High Pitched Whistle/Whine At 30mph - JeepForum.com
post #1 of 26 Old 10-11-2011, 03:06 PM Thread Starter
bill-pat
I get a high pitched whine when I hit 30 mph.
It only whines when it is under load.
As soon as I take my foot off the gas the whine goes away but comes back as soon as I start to accelerate again.
I am driving a 2007 Patriot Sport with 44,000 miles on it (70,000kms)
Anyone have any idea what it could be?
Any information is much appreciated.
Thanks in advance.
bill-pat is offline
post #2 of 26 Old 10-12-2011, 10:56 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
CVT, 5 Speed, front, rear, engine compartment, vacumm leak? Sorry, not enough info.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 26 Old 10-13-2011, 08:44 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Also check the serpentine belt http://www.jeepforum.com/forum/f98/s...moval-1020484/ if that the area the noise is coming from.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 26 Old 10-13-2011, 01:24 PM Thread Starter
bill-pat
Sorry for the long delay in responding.
It's a CVT and the noise appears to be coming from under the center of the jeep.
It a bit intermittent.
I checked the oil in the PTU and the RDA and they are filled properly.
I also check the CVT and it is within it's baseline measurements as I established about a year ago.
There is no driveline lash either.
The belts seem to be fine on inspection and deflect properly. When I put it in neutral and rev it high I get no unusually noises.
I am thinking it may be somethings up with the tires.
How do I check for vacuum leaks?
Thanks for answering
bill-pat is offline
post #5 of 26 Old 10-13-2011, 03:13 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Vacuum leaks will normally be a constant whistling sound. You can spray around hose fittings/connections with carb clears that will seal them and you'll normally pick up some RPM when they seal up.
In reality, I don't think that's your problem with it being intermittent, but I am at a loss for ideas.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 26 Old 10-13-2011, 07:49 PM Thread Starter
bill-pat
Hey Gramps
Thanks for the input.
I'm going to check out the hoses and fittings and clean them up a bit with some throttle body cleaner I have.
Maybe that will help.
Thanks again.
bill-pat is offline
post #7 of 26 Old 10-13-2011, 09:29 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Let me throw out one more (I hate to give up). Maybe it's an air intake or air movement just the other side of the firewall from the air filter cover or engine cover? Fan speed, road speed, harmonics just at the right time to produce that noise?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 26 Old 10-13-2011, 10:33 PM
Atlas
Junior Member
Atlas's Avatar
2010 JK Wrangler
Could be transmission whine, change the tranny fluid lately? If you haven't, may want to...if you have, they may have put the wrong kind in.
Upgrades: 33" Mountaincats, Rocksliders
"Sometimes I think this is all just a dream but then I remember my dreams always have Tom Selleck in them." - Keith
Atlas is offline
post #9 of 26 Old 10-16-2012, 11:15 PM Thread Starter
bill-pat
Sorry for bumping such an old thread.....
I just want to post the resolution to this "High Pitched Whistle/Whine At 30mph"
And the winner is.....
PREMATURE CVT FAILURE (like all the rest of 'em)
Had it replaced under guarantee.
After it was replaced my transfer case was leaking like a sieve.
Turns out the dealer techs broke the seals on the outer transfer case cover and I had to go back and have that replaced a few weeks later.
The entire cover was replaced along with the seals.
When you get work done at the dealership drop that skid plate and looks for leaks and shoddy workmanship.
Remember, the dealer has no vested interest in fixing your car properly.
bill-pat is offline
post #10 of 26 Old 10-17-2012, 07:37 AM
mmdambro
2008 MK Patriot
I'm already tired of my CVT
mmdambro is offline
post #11 of 26 Old 10-17-2012, 10:37 AM
FujativeOCR
2011 MK Patriot
^they are headache inducing
FujativeOCR is offline
post #12 of 26 Old 10-17-2012, 11:34 AM
FujativeOCR
2011 MK Patriot
It's amazing how many of these fail with so few miles. And to think they don't even suggest changing the oil until 60+k and only if used under extreme conditions.
post #13 of 26 Old 10-17-2012, 05:10 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The CVT troubles just started happening of late. Much more than the earlier days but then they just started getting the mileage on them. For the brief 3 weeks that I worked at a dealership the head guy who worked on these said that the fluid change really wasn't necessary. It certainly does sound like cheep insurance.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #14 of 26 Old 10-17-2012, 05:14 PM
FujativeOCR
2011 MK Patriot
I wonder if the CVT2L will be more prone to failure than the standard. Since it spins faster 100% of the time.
post #15 of 26 Old 10-17-2012, 05:31 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
For the same mileage the FD II will have put on more engine, transaxle revolutions than the FD I. Could it be more prone to 'early life failure' I'd say yes. Or at least a shorter life expectancy, it does make sence.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
High Mileage/General update cuemark8 Jeep Compass & Patriot Forum 44 05-14-2016 02:46 PM
K&N AirCharger High-Flow Intake/Cold Air Intake - Merged compassjeep Jeep Compass & Patriot Forum 114 09-14-2012 03:41 PM
Manual Transmission Whine iamrone Jeep Compass & Patriot Forum 3 04-06-2011 08:40 PM
annoying whine in drive train 68-72 mph airic Jeep Compass & Patriot Forum 1 11-14-2008 05:53 PM
High Beams on Patriot seem underpowered? Dr. Grinch Jeep Compass & Patriot Forum 3 01-29-2008 04:25 AM
