Green fluid leaking? - JeepForum.com
post #1 of 2 Old 02-22-2014, 08:45 AM Thread Starter
mich99TJ
My 2007 Patriot 4x4 Manual Transmission is dripping something green from under the general area of the engine compartment. I tried to peak under it and could not see it obviously dripping from anywhere, but I'll have to jack it up soon and really try to pinpoint what is leaking.
I was wondering if anybody had an experience with what the possible culprits may be...
1) coolant is pink on this, so I dont think its related to that
2) brake fluid is usually greyish in color
3) maybe its related to the FDI differential or the manual trans lube?
'99 TJ SE, 2.5 / Ax5 / NP231, D30/35, 4.11
Intense Blue, 31" BFG ATs Warn M8000 Winch, Cobra CB
'14 Cherokee Trailhawk, 3.2 V6, 9 Speed, Granite / Moroccan Black Interior, 8.4 AN, Trailer Tow
mich99TJ is offline
post #2 of 2 Old 02-25-2014, 03:06 PM
DEMO111
2009 MK Patriot
It's coolant.
I have a 2009 Patriot Sport / manual transmission and I noticed a half dollar sized spot on my garage floor every so often when I parked. It would occur directly under the engine compartment. My mechanic took a look at the cause and found out that the gasket on the thermostat was leaking and dripping down the engine block. I had the gasket replaced and fixed the problem.
DEMO111 is offline
