Goodyear Wrangler Tires - Page 2 - JeepForum.com
post #16 of 30 Old 09-24-2013, 09:45 AM
NHPATRIOT
2014 KL Cherokee
Originally Posted by jeepguy2010 View Post
Ok, so if not goodyear tires then what other kinds are good that are moderately price. Ones that others have been impressed with.
What kind of use will your vehicle see besides winter? On road or off?
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
NHPATRIOT is offline
post #17 of 30 Old 09-24-2013, 03:09 PM
aroundincircles
1989 XJ Cherokee
The most common tire used on the other jeep patriot site in stock sizes would be the Yokohama geolander ats tires for sure. Haven't heard anything negative about them. Other people take the opportunity to go up or down in wheel diameter, to increase tire choices. I for one will get a set of 15" rims so I can get a set of mt tires.
89 Cherokee
aroundincircles is offline
post #18 of 30 Old 09-24-2013, 06:21 PM
NHPATRIOT
2014 KL Cherokee
Be careful. From what I have read many/most 15" rims will not fit on the Patriot due to brake issues( caliper/rotors ).
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
post #19 of 30 Old 09-24-2013, 11:58 PM
aroundincircles
1989 XJ Cherokee
discount fitted some to my pat a while back, and they had no issues at all:
http://www.jeepforum.com/forum/f98/1...sults-1489685/
and since I go off roading so much, it would make more sense to have a smaller wheel. more sidewall means less likely to pinch a side, or slice it on a rock. (something I haven't done yet, yay!)
89 Cherokee
post #20 of 30 Old 09-25-2013, 03:35 PM
NHPATRIOT
2014 KL Cherokee
Just wanted you to be careful.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
post #21 of 30 Old 09-27-2013, 07:02 AM
KLRJEEPER
Anything but SR-A is my answer...they are the crappiest tire I have ever used. pure JUNK!....look at cooper. last forever, and great warranty too!
KLRJEEPER is offline
post #22 of 30 Old 10-01-2013, 09:55 AM
KayCeeJeep
The inexpensive Wranglers Wally's sells were a huge disappointment for me, about 25k mile tires. No experience with the others.
KayCeeJeep is offline
post #23 of 30 Old 03-30-2014, 10:59 AM
warrior__one
2013 MK Compass
I highly recommend staying away from walmart tires, especially the goodyear wrangler territory as they ate Made For Walmart exclusive tires and do no meet true goodyear quality specs. As for the SRA wrangler I was a bit dissapointed when I ordered my compass with the OWL A/T tire package and it rolled out with these "street" tires. However they are definatly not as bad as others are stating considering ive ran mine hard in the true north winter of Canada and have not missed a beat whatsoever. 15000 km so far and to be quite honest the tires dont look worn at all. I wouldnt doubt achieving 50k or more easily. It really depend on what you are looking to use them for, hwy or offroad. As for myself I will be looking into the Wrangler D7ratrac size option as these tires are a beautiful mix for what I need, decently agressive tread pattern, very appealing appearance, quality brand and as for being a GOODforaYEAR, you sir must drive alot considering I run these on our f350 diesel 4x4 thay spends 7mnths of the year towing a S130 Bobcat and the remainder being a plow truck with a full size sander mounted to the front and a 9ft V-plow on the front. All this and with proper tire rotation we will definatly see 60-70k out of them. Put about 40+k a year so 8 guess you could call them GoodYearNaHalfs lol.
warrior__one is offline
post #24 of 30 Old 03-31-2014, 02:37 PM
ODubhGhaill
2014 MK Patriot
Why do you feel they are "pure JUNK!"
ODubhGhaill is offline
post #25 of 30 Old 04-01-2014, 10:25 AM Thread Starter
jeepguy2010
2010 MK Compass
Ok, here's an update... I decided not to get the Goodyear Wrangler tires. I went with another brand called Sumitomo tires. Nobody knew anything about these tires when I first got them, but I wanted something with a pretty aggressive tread pattern and a decent life span. These tires fit that bill at least as far as the agressive tread pattern goes. The life span is still yet to be determined as i've only put about 5,000 or so miles on them so far. They are rated at 75,000mi.
jeepguy2010 is offline
post #26 of 30 Old 04-03-2014, 08:06 AM
warrior__one
2013 MK Compass
Biggest question, where do the tires say they are made. I have heard mixed review on this brand so I always stayed clear of them as alot of them are made in china.
post #27 of 30 Old 04-04-2014, 12:40 PM Thread Starter
jeepguy2010
2010 MK Compass
Is this question about the Goodyear Wrangler tires or the Sumitomo Tires?
post #28 of 30 Old 04-06-2014, 07:53 AM
warrior__one
2013 MK Compass
Only Goodyear tire I've seen grom overseas are the stock tires that roll off the lot on a new vehicle. I was referring to the Sumo tires you purchased.
post #29 of 30 Old 04-06-2014, 08:11 AM
BostonStrong
2013 MK Patriot
I checked out the Sumo site; which tires did you get? None of the tires on the site looked like they would visually fit with the Patriot.
BostonStrong is offline
post #30 of 30 Old 04-07-2014, 10:49 AM Thread Starter
jeepguy2010
2010 MK Compass
Sumitomo Touring LS T. 215 60R17 look it up on tirerack.com they have them.
