High Mileage/General update - JeepForum.com
post #1 of 45 Old 03-14-2010, 02:40 PM Thread Starter
cuemark8
2007 MK Compass
Hi you all! Been awhile since last here.
Ok a mileage update. The Compass is still running flawlessly. I just turned 115,000 mi! I do all the maintainance by the book. At 90,000mi I installed a new air filter and changed the fluids. At 100,000 mi I had the engine coolant changed and flushed. I also had the transmission fluid changed that was the first time for that. My Compass is a manual.
In some previous post I changed the factory spark plugs at 30,000mi and replaced them with NGK Iridium plugs. At 100,000 mi while doing the other service I removed just one spark plug just to check them. It looked good as new.
I have had no problems with my Compass, like it said I maintain my vehicles well. I will try to keep a watch on this thread and post back. Later this week I am replacing the front brakes. I never replaced the brakes yet! I had it looked at and an estimate done. I need new pads in the front, my rotors are slightly warped. They are still within spec and can be machined or I may just replace them. Not sure yet what to do. The rear pads and rotors are still ok.
To Gramps, I'm not sure how you wish to post this thread. I know I have rediculous mileage for my vehicle. If others wish to ask questions about my vehicle care or maintainance I will try to stay tuned to this site and respond to posts. I will try to help in any way. Thank you all!
FYI: 2007 Compass Limited
FWD
5-speed manual
225/60/18 tires on factory wheels
Had K&N air charged, bur removed it (to noisy) now stock again
all factory options except the 4WD and CVT
cuemark8 is offline
post #2 of 45 Old 03-14-2010, 03:42 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Congrats on the good maintenance that you've done to get over 100K!!
It's up to you what you want to do with the tread, I'm here to help, not dictate. I can say from experience that a sticky will get over looked but instead recommend that we put a link in the "Quick Links" threads for easy reference and add others as they come up.
Here's the brake thread if you want to try it yourself, they aren't very hard. http://www.jeepforum.com/forum/f98/brake-job-548958/ I tried to shop for some parts but prices are all over the board. I run in to "loaded caliper, simi-loaded calipers, remanufactured, etc. If you have a place that can turn the rotors that would be the cheapest way to go; new fronts are between $50 - 55 ea; the rears are $32 - 44 ea. The good news in my search is the the hubs and bearings are now available aftermarket.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 45 Old 03-15-2010, 10:35 PM
parajeep
2007 MK Compass
Brakes
If just doing the brake pads, is it necessary to disconnect the battery? I don't want to mess up any sensors.
parajeep is offline
post #4 of 45 Old 03-15-2010, 10:50 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I never have on any other brake job that I've done but then I've never had this much electronics before. Even though I can't think of anything that would get damaged, since it's not powered up, I would disconnect the battery just to be on the safe side and its so easy to do.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 45 Old 03-17-2010, 10:53 PM
fortuneer
fortuneer's Avatar
2007 MK Compass
What is your secret to break life??? In my twenty-six years of driving, I've never EVER had break pads last longer than 30,000-35,000 miles! When I home delivered news papers, I was replacing my front pads every 5,000 miles (on other vehicles). Under more "normal" driving conditions, I usually get the above mentioned mileage. My Compass has just over 31,000 on the clock and I'm already detecting a decrease in breaking performance indicating worn pads. I don't ride my breaks and usually use the engine to help slow down before actually pressing my break pedal. How do you get such life from your breaks???
"There's gold in them hills" (and I'm still stuck in Florida!) ...well, in south Miss now, lol
Black '07 Compass Sport 5-speed 4X4 ("Fortuneer"), K&N filter, cat-back exhaust; RR lift, sunroof, trailer tow group, Boston Acoustic audio, sport bars, rear taillight guards, more to come... Finally got it back from the wife so I can let my Neon R/T rest for a rebuild.
fortuneer is offline
post #6 of 45 Old 03-18-2010, 07:55 AM Thread Starter
cuemark8
2007 MK Compass
Secret to brake life
Secret to brake life can involve many factors but in opinion about 3 huge factors.They are:
1: Most of my driving is all highway miles and very little city traffic. Stop and go traffic kills brake life.
2: Oddly my vehicle is a 5speed manual, better fuel mileage way better brake life. Just like OTR truckers downshifting will braking and slowing or downshifting while decending hills saves brakes greatly! Let the compression of the engine hold the vehicle back!
3: Added vehicle weight. Lose the junk in the trunk! Any extra equipment, parts, people, tools all add weight to the vehicle. Any extra weight thats just more the engine has to overcome to get moving and thats just more the brakes have to overcome to stop.
