High Speed Shake/ Outer Tire Wear - JeepForum.com
post #1 of 6 Old 06-01-2012, 03:45 PM Thread Starter
EmPat
Hi everyone, I'm new here and have a couple questions about my sister in laws 08 Patriot. I don't know much, other that what she has told me, which is as follows:
She says at highway speeds, the vehicle shakes pretty bad, and she's gone through 2 sets of front tires in the past year. It drives straight with no pull to either side, yet the front tires are wearing on the outer edges. She also says she hears "noise from the tires". The Jeep garage gave her a ridiculous estimate, and said she needs control arms, ball joints, wheel bearings(front and back), and a few other things that I can't remember.
I'm most concerned with the shaking at highway speeds. I've been told by others that bad tie rods will cause shaking at higher speeds, and ball joints could cause the outer edge wear on the tires?? Also, the "tire noise" she hears, I'm guessing is wheel bearings? I'm new to "new" vehicles, and was just looking for advice before I start ripping it apart. I haven't had the chance to drive it myself yet, so I'm not 100% on what exactly its doing. I hope to check it out tonight. Any advice on common issues with the Patriot's would be greatly appreciated. Thanks
EmPat is offline
post #2 of 6 Old 06-01-2012, 04:42 PM
festerw
festerw's Avatar
Ball joints will for sure cause abnormal tire wear.
Ball joints are a common issue in the Patriot/Compass line and dealer wise they will replace the entire control arm. Moog makes replacement ball joints to cut the cost on a DIY repair.
It is possible the bad ball joints caused premature wear on the tie rods and wheel bearings.
Unfortunately the Patriot is a nice vehicle with a terrible quality suspension.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #3 of 6 Old 06-01-2012, 05:34 PM Thread Starter
EmPat
Thanks for the info...how hard is the diy balljoint job? I've done uppers and lowers on older vehicles, but never anything this new. Anyone maybe have a diagram of the job? Thanks again
EmPat is offline
post #4 of 6 Old 06-01-2012, 07:30 PM
festerw
festerw's Avatar
It's not bad, jack up and support the whole front end, remove wheels, disconnect the lower sway bar bolt, unbolt the ball joint pinch bolt, remove the LCA bolts, pry out the ball joint. Be aware that you could pull out the cv shaft accidentally, it will slide right back in. To avoid this you could rent a spring compressor and compress the springs slightly to take the load off.
Rent the ball joint press and you'll need a set of snap ring pliers to secure the new joint and a socket or pvc pipe length large enough to press on the dust covers. Not an overly hard job but time consuming, I would recommend replacing the sway bar links and bushing while you're in there too and of course get an alignment done soon afterwards.
festerw is offline
post #5 of 6 Old 06-02-2012, 06:45 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
There are some DYI guides here: http://www.jeepforum.com/forum/f98/q...5/#post6282244
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 6 Old 06-02-2012, 05:14 PM Thread Starter
EmPat
Thanks guys. Hopefully I'll be able to get to it this weekend sometime. She works ALOT so who knows. Thanks again
EmPat is offline
inner and outer tie rod torque #s please ronjr8102 Jeep Compass & Patriot Forum 5 02-04-2012 09:53 AM
2010 Patriot Rear tire wear/cupping tyler711 Jeep Compass & Patriot Forum 1 09-11-2011 03:18 PM
OUTER TIE ROD END R&R Gramps Jeep Compass & Patriot Forum 0 05-21-2011 08:07 AM
Shake in steering wheel on deceleration Argent33 Jeep Compass & Patriot Forum 8 07-22-2010 06:14 AM
Uneven tire wear eshew Jeep Compass & Patriot Forum 2 05-30-2010 11:10 AM
