Hello! Power Window Problem, please help. - JeepForum.com
post #1 of 7 Old 09-20-2010, 08:29 AM Thread Starter
cobbs
Hi everyone,
New to the forums. I am here looking for some information for a friend’s 2007 Jeep Compass. She is having issues with her driver's side power window.
Occasionally, the window would go down and not come back up, then mysteriously begin working again a few hours later.
When I took a look at it, the window was working, but I noticed that when you pressed the down switch, the window would go down, but when you released the switch, the window would "glide" to a stop, moving another 1/2" to 1" after I took my finger off the switch. All other windows stop immediately after releasing the switch.
I think this is a worn window motor clutch and that I need to order and install a new motor assembly. What do you folks think?
Thanks for any insight!
cobbs is offline
post #2 of 7 Old 09-21-2010, 11:23 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I had something similar on a rear window. Mine's an early production too. The window track needs adjustment would be my guess, the factory messed up. This would also cause the "extra travel" when you release the button while the window settles in.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 7 Old 10-07-2010, 07:27 AM
pillzny
My passenger side window is all the way down and wont come back up. Of course it'd rain this am and at about 55 degrees... the ride to work stunk.
Any way to do this myself and avoid a trip to the dealer?
2007 btw
pillzny is offline
post #4 of 7 Old 10-07-2010, 07:30 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Remove the door panel and adjust the window track.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 7 Old 10-07-2010, 11:41 AM
pillzny
So not in the mood but its inevitible. Almighty Gramps, would you happen to have a diagram for removing the door panels?
Thanks in advance
A little more detail, I hit the switch and hear nothing(i have power windows). Either its really "stuck" or maybe disconnected somewhere. Is there anywhere else I should check b4 getting in there? I did already check all the fuses
pillzny is offline
post #6 of 7 Old 10-07-2010, 11:59 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Here's a start http://www.jeepforum.com/forum/f98/s...8/#post8704972
I'm working on a full write up with more info. Once the panel is off there are 2 guide tracks that are under it that (I believe) are the ajustments.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 7 Old 10-07-2010, 12:12 PM
pillzny
Thank you very much!
pillzny is offline
compass , mk , patriot , track , window
Power steering problem Urr Jeep Compass & Patriot Forum 3 07-19-2010 10:27 AM
Problem with lights on window switches adsaue2 Jeep Compass & Patriot Forum 25 09-01-2009 07:30 PM
2009 Patriot window tint? samiebaby1 Jeep Compass & Patriot Forum 1 12-18-2008 01:09 PM
loss of power? CharBroiled Jeep Compass & Patriot Forum 13 03-29-2008 07:27 PM
Window Visors Gramps Jeep Compass & Patriot Forum 3 12-17-2006 08:12 PM
