Hey fellas, not a lot of talk on the forum lately so..... - Page 2 - JeepForum.com
post #16 of 20 Old 01-18-2011, 05:54 PM Thread Starter
armystrong68w
2008 MK Patriot
So what would the pros and cons be with the coils and the springs? If i bought bigger springs would i need bigger shocks?
****Before i had a jeep I didnt know why you guys parked in snow banks and made sure to hit puddles and mud but now i understand....It really is a Jeep thing!!!!!****
armystrong68w is offline
post #17 of 20 Old 01-19-2011, 06:25 AM
TheHeilis
There are no upgrades made as of yet for the struts (shocks). With the spring upgrade you just change the existing coil spring in the factory strut with the new spring (you need a strut compressor tool to do this). Some upward travel in the strut is lost but people that have the springs seem satisfied. They have said that it has been fine on the road and the vehicle handles quite well and even better than stock.
The spacer lift (RRO lift) uses metal spacers that fit between the strut and the body. The strut remains in it's stock configuration and just "raised up" the desired amont by the spacer being used. Just like a "budget boost" is used on a Jeep Wrangler. pretty simple to do. I would recomend an alignment after either of these lifts were installed.
Either of these will lift the vehicle and add the ground clearence that is desired. They both work and help for the off roading of one of these type vehicles. Not to mention it makes them look how they should have come from the factory in the first place. The decision comes down to what you want. Look at both and see what fits your budget and needs.
2002 Wrangler Sahara, 2008 Patriot FDI
Member of Northwest Indiana Jeepers
White Jeep Club Member #117
TheHeilis is offline
post #18 of 20 Old 01-19-2011, 06:32 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Pros - some dealers will still cover the warranty, sway bar extensions not necessary, better ride (subjective opinion).
Cons - more expensive to buy, installation a little more difficult (spring compressor required and knowing how to use it safely).
The springs have a different spring rate and are made of a new high tech steel, new shocks not required. This setup just doesn't "bottom out" as low as the stock suspension.
(Good morning TheHeilis - responding at the same time, I see. )
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #19 of 20 Old 01-19-2011, 07:31 AM Thread Starter
armystrong68w
2008 MK Patriot
Thanks guys, thats exactly what i wanted to know!
Well i guess ill have to go with the spacer option, because i do not have a coil compressor! Could you guys guess the shop cost of the coil install?
post #20 of 20 Old 01-19-2011, 07:42 AM
TheHeilis
No idea, but it would pricey. If you know a mechanic or someone that is able to do the job that would be your best bet. I think you can a rent strut tool but you should know what you are doing since you will be working with compressed coil springs.
Here is a link to the spacer lift:
http://www.rocky-road.com/patriotsus.html
Oh and Morining Gramps .
exhaust , kit , lift , photos
Mercedes Benz Forum JF_Admin Jeep Compass & Patriot Forum 0 05-27-2010 06:58 PM
Our poor forum cactus_jack Jeep Compass & Patriot Forum 32 01-15-2010 04:53 PM
New Too forum sayin hi tourotsArrago Jeep Compass & Patriot Forum 1 12-31-2008 05:33 PM
