Help with running Sirius extension cable - JeepForum.com
post #1 of 3 Old 07-16-2009, 12:04 PM Thread Starter
Huzzah
Hello, I'm about to upgrade my 2007 Jeep Compass from the factory installed REC stereo to a MyGig. I need to install a new cable from the Sirius antenna as the connectors are different. Can anybody tell me how to do this?
I'm assuming that the Sirius tuner is built into my stereo so the cable goes directly from the antenna to the stereo? If this is the case I suppose I need to get access above the headliner? I found two plastic connectors near the back of the headliner, do I have to remove them?
Any guidance would be greatly appreciated.
Thanks,
Steve
Huzzah is offline
post #2 of 3 Old 07-16-2009, 05:52 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The satellite Receiver in mounted in front of the spare tire. (Fig 1).
The satellite radio antenna is secured by adhesive foam and retainers which protrude through a hole in the roof panel. Two wires from the antenna are connected to the body harness above the headliner.
The satellite radio antenna receives signals from orbiting satellites and sends these signals to the satellite receiver module. The satellite radio antenna must have open space in which to operate. Items carried on the roof, parking inside etc. can have an effect on the antenna's ability to receive signals.
INSTALLATION
(disconnect battery)
1. If original antenna is being reinstalled, remove backing from patch adhesive (2) and apply to antenna base (1).
2. Remove backing from the adhesive on the antenna.
3. Insert wire harness through hole in roof panel. Press antenna into position until both retainers snap into place.
4. Connect wire harness connectors to antenna.
5. Install headliner
6. Connect battery negative cable.
I know nothing about the Mygig. maybe someone else can fill you in.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 3 Old 07-16-2009, 07:14 PM Thread Starter
Huzzah
Awesome, thanks! I actually just got in from installing the MyGig, including routing the Sirius cable. It was a little bit of a pain but it's all done!!
Thanks again,
Steve
Huzzah is offline
Patriot 09 Sirius meni0n Jeep Compass & Patriot Forum 4 08-31-2009 10:27 PM
How to measure hitch extension ?? Gentleman Jeep Compass & Patriot Forum 2 07-17-2008 06:18 AM
Recommendations On Sirius Install TheGatekeeper Jeep Compass & Patriot Forum 3 10-09-2007 09:46 AM
Sirius Radio Swaybar Jeep Compass & Patriot Forum 6 09-24-2007 05:05 PM
Sirius factry unit? Compassowner84 Jeep Compass & Patriot Forum 2 08-08-2007 03:29 AM
