Honest opinion on a few items - JeepForum.com
post #1 of 10 Old 07-25-2013, 08:56 AM Thread Starter
ezzymo1024
So I've got a 2007 Compass sport; FWD, 2.4 L; 5-speed box.
As it stands, it needs a few thousand worth of work done; struts front and back, tie rods, brakes front and back, and probably other front suspension components as well. Not mentioning tires because those are regular wear items.
Stupidly, I bought it used last year and because I was in a pretty tight spot financially I took out a loan on it.
I like the idea of taking my Compass off-road on some old logging roads and tracks at my families cottage, as Iíve done that already with someone elses, and a few JK Wranglers as well.
So my questions: should I keep it and make the necessary repairs? Would you trade it in against a newer 4wd Compass/Patriot with the Offroad II and use that as a starting point?
Iím only asking because I also want the Rocky Road suspension lift (or something as good), but Iím not entirely certain itís worth having on a front-wheel-drive Compass.
ezzymo1024 is offline
post #2 of 10 Old 07-25-2013, 09:10 AM
jacko15
2014 WK
I really can't see any reason to keep it with the type of driving you want to do. Look at a Patriot if you want to go off road, and definitely go 4x4. I don't know your financial situation, but dumping a ton of dough in a fwd Compass to off-road just doesn't make any sense to me. The patriot can be equipped with the trail rated package, but the Compass doesn't have the clearance without mods to hit the same trails. Of course this is just my personal opinion. We love our '08 Compass, and have had it off road with no problems, but it is 4x4.
Mine: 2014 Jeep Grand Cherokee Overland V/6
ORA II
Hers: 2017 Jeep Compass Latitude 4x4
jacko15 is offline
post #3 of 10 Old 07-25-2013, 12:41 PM Thread Starter
ezzymo1024
@jacko15 - I'm having similar thoughts, to say the least. Maybe I'll wait and pick up one of the last few 2014 Patriots. I'm sure when people see the replacement for the Pat-pass, the 2014 Patriots/Compass' will simply languish on dealer lots.
post #4 of 10 Old 07-25-2013, 01:17 PM
Lehman26
2012 MK Compass
You can get a compass with off road package. I have it. Same set up as the patriot.
Lehman26 is offline
post #5 of 10 Old 07-25-2013, 01:18 PM
Lehman26
2012 MK Compass
*meant trail rated package...1" higher, tow hooks, 140 amp salt, DRLs, Goodyear wranglers, low range, etc. Fd2 compass's are out there just gotta look
Lehman26 is offline
post #6 of 10 Old 07-25-2013, 07:16 PM Thread Starter
ezzymo1024
You're right. Compass/Patriot with FDII are rare though. Most I've seen stop short of that option.
post #7 of 10 Old 07-25-2013, 07:32 PM
aroundincircles
1989 XJ Cherokee
If you plan on actually going off road, its worth it, as you will always wish you had the extra capability.
89 Cherokee
aroundincircles is offline
post #8 of 10 Old 07-25-2013, 07:49 PM Thread Starter
ezzymo1024
Completely agree. If I don't find an excellent used example I'm buying a new 2014.
post #9 of 10 Old 07-25-2013, 08:07 PM
Lehman26
2012 MK Compass
Yea they definitely are pretty rare I settled for mine in silver with the options it had BC there were no others anywhere near. Would of preferred black but couldn't find one.
Lehman26 is offline
post #10 of 10 Old 07-26-2013, 07:46 PM
Sarkus
FWIW, the newer Patriots (2011 and newer) have the same clearance no matter if they are FD1 or FD2. What you gain with the "Trail Rated" version is the low gearing, underside protection, etc but you pay for that in notably worse fuel economy. The FD1 Patriot, even the pre-'11 version, is still a reasonably capable off roader as well. No stock Patriot (or Compass) is going to compare to a Wrangler or a modded vehicle for off-roading, though. So it depends on how much capability you want and what else the vehicle needs to do on a regular basis.
Sarkus is offline
