How to hook up a vacuum gauge? - JeepForum.com
post #1 of 19 Old 11-24-2008, 11:01 PM Thread Starter
horsey2k
I was wondering how to hook up a vacuum gauge? The instruction said I needed to connect the vacuum sensor to any constant vacuum source? Could anybody tell me where to cut the hose to put a T-fitting in? Could you tell me the detail location? thank you!
horsey2k is offline
post #2 of 19 Old 11-25-2008, 12:15 AM
Bigbob
Bigbob's Avatar
Brake booster works well if you have the right size tee. Basically any hose coming off the intake manifold has a constant vacuum.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #3 of 19 Old 11-25-2008, 05:48 PM Thread Starter
horsey2k
I don't know much about cars, would you tell me the specific location. Is there any quarter inch constant vacuum lines? thank you!
horsey2k is offline
post #4 of 19 Old 11-26-2008, 07:20 AM
schoat333
2008 MK Patriot
being that you dont have a real good understanding of cars, i would say to see if you could have someone help you with it. the brake boosters vacuum line is probably 5/16" or 3/8"' hose, so you would need vacuum adapters.
schoat333 is offline
post #5 of 19 Old 11-26-2008, 12:45 PM
ChvyKc
2006 XK Commander
Any hose on the motor after the throttle body is fine. The throttle body is the very first thing after the intake.
-ChvyKc
'06 XK 3.7L (Stock for now)
'07 WK HEMI Limited (Wife's)
ChvyKc is offline
post #6 of 19 Old 11-26-2008, 05:38 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It's dark when I leave and dark when I get home. I'll try and take a picture of a likely victim this week end.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 19 Old 11-26-2008, 05:56 PM Thread Starter
horsey2k
thank you for all you guys
horsey2k is offline
post #8 of 19 Old 11-27-2008, 03:46 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The victim
Pull off the engine cover (if you have one) by just lifting straight up. Some people like to take out the dip stick and take off the oil filler cap but you don't have to.
The brake booster is below the master cylinder and you can see the check valve that is circled in all of the shots. This vacuum hose is the one with the woven braiding around, it runs all the way from the booster up to the front of the engine and then down in front and under the plastic runners from the intake manifold. A common I.D for the hose is 11/32" but you'll need to check the size for yourself. Get a "T" that's the correct size to connect the hose back together after you cut it and tap off for your auxiliary hose. Something like a 3/8 x 3/8 x 1/4. I don't think that "T's" are made in 11/32, you'll just have to push harder to get the hose on. You can cut it where ever it's convenient, just leave yourself some working room.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #9 of 19 Old 11-29-2008, 06:06 PM Thread Starter
horsey2k
Thanks for the pictures, very helpful.
horsey2k is offline
post #10 of 19 Old 12-03-2008, 11:42 AM
nick8387
2008 MK Compass
im also considering putting in a vacuum gauge, the only thing holding me back is actually mounting the gauge in the car. does anyone have any suggestions, i was thinking of finding someone to fiberglass one at an audio shop.
nick8387 is offline
post #11 of 19 Old 12-04-2008, 01:44 AM Thread Starter
horsey2k
I bought a Glowshift Elite series vacuum gauge, it's electrical gauge, so you dont need to run a electrical wire though the firewall, not the vacuum hose.
you can check www.glowshift.com,
it also comes with a gauge pod. it looks great on my compass, I will take some pictures someday this week.
horsey2k is offline
post #12 of 19 Old 12-04-2008, 09:38 AM
nick8387
2008 MK Compass
i just ordered the glowshift tinted 7 color series with the universal swivel pod. where did you hook up all your electrical connections.
nick8387 is offline
post #13 of 19 Old 12-04-2008, 01:13 PM Thread Starter
horsey2k
tap red wire to switch ignition wire, and black wire to ground. then put a tee connector to the brake booster vacuum hose. the vacuum hose is on the right hand side of the engine, you can see "vacuum" printed on that hose. very easy to find it.
horsey2k is offline
post #14 of 19 Old 12-05-2008, 12:51 PM
nick8387
2008 MK Compass
do you have any pics of your gauge so we can see what it looks like
nick8387 is offline
post #15 of 19 Old 12-09-2008, 01:31 AM Thread Starter
horsey2k
horsey2k is offline
Gauge Cluster Sgt_K Jeep Compass & Patriot Forum 4 05-29-2009 10:19 AM
where is the vacuum line on intake manifold ? horsey2k Jeep Compass & Patriot Forum 3 11-20-2008 07:54 AM
question about hook OxyG3nE Jeep Compass & Patriot Forum 1 10-20-2008 02:08 PM
Anyone Know Where to Hook up the MP3 player in the compass joeydominick Jeep Compass & Patriot Forum 4 03-30-2008 10:34 PM
Temp. Gauge Chriztofor Jeep Compass & Patriot Forum 9 01-26-2008 05:58 AM
