Gas tank - JeepForum.com
post #1 of 8 Old 01-13-2007, 06:29 PM Thread Starter
echocat22
2007 MK Compass
Gas tank
checked the book, have a compass sport 4x4, would guess all have the same gas tank volume, is it really only 13.5 gallons
echocat22 is offline
post #2 of 8 Old 01-14-2007, 12:20 AM
Jgrillz
Yea the gas tank seems small.
Jgrillz is offline
post #3 of 8 Old 01-14-2007, 05:33 AM Thread Starter
echocat22
2007 MK Compass
my subaru 2.5rs(2885 pounds) had a 14.9 gallon tank, i figured the compass would of had a least that, oh well
post #4 of 8 Old 02-02-2007, 07:24 PM
flatlanderep
Junior Member
my neighbor just bought one of these, filled up the tank and on the way back to the house, the GAS TANK FELL OUT!!!!
talk about irony huh?
....bring it back to the dealership and ask them to replace your tank
I think the recall number is #45311-982
flatlanderep is offline
post #5 of 8 Old 02-03-2007, 09:32 AM
XJ2Timer
I dislike how the gas tanks are getting smaller. I suppose it is for two reasons. One is for handling. To tune the suspension between a full and near empty tank the smaller capacity results in less of a weight difference. Second is fuel economy. If the vehicle is more fuel efficent they think the tank can be smaller which also by carrying less fuel/weight it also helps mpg. This all sounds great, in theory. But what if you are traveling hundreds of miles? To make the trip as short as possible it might make more sense to drive a larger vehicle with a larger gas tank. Sure I'll spend more in gas but I might be able to travel farther/longer without stops with the larger vehicle. I'd gladly trade many of the convenience items on a vehicle for a larger tank.
1st one- 1989 Cherokee Laredo. 12 great years
2nd one- 2001 Cherokee Limited. Got it before they were gone.
XJ2Timer is offline
post #6 of 8 Old 02-03-2007, 10:20 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I tend to agree that the gas tank could be bigger, in the 16 – 18 gal range so that I could comfortably go 400 miles non stop, the 300 mile range is adequate for my weekly commute if I have no side trips. I’m sure that one of the reasons that I do enjoy the smaller tank is purely psychological; it takes fewer dollars to fill it up but, it wouldn’t matter if I still filled up only once a week. It was also OK on the cross country trip because there are plenty of stations along the way and we made frequent stops to look for “treasures”. If someone made a larger aftermarket tank I may be interested in it.
I don’t think that the handling would be adversely affected because I believe that weight distribution is calculated on ˝ tank capacity and that would only affect it by 1 ˝ - 2 ˝ gallons and it would be low in the center of gravity.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 8 Old 02-03-2007, 12:34 PM
snikr
Yes....3 or 4 more gallons would be nice. Seeing as we only put about 145 miles a week on the Compass it's not a big problem right now.
Tom
2010 Subaru Forester
2004 Dodge Dakota 4 X 4
So many roads.......So little vacation time
snikr is offline
post #8 of 8 Old 02-04-2007, 08:55 AM
BuzzDog
I don't necessarily see a sweeping trend toward smaller tanks. For example, my first new car was a 1980 Mustang Ghia with a 200 c.i. inline six (remember the era before you start teasing me mercilessly); I seem to recall that its tank held somewhere around 12 gallons, and it was hard pressed to get 18 mpg, for a cruising range of less than 200 miles unless you ran it bone dry.
It seems that automakers shoot for somewhere around a minimum of 250 miles to a tank, using the EPA mileage figures multiplied by capacity.
A couple of nice things about not having a huge tank: When I travel a lot for work my Jeep sometimes goes only 100 miles or so in a month, so I don't have to worry about the fuel breaking down if I don't get around to topping off the tank, even though major fuel breakdown is fairly unlikely. Second, gasoline formulations in some markets are slightly modified to reduce emissions as temperatures fluctuate; in other words, the "winter formula" for fuel is slightly different than the ones used in other seasons. A smaller tank might make a slight difference in the quality of the air you breathe, and I'm all for breathing better air.
But again, those two advantages are a bit of a stretch...in reality, I think that manufacturers strike a compromise between weight, range and the ability to fit a tank within the vehicle.
BuzzDog is offline
Gas tank issue-When pumping it shuts off before full greencompass Jeep Compass & Patriot Forum 3 08-13-2009 06:03 PM
I'm impressed...29mpg on first tank...lifetime warranty... awd...for $15,999 2broke2smoke Jeep Compass & Patriot Forum 3 05-21-2008 04:17 PM
Seriously only 255 miles on a full tank....? rightsmanaged Jeep Compass & Patriot Forum 10 01-29-2008 06:17 AM
Click in Steering/TPMS/Sirius/Gas Tank blockisle9 Jeep Compass & Patriot Forum 6 11-25-2007 09:15 AM
Covering gas tank - suggestions? Melanie Jeep Compass & Patriot Forum 20 12-27-2006 08:05 AM
