'Axle' section that actually makes it an 'L' and the splines are different and they do not interchange. The Compass didn't have the FD II until 2011.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 11 Old 03-25-2013, 02:00 PM Thread Starter
Sperron
2007 MK Compass
Thanks Guys, everything is clear now.
I just bought a trans with 40k on it for 900$ Can. Next step will be to put it in the car.
Sperron is offline
post #8 of 11 Old 03-26-2013, 06:10 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Good luck and I hope that you have a warm garage! Let us know how it goes.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #9 of 11 Old 03-26-2013, 07:01 AM Thread Starter
Sperron
2007 MK Compass
Haha! Unfortunately, I work in Good Lord's garage. It's too cold right now (and snowy), so the plan is to do it in June. My old trans is noisy but still working. I'll post some updates when I do it. And I may ask again for some help!
Thanks again.
Sperron is offline
post #10 of 11 Old 03-26-2013, 09:33 AM
IRSmart
2015 KL Cherokee
fixed for ya gramps they gave the compass FD-II with the 2011 redesign.
IRSmart is offline
post #11 of 11 Old 03-26-2013, 06:46 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Thx IRSmart. I wasn't sure but I new it wasn't '07!!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
