HELP! Jeep doesn't want to start when it's hot/sunny - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > HELP! Jeep doesn't want to start when it's hot/sunny
ZONE 4.25" combo lift for TJ available at Rockridge4wNitro Gear Packages Now Available at Rockridge 4wdROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 09-13-2013, 07:27 PM   #1
CasOli
2007 MK Patriot
So yea, as soon as we get a sunny, warm day my jeep doesn't want to start. It turns over but doesn't "fire". It will just turn and turn and turn until I stop and try again...but only when its sunny! The battery has been checked, the starter is fine, the oil and filter are fresh, I'm really at a loss here...Thoughts?
CasOli is offline   Reply With Quote Quick reply to this message
Unread 09-13-2013, 08:29 PM   #2
FujativeOCR
2011 MK Patriot
Fuel filter or pump? How many miles?
FujativeOCR is offline   Reply With Quote Quick reply to this message
Unread 09-13-2013, 11:58 PM   #3
aroundincircles
1989 XJ Cherokee
Haven't had this problem on my jeep (its only a year old) but common problem I've had on other cars. Sounds like the crank shaft position sensor.
1989 Cherokee Pioneer
http://www.youtube.com/c/aicoffroadvideo
http://goo.gl/OspLWH - amazon link
aroundincircles is offline   Reply With Quote Quick reply to this message
Unread 09-29-2013, 02:58 PM   #4
Biloxinative
2013 MK Patriot
Mine does the same thing. It's a 2013.. Only when it's sunny or hot outside. Any answers to help?
Biloxinative is offline   Reply With Quote Quick reply to this message
Unread 09-29-2013, 03:04 PM   #5
Biloxinative
2013 MK Patriot
Rear camera system though navigation
I have a 2013 patriot, that did not come with a rear camera back up system. Anyone know if there is one that can be installed though the navigation screen? I do not want to purchase one that attached to the rear license plate with the small LED screen to mount.. Thanks
Unread 09-29-2013, 04:04 PM   #6
BostonStrong
2013 MK Patriot
BostonStrong is offline   Reply With Quote Quick reply to this message
Unread 09-30-2013, 08:00 AM   #7
aroundincircles
1989 XJ Cherokee
you should be under warranty, so I would take it to the dealer, but as my post says above 99% sure its the crank shaft position sensor. That is a very tale tell sign of it going bad.
