gas mileage question - JeepForum.com
post #1 of 12 Old 09-26-2012, 09:57 AM Thread Starter
Elihawk
2008 MK Compass
2008 Jeep Compass, 5 speed, 2.4 liter engine. I consistently get 20-25 mpg in town (20 in cold weather) and 25-28 with mostly highway miles. Being I live in Iowa and farm country, I always buy Ethanol blend gas...
The other day, I stopped at a station where the Ethanol blend gas pump was out of order...so I filled up with premium gas. I noted the mileage and was suprised that on a highway trip where I usually get 27 mpg in the fall (speed limit is 55), with premium gas I got just under 22 mpg. I assumed that I would be improved over ethanol blend gas. Second time I have noted a drop in mpg with the highest octane gas available. What am I missing?
Elihawk is offline
post #2 of 12 Old 09-26-2012, 10:40 AM
FujativeOCR
2011 MK Patriot
Tire pressure? Temps coming down in fall your tires might have deflated.
Also, Premium gas is for high compression engines. Ours are supposed to use 87, which is actually more combustible than high octane. Maybe we get more power iff regular because of this.
FujativeOCR is offline
post #3 of 12 Old 09-26-2012, 10:53 AM
FujativeOCR
2011 MK Patriot
To expand on that, using "premium" gas, causes the engine to adjust it's own timing to compensate for the delayed combustion. Thus the engine produces less power, and probably requires more gas to compensate. Stick with 87.
post #4 of 12 Old 09-26-2012, 11:02 AM Thread Starter
Elihawk
2008 MK Compass
Thanks for the explaination...as I said, I usually buy ethanol blend (89) and get really good gas mileage, so I will stick with that!
Elihawk is offline
post #5 of 12 Old 09-26-2012, 12:34 PM
FujativeOCR
2011 MK Patriot
Just so you know...the Regular, Plus, and Premium designations are a sham to imply the higher octane is better. It's not better it's just designed for different engines. The octane rating is a percentage number of how much octane vs. heptane is in it. It's just a different blend with different ignition properties. But it' isnt technically better. It's just that usually the cars that need it are better cars. Cars with turbos and superchargers etc. if you put 87 in a HP car it will pre ignite and knock the engine. Conversely, putting 93 in our engine only makes it retard the timing and lower performance.
post #6 of 12 Old 09-26-2012, 05:01 PM
jasonwe
2012 MK Compass
Premium (91 or 92 or 93 octane) gas is not just for higher compression engines. It can also be used for more power and better mileage if your car's computer is properly tuned for it using a programmer, without really raising the compression ratio. Unfortunately, there aren't really any programmers for our little 4 cylinder engines.
2012 Jeep Compass Sport 4x4
2.4L I4, CVT II, Freedom Drive I
2010 Dodge Dakota Quad Cab 4x4
4.7L V8, 545RFE, Big Horn Edition
jasonwe is offline
post #7 of 12 Old 09-26-2012, 05:06 PM
FujativeOCR
2011 MK Patriot
Ok....exceptions to every rule. But most people aren't engine tuners.
post #8 of 12 Old 09-26-2012, 06:29 PM
cuemark8
2007 MK Compass
ethanol fuel mileage
Higher octane fuels will always have a worse fuel economy in ANY engine. The ethanol is used to boost the octane rating of gasoline to whatever it is wanted to be. IE 87,93. Pure ethanol has an octane rating of 116. This is blended to gasoline up to a maximum of 10% to federal limits. 87 octane gasoline has almost no ethanol in it. 93 octane will have closer to the 10% limit. Ethanol yields only half the fuel mileage of gasoline because ethanol needs half the amount of air gasoline needs. The more ethanol mixed in gasoline the worse fuel mileage. The amount of air, (ie oxygen) inside and engine cylinder is always the same. Unless the engine has forced induction. Twice as much ethanol is needed to get the proper air/fuel mix inside the engine for combustion as compared to gasoline. This is a big part as to why racing engines make so much power burning alcohol. Computers will sense the ethanol content of gasoline and compensate with more fuel to get the air/fuel mix right for combustion and emissions.
cuemark8 is offline
post #9 of 12 Old 09-26-2012, 08:56 PM
FujativeOCR
2011 MK Patriot
^that is incorrect. Where do you suppose ethanol free gas comes from? And how do you think it exists in all octane forms? 87, 89, 91, 93?
Gas is a mixture of Octane and Heptane. Ethanol is added (more often than not, but not exclusively) for emissions/pollution reasons, and yes the federal limit is 10%, except for E85. Gas with ethanol in it hurts gas mileage. But Ethanol has nothing to do with octane ratings.
post #10 of 12 Old 09-26-2012, 10:13 PM
jasonwe
2012 MK Compass
There are many different places that claim different octane ratings for ethanol. I've seen 99, 113, and 116 stated. The most common rating I see is 113, but they do not state if that is a RON, MON, or an AKI measurement.
In some states, they do use ethanol to boost octane ratings slightly. However, none of it is standard across the country (varies state to state), and the ethanol only impacts the octane a little bit due to the 10% or less guideline. What Fujative says has a lot of truth to it.
The only gas in my state of South Dakota, for example, that has any ethanol is typically the 89 octane, which is 10%. I have read, although I could not find any concrete evidence, that this is 85-87 octane gas that has 10% ethanol mixed to "boost" the rating to 89.
Also, South Dakota state law requires it be marked as containing ethanol if it does. The 91/92/93 octane here does not contain any ethanol unless it is marked as such. Many states have similar laws. Minnesota, on the opposite end of the spectrum, has a state law requiring all gas to contain 10% ethanol, or so I am told by relatives that live there. And this does not have to be marked on the pumps at all. They were even considering a law at one point to require 20% ethanol in gas sold.
jasonwe is offline
post #11 of 12 Old 09-26-2012, 10:27 PM
FujativeOCR
2011 MK Patriot
California too. All gas is 10% ethanol. There's 5 stations in the whole state that have ethanol free gas. I don't know how they get away with that at those stations.
post #12 of 12 Old 09-27-2012, 07:42 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Find a station in your area. I have one in my town that has racing gas. http://pure-gas.org/
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Horrible Mileage cactus_jack Jeep Compass & Patriot Forum 28 07-25-2012 10:44 AM
Mileage question-Help me help a friend! Ej132 Jeep Compass & Patriot Forum 22 02-22-2012 07:31 PM
Gas Mileage Question reduno Jeep Compass & Patriot Forum 16 09-15-2009 02:42 PM
Gas Mileage on 4x4 w Off Road safaribabe Jeep Compass & Patriot Forum 19 03-18-2008 10:01 AM
Gas Mileage/Break-in NoNamesLeft Jeep Compass & Patriot Forum 3 01-11-2008 06:17 PM
