Getting a lift - JeepForum.com
post #1 of 10 Old 04-16-2012, 11:42 PM Thread Starter
marco182
2007 MK Patriot
Getting a lift
i own a 2007 Patriot limited 4x4 2.4L and i want to get it lifted.any tips ? i also want to upgrade to larger knobby tires aswell.
marco182 is offline
post #2 of 10 Old 04-17-2012, 07:53 AM
ruienr54
2009 MK Patriot
Your choices are basically this:
RRO spacer suspension Lift from Rocky-Road Outfitters (based in US)
Masterkit1 spacer suspension lift from Masterkit (based in Quebec, Canada)
STU'S COILS suspension lift using different coils (based in Australia)
Purchase the FDII/or 2012 coils ...they seem to be around an inch taller.
BTW - The first 3 choices all give you around 2 inches of lift (give or take a little). Anything taller than that can put dangerous strain on your CV joints because of the angle they will be at....and they will likely break.
Hope this helps!
ruienr54 is offline
post #3 of 10 Old 04-17-2012, 09:39 AM Thread Starter
marco182
2007 MK Patriot
excellent i ordered the first 1 quicker delivery and a bit cheaper! thanks
marco182 is offline
post #4 of 10 Old 04-18-2012, 04:59 AM
ruienr54
2009 MK Patriot
Good choice, although they all have really good reviews. I have the masterkit1 on the way now and it's supposedly the same deign as the RRO, but just thicker. The STU coils get a phenomenal review since its an actual longer coil, but ordering from Australia becomes expensive.
ruienr54 is offline
post #5 of 10 Old 08-01-2012, 05:55 PM
nileek
Do it right and get the coils from Stu. Spacers are a cheap upgrade. You'll need camber bolts for the front end alignment. You can get these at your local parts store. Then get it aligned.
nileek is offline
post #6 of 10 Old 08-17-2012, 09:30 AM
ezzymo1024
Any experience with lifting just a fwd? I wish I'd bought awd. Kicking myself for that.
ezzymo1024 is offline
post #7 of 10 Old 08-17-2012, 08:32 PM
tcrosby86
2009 MK Patriot
What ezzy said. I have fwd and am considering a lift. Any diff install for the fwd than 4wd?
GREAT WHITE TYRANNOSAURUS SHARK
tcrosby86 is offline
post #8 of 10 Old 08-18-2012, 07:23 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Actually the first Patriot that RRO lifted was a FWD. Mine was the first 4WD. You'll be fine.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #9 of 10 Old 08-18-2012, 07:36 AM
ezzymo1024
Oh! That's very cool. Just in time too as I need new front struts and strut tower bearings.
post #10 of 10 Old 10-20-2012, 04:52 AM
KLRJEEPER
Master kit and rro are fine. And getting more lift with an fdii is always a plus.
KLRJEEPER is offline
