Help Please. Problem with patriot. - JeepForum.com
post #1 of 7 Old 10-02-2012, 11:21 PM Thread Starter
Hadfield
I have a new 2012 patriot with 370 miles on it. the other day while driving home I had the ABS, Traction control, and Parking brake light come on. since then sometimes the lights will come on randomly and then go back off.
I took it to the dealer and they told me that it is a bad abs module and they would have to replace it but the part is backordered. all the research I have done has got me nowhere. Has anyone else had this problem?
I use this vehicle for the fire department and it has me worried. seems with 370 miles on this vehicle I shouldnt have these problems. is the dealer correct or is it something else?
Thanks all!
Hadfield is offline
post #2 of 7 Old 10-02-2012, 11:27 PM
FujativeOCR
2011 MK Patriot
A bad or disconnected wheel speed sensor. Others have had this too, and i had a grand am that did it. Both ABS and Traction Control systems use the wheel speed sensors to monitor slippage. The car probably thinks one wheel is locked up or spinning when it isn't. If the dealer provided ABS module doesn't fix it, one of the wheel speed sensors will.
FujativeOCR is offline
post #3 of 7 Old 10-03-2012, 12:06 AM Thread Starter
Hadfield
thank you for the fast response! I told them when I took it in that i believed it was the wheel speed sensors and they insisted that it was the abs module stating that "this is their job".. i cant wait for that statement to blow up in their face. I contacted jeep corp. headquarters and told them that I am extremely upset that im already having issues.
Hadfield is offline
post #4 of 7 Old 10-03-2012, 12:19 AM
FujativeOCR
2011 MK Patriot
Well they do say that most new car failures will appear in the first few hundred miles. Hopefully this is the only one. I've never looked at the jeep sensors but you should stick your head under there and see if one is unplugged.
post #5 of 7 Old 10-03-2012, 06:36 PM
jasonwe
2012 MK Compass
+1 for what Fujative said. During the purchase of my wife's 2012, the salesman warned us that "You'll have it into the dealership more during the first few thousand miles than the rest of the vehicle's life." So far we've only had to take it in once for a squeak coming from the front, driver's side dash near the windshield, and that turned out to be the infamous wiper cowl. They fixed that free of charge, and haven't had another issue yet. Just shy of 2400 miles now.
2012 Jeep Compass Sport 4x4
2.4L I4, CVT II, Freedom Drive I
2010 Dodge Dakota Quad Cab 4x4
4.7L V8, 545RFE, Big Horn Edition
jasonwe is offline
post #6 of 7 Old 10-04-2012, 03:58 PM
FujativeOCR
2011 MK Patriot
I had to replace an interior door panel after 3 weeks when i got mine. It had an air bubble that ballooned up when hot or high altitude.
post #7 of 7 Old 10-05-2012, 10:17 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hadfield-
After you get it done, let us know if the dealer repair works.
If an Anti-Lock Brake Module's microprocessors aren't operating correctly - that would be one reason to replace the module.
JeepCares is online now
jeep Patriot H.I.D problem marco182 Jeep Compass & Patriot Forum 5 04-17-2012 11:28 AM
07' Patriot Engine Light Problem kairosdreaming Jeep Compass & Patriot Forum 2 02-10-2012 10:23 AM
Friend's Patriot Problem C2U5H Jeep Compass & Patriot Forum 3 10-17-2011 06:10 PM
Headrest Problem On 2008 Patriot ChillyWillys Jeep Compass & Patriot Forum 16 08-24-2009 09:59 PM
New Patriot (slight alignment problem) phil8400 Jeep Compass & Patriot Forum 16 05-17-2007 09:31 PM
