has anyone put a lift on their compass? - JeepForum.com
post #1 of 27 Old 07-16-2013, 09:06 AM Thread Starter
egsox
2015 JK Wrangler
I'm curious to know if they are out there and is it worth the price. Thanks in advance.
egsox is offline
post #2 of 27 Old 07-16-2013, 09:57 AM
FujativeOCR
2011 MK Patriot
Yes someone has. They are out there.
FujativeOCR is offline
post #3 of 27 Old 07-24-2013, 05:09 PM
aroundincircles
1989 XJ Cherokee
I lifted my patriot, same set up. Do you have a fdi or fdii, and go off roading a lot? Might be worth it, if its fwd or if you only drive in town, I wouldn't bother.
See pics of my lifted patriot look for a thread on here labeled aroundincircles' patriot.
89 Cherokee
aroundincircles is offline
post #4 of 27 Old 07-24-2013, 05:30 PM
aroundincircles
1989 XJ Cherokee
Actually just check out the links in my sig.
89 Cherokee
post #5 of 27 Old 07-25-2013, 12:00 PM Thread Starter
egsox
2015 JK Wrangler
I have the fd1. I do plan on off roading.
egsox is offline
post #6 of 27 Old 07-25-2013, 12:40 PM
aroundincircles
1989 XJ Cherokee
Awesome, there are two options, rro's spacer lift and stu coils out of Australia, I went with the rro lift.
89 Cherokee
post #7 of 27 Old 07-25-2013, 01:26 PM
TheHeilis
^ same went with RRO lift. at 91,000 miles still going. Installed @ 18,000.
2002 Wrangler Sahara, 2008 Patriot FDI
Member of Northwest Indiana Jeepers
White Jeep Club Member #117
TheHeilis is offline
post #8 of 27 Old 07-25-2013, 03:37 PM
tommudd
2004 KJ Liberty
Spend the money and do it right, it'll cost more with Stus, but ride, handling and overall it will be 100 times better than the RRO junk
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #9 of 27 Old 07-26-2013, 05:43 AM
TheHeilis
That's what I love, a low opinion of something. 100 times better? Sure it is
post #10 of 27 Old 07-26-2013, 05:58 AM
tjkj2002
2002 KJ Liberty
Putting cardboard under your coils is better then anything rro puts out.
tjkj2002 is offline
post #11 of 27 Old 07-26-2013, 06:01 AM
tommudd
2004 KJ Liberty
So true so true
MUDD'S MOTORSPORTS
tommudd is offline
post #12 of 27 Old 07-26-2013, 06:18 AM
tommudd
2004 KJ Liberty
Well comparing a cheaply, poorly built spacer lift by RRO to a well built and designed lift by Stu is a no brainer.
Not only would you have way better ride but would also last longer as well
MUDD'S MOTORSPORTS
tommudd is offline
post #13 of 27 Old 07-26-2013, 09:03 AM
iamrone
2007 MK Compass
I've got the RRO kit installed and don't have any complaints at all. Fortunate to have gotten their 2nd gen control arms in the rear (fully adjustable and more robust). Took the opportunity to swap all 4 of my leaking struts, new sway links, control arm bushings, and inner/outer tie rods at the same time. All said and done, it felt better than new! Not like this is the first round of suspension work needed...
After about 1,000 KM my driver's side half shaft was shot. Angles were not out of tolerance, but the vehicle had spent 165, 000 KM at a specific angle which I altered. I imagine it was just time to go.
My co-worker has Stu's Coils and similar tires. Hasn't had a problem either. Install was about as painless.
They both handle differently. Stu's is more truck like and much more responsive. If I were doing it all over again, I'd probably have gone with Stu's as I needed struts anyway, and besides yellow just screams 'off-road' :P
In terms of longevity? I can't see a solid block of metal failing anytime soon, but I didn't engineer it. And at this point I don't really care, if this thing makes it to 250, 000 KM it'll just be a bonus
iamrone is offline
post #14 of 27 Old 07-26-2013, 09:05 AM
TheHeilis
How? please explain this. Last time I looked they were made out of steel. It's been on ther since 2009 and NO problems but go ahead and tell me so's I'll understand. Your ride changed no doubt due to the spring rate change, but you still used the same strut and limiting your upward strut travel by ~2 inches.
I see nothing wrong with either lift but I guess I'm not as opinionated as the the "STU" guys. RRO was the only option when I did the lift so why all the hateraid in the post? Did either of you offroad and /or have a Patriot or Compass lifted 4 years ago?
post #15 of 27 Old 07-26-2013, 11:11 AM
tommudd
2004 KJ Liberty
You can't even compare a cheaply made spacer lift to a full spring lift which gives way better ride, better handling, lasts a long time and less issues
Plus RRO , well they are great at BSing thats for sure
But I guess if thats all you've ever had then you'll never know how well it could of been
Carry on
and to iamrone
the spacer lift from RRO of course doesn't fail, its the UBJs, etc on yours that will fail. Its harder on the suspension parts going with a spacer style lift than a full spring lift
I've had a RRO spacer lift laying at my garage since 2005 , won't even sell it or install it. The previous owner went through 2 right side and one left side UBJs in less than 20,000 miles. Finally gave up and sold everything to me that he had aftermarket
MUDD'S MOTORSPORTS
tommudd is offline
