Good place for a 4ch amplifier ! - JeepForum.com
post #1 of 3 Old 09-04-2007, 10:03 PM Thread Starter
peterg2000
Hi everyone ,
Just got my Compass last Thursday Aug 29 ! Liking it so far !
I was wondering is there was a place to put an Amplifier in the dash ?
I was going to put some speakers in the back but now I'm thinking more about replacing the door speakers with a decent pair ! Probably the Pioneer TS-D691R's.
I'm assuming from what I've read that the door speakers front and rear ARE 6X9's !
I don't need that much power so I'm looking for a good 4 channel amp 50 RMS watts /ch !
I hope I don't have to run the wires to the back or under a seat !
Thanks in advance !
Pete
peterg2000 is offline
post #2 of 3 Old 09-05-2007, 04:04 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
You might find enough room at the bottom of the center stack or behind the glove compartment but I don't know what the heat dissipation would be like. It may be less trouble to pull the door scuff plates and quarter panels than to pull the pieces to get under the dash.
and to the group!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 3 Old 09-05-2007, 06:34 PM
Jason31
What I would highly recommend to you, based on your requirements listed, would be to buy a Class D or higher amplifier. Example - Alpine's Class D amplifiers. Small amps, good power, highly efficient which means you can run thinner power/ground wires and they won't put off as much heat.
Yes, you would have no problem mounting one in the dash. One issue you could possibly have though is noise. With all the wires in the dash, noise could be an issue. Highly recommend running your ground wire up to the battery if possible, this will help for this specific install.
2007 Jeep Compass Limited - Black w/Chrome 18" OEM Wheels
Jason31 is offline
want to buy compass. good/bad and dealer invoice bringbackphish Jeep Compass & Patriot Forum 2 04-23-2009 08:48 AM
Compass a good buy? Kryptes Jeep Compass & Patriot Forum 7 02-23-2009 05:09 PM
Picked up my new Patriot on Tuesday - so far so good!! BeaterPatriot Jeep Compass & Patriot Forum 5 06-06-2008 01:11 PM
Good deal on 2007 Patriot and mpg on 4x4 Feb Jeep Compass & Patriot Forum 2 05-30-2008 11:35 AM
Crutchfield radio harness no good? websurrfr Jeep Compass & Patriot Forum 4 07-06-2007 07:12 PM