As a note this vehicle is front wheel drive and frankly thats wears the front brakes more in my opinion. Most brake stopping power is on the front wheels and front wheel drive makes that worse compared to a weight balanced RWD vehicle. I got 115,000mi miles of wear on my front brakes and I am somewhat disappointed. I actually thought I could do better than that considering it is 4 wheel disc brake. I had a Ford Mustang prior to this if I remenber correctly I changed the front brakes around 160,000mi. I traded the car at 213,000mi having never changed the rear brake pads. I bought it brand new in 2001 traded it on the Compass!
cuemark8 is offline
post #7 of 45 Old 03-21-2010, 07:40 AM
cactus_jack
FWD
5-speed manual
you have 115k and have NEVER EVER replaced the brakes????? I was wondering when mine were going to go out, its been 39k now. Ill let them ride out until the indicators start squeeling!
CACTUS_JACK
98 XJ Sport Budget Build
cactus_jack is offline
post #8 of 45 Old 03-21-2010, 04:15 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
My daughter got 95K or so out of her Dakota and she's still on the original clutch at 115K. I taught her how to drive but she is very gentle on her stuff any way. I've got 55K on mine and I'll be looking at them this summer. I was just in the shop for LBJ/tie rods/tire rotation and the dealer made no mention of the brakes being down.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #9 of 45 Old 03-22-2010, 12:42 AM Thread Starter
cuemark8
2007 MK Compass
Yes, I got 115K out of the brake pads. It's all highway driving they just don't get used. I just replaced them at the dealer I get most of my work done at. I spent the extra money ane replaced the rotors rather than just get them cut down. They just don't seem to last after machining them.
I've driven a manual since I was 16. I never replaced a clutch, ever. My last two vehicles had over 200K when traded in.
cuemark8 is offline
post #10 of 45 Old 03-22-2010, 10:39 AM
howdy246
2008 MK Compass
My Compass just turn 60,000kms and I was thinking about the brakes also so I checked out some prices on the net. I would go with new rotors instead of getting them turned. If they are warped a bit now then they will warp again even faster.
howdy246 is offline
post #11 of 45 Old 05-12-2010, 06:40 PM
spencernj
My 08 UK Diesel has just done 60k miles. So far only items replaced are tyres at 50k other than normal service items. No brakes yet.
Current: 1998 XJ 4.0 Ltd Grey/Blue, 2008
Past: 1998 XJ 4.0 Ltd Green, 2005 Grand Cherokee Ltd Black, Patriot 2.0 CRD Ltd Silver
spencernj is offline
post #12 of 45 Old 05-12-2010, 08:18 PM
cactus_jack
if anybody happens to need brakes anytime soon make sure you buy the NAPA Adaptive One pads! They're $15 off with a mail in rebate and it will help out your local NAPA parts man! (We are getting commission on every set we sell this month!) Sorry for advertising but I must say, they are great brake pads
CACTUS_JACK
post #13 of 45 Old 05-12-2010, 09:14 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I got my email notice on that last week and it's good until the 30th. Gonna need 'em sometime but since when do counter guys get a commission? Things have changed since '70's!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #14 of 45 Old 05-13-2010, 08:14 AM
cactus_jack
Im not sure about every other chain, but our chain of 4 stores gives 5 dollars to each counterperson for each set of ADO pads sold. And then at the end of the month, each store gives some sort of prize to the guy who sold the most. Pretty good deal I'd say, but in my poor little town everybody wants the Tru-Stops. I've only sold one pair of ADOs since the 1st of the month
CACTUS_JACK
post #15 of 45 Old 12-13-2010, 11:15 AM
Finallyajeep
Sorry to hijack this thread but I am curious how many miles you guys have on your compass'? This is for my dad who has a 2008 compass with around 150k on the clock.
Firefighters Jeep Club
Finallyajeep is offline
compass , high mileage , patriot
General Questions about the Compass MsIrisMG Jeep Compass & Patriot Forum 6 01-25-2009 11:18 AM
General question regarding TSB's... Zappy Jeep Compass & Patriot Forum 1 09-20-2008 05:37 PM
Update to "Interior Update"...RE: Plastech Brankruptcy unclejjg Jeep Compass & Patriot Forum 2 02-04-2008 08:38 PM
General likes and dislikes -Compass BeerMonkeY Jeep Compass & Patriot Forum 18 01-17-2008 10:11 AM
Patriot Build and Price update Gramps Jeep Compass & Patriot Forum 1 03-02-2007 02:51 AM
