H.I.D Light issue - JeepForum.com
post #1 of 18 Old 01-18-2012, 08:12 PM Thread Starter
srtdodge05
2011 MK Patriot
H.I.D Light issue
I had some H.I.D lights installed and having a issue with them. They seem to flicker and cant figure it out. The installed tried two different ballasts and different bulbs and they still flicker.
srtdodge05 is offline
post #2 of 18 Old 01-18-2012, 08:27 PM
tjkj2002
2002 KJ Liberty
Put back in the correct halogen bulbs and problems solved(and legal).
tjkj2002 is offline
post #3 of 18 Old 01-20-2012, 08:44 AM
IRSmart
2015 KL Cherokee
and safer. hallogen headlights are not designed to emit a legal or safe beam pattern. take them out and throw them away. don't sell them to someone else, throw them away. selling them will only allow a dangerous beam pattern to show up in someone else's car.
to answer your question, the computer in your car is more advanced than anything you've had before. it is sensing the change in voltage and is causing the problems. there is no simple way to hook HIDs up into a compass/patriot.
IRSmart is offline
post #4 of 18 Old 01-21-2012, 09:49 AM Thread Starter
srtdodge05
2011 MK Patriot
Problem fixed for the flicker in the lights. I got a different brand bulbs and the problem is gone.
post #5 of 18 Old 01-21-2012, 10:00 AM
IRSmart
2015 KL Cherokee
doubt it, the flicker will still happen, it just might not be as frequent. i know what the fix is, and it isn't that.
do everyone else a favor and get rid of them. here is a very good read as to why HIDs are not a good (or legal) idea to have in your car:
http://www.danielsternlighting.com/t...nversions.html
IRSmart is offline
post #6 of 18 Old 01-21-2012, 10:49 AM Thread Starter
srtdodge05
2011 MK Patriot
After 2 days of being replaced not one flicker. I had the Sylvania bulbs before but weren't bright enough.
post #7 of 18 Old 01-21-2012, 11:37 AM
IRSmart
2015 KL Cherokee
that fact not withstanding, read the article i posted above. you're hurting yourself more than you think you're helping yourself.
IRSmart is offline
post #8 of 18 Old 01-24-2012, 07:17 AM
Photolithic
In order to "propery" install HID lamps in your vehicle, electrically speaking, is to put resistors inline with the headlight wiring to bring the voltage down to a level accepted by the computer. However, your lamp housing is not designed for HID lamps. The position of the arc, what would be a filament in a standard bulb would be positioned incorrectly for your lamp housing. The result, a lot of blinded and pissed off drivers infront of you.
Photolithic is offline
post #9 of 18 Old 01-24-2012, 11:12 AM
IRSmart
2015 KL Cherokee
right
not right. it needs to be a relay system.
IRSmart is offline
post #10 of 18 Old 01-24-2012, 12:05 PM
Photolithic
Originally Posted by IRSmart View Post
right
Probably that too, but previous installers have made use of resistors to solve the problem, more than likely in concert with relays. A few guys on the "other" jeep patriot forums have "how toooos".
post #11 of 18 Old 01-24-2012, 05:26 PM Thread Starter
srtdodge05
2011 MK Patriot
The problem I had was defective bulbs he used. Ordered a new set and problem was gone. He installed a relay pack that worked great. The 8000k he install has a low/high beam. I don't like how blue they are so going with some 6000k that is more of a white light. This is my third car with H.I.D lights and never been flashed from having them.
post #12 of 18 Old 01-24-2012, 05:49 PM
tjkj2002
2002 KJ Liberty
Does not mean your not blinding oncoming traffic or being a jacka$$ to others and there safety.
High beam HID's are illegal no matter what.The vehicles that come with low/high beam HID's just re-aim the low beam for high beam function so not a true low/high beam.
tjkj2002 is offline
post #13 of 18 Old 01-24-2012, 06:42 PM
Photolithic
My Mini S has HID lights, and I love them. Provided, they auto aim themselves to the correct position. If you really can't live without them...perhaps a projector retrofit designed for HID bulbs??? I've seen some pretty nice ones in my VWing days lol. May look kinda goofy in the patriots round headlight housing though lol.
post #14 of 18 Old 01-24-2012, 07:44 PM
IRSmart
2015 KL Cherokee
that's the only way to safely do HID lights. your car is different because it came with them from the factory. your housings are meant to emit a proper beam pattern. the danger comes when you try and replace a hallogen bulb with an HID bulb. it's like putting on someone else's glasses and expecting better vision.
OP, please read the article i posted above. there are several reasons that HID retrofitted lights are not safe. for one, you actually see better with the hallogen bulbs you had before
Originally Posted by your response
no i don't, i see hella better now than i did before!
yes, you can. hids are very bright, yes, but the retrofits don't put that light where it belongs. you can see better directly in front of the car, but your vision at a distance (where it matters) is hindered for two reasons: one, the light isn't properly aimed, and two, your eyes are focused on the bright light right in front, hindering your ability to see.
regardless of how many cars you've had HIDs in, it's never a good idea to put them in cars that don't have them from the factory. like i said, read the article i posted above. it has test results the government did on these kits, and shows a computerized beam pattern of three cars, clearly showing why they're unsafe and illegal.
bottom line: they're a bad idea, and the only people that buy them are the ones uninformed to their danger. it's people like me and Photolithic that try and educate people to get these pieces of garbage off the roads.
IRSmart is offline
post #15 of 18 Old 01-24-2012, 09:16 PM
General_Jeep
1994 ZJ
Some people over at the ZJ side are starting to do HID projector retrofits because our ZJ's stock housing suck arse. I am planing on doing one of those swaps because I can't see anything in that Jeep. My Patriot with silver stars is quite impressive beating out my dads Merc GL with projectors.
1994 Jeep Grand Cherokee 5.2L V8- NV3500 - Blown D35 8.8 replacement some day.
2010 Jeep Patriot 5 speed manual-- DD, 27-31MPG :D
1996 Dodge Ram 1500 - Work Truck/Plow 5.2L NV3500
2005 Nissan Titan - Hauler
"The Jeep is Americas only real sports car!" - Enzo Ferrari
General_Jeep is offline
Shifting issue Elihawk Jeep Compass & Patriot Forum 17 11-09-2011 07:54 AM
Will backspacing solve the issue? tjwrangler99 Jeep Compass & Patriot Forum 3 01-22-2011 09:49 AM
Another acceleration issue... Elihawk Jeep Compass & Patriot Forum 9 06-10-2008 05:34 AM
Rough idle issue Anewbigging Jeep Compass & Patriot Forum 2 03-21-2008 05:54 AM
Patriot Hood Issue Silkk19 Jeep Compass & Patriot Forum 6 03-01-2008 08:04 AM
